terrabytetango
  1. So it seems there was a 3 buck price increase on Saturday?? I wasn't aware of this because I was out of town during the long weekend :/ And also I did pump a full tank before my trip, which was at the regular rate. However that still doesn't explain the differences does it? I mean it's the principle of the thing that irks me, like the bus conductor withholding 50 cents in change, not the actual loss.
  2. That would be the correct assumption, but till last week the volume for RS1000 worth of petrol had been 'fixed' at 6.211 litres, What worries me is the fluctuation itself and how it varied from shed to shed. It's unpleasant to think shed operators are actually crass enough to operate with such impunity without fear of blowback.
  3. I've got a 256MB model B which I've been using since last June. It's run off a small a solar panel hooked up directly via a small ebay solar power controller to a 12V battery. It runs a minimalist version of Raspbian without any GUI, I use it for console work only, mainly as a torrent downloader and IRC eggdrop. I've got the new model B and model A on the way as well. The B will be used as a stand alone classic console and PC game emulator, not sure what I'm going to do with the other one yet.
  4. Okay, so my normal routine is to pump a thousand bucks worth of fuel every 2 days. Since the December '12 price hike, the ratio has been 6.211L/1000 bucks, which actually works down to less than the 6.28 odd one gets when doing the math, but yeah, Sri Lankan Economics®. However, since this week, I've noticed capacities fluctuating at places I pump at regularly i.e. Nugegoda Bo tree and Rajagiriya Pizza Hut. On Tueday, the tally was 6.183 at Nugegoda, and today, the Rajagiriya joint pumped only 6.172 litres, indicated by the display. I didn't fuss about it, but I'm wondering if anyone else has noticed a decline in the pumped volumes of fuel, or if I've just been especially unlucky to win the unjackpot this week.
  5. The irony is that even though the Nissan Patrol hasn't seen the shores of North America since the 60's, they were the first to get Nissan's (Infiniti) super sized SUV, the Q56, which incidentally is the same as the new Patrol Y62. It's up there with the LC200, and IMO looks so much better. Enough to contend with the new Range Rover even I would say.
  6. I have no idea. I have yet to do a full service on my car, I'm waiting till I hit 75K , which coincides with the service interval after next. You needn't make it an immediate concern unless you're hearing weird noises and/or experiencing power loss issues. However I do suggest you carry out a full service, including inspection of drive line and suspension, when you hit 100,000 kms.
  7. 1NZ-FE, can't beat it. My Vios has the same engine, and performance isn't bad considering the car weighs only 1030kg. I suspect the Thai engineers realized this too, since they managed to cut costs nearly everywhere, yet they decided on fitting rear disc brakes.
  8. Your car has a timing chain, not belts. The only reason to change it would be if it fails the inspection for stretching or damaged links.
  9. I considered this Davy, but the issues is there is no place on the outer perimeter of the door frame to attach anything to, the door fits quite snugly into the door jamb. The door switch in my car is on the door jamb itself, in the vicinity of the latch hook, so I would have to route the wiring through the conduit for mirrors locks and windows. Mounting on the door card was also considered, but apart from the wire routing issues, all feasible solutions I've come with so far are rather permanent, and I'd really prefer to retrofit instead of altering anything.
  10. The problem with the lights under the mirror is that when you open the door they become completely useless, more so for egress. I've been meaning to have some kind of light installed under the rocker panel to illuminate the sides of the car on which door is open. I can't even begin to count the number of times I've stepped in puddles/garbage/various kinds of animal feces etc when parking in unfamiliar places at night. My idea was to buy a spool of LED lights and attach them to the side skirts of the body kit, angle at 45 degrees down on the horizontal, split into sections for each door, and hook up each section between the door switch and dome light. Thus, only the bit under the opened door will light up.
  11. Your Axio is a _Corolla_. And did you try drying out the camera? Also nearly every cam on ebay will work with your car, what you need to do is find one with a similar mounting hole pattern, and the color system i.e. NTSC or PAL. The two wire model uses the second wire to power the IR emitters, to enhance the camera's night vision. AFAIK this function is handled by the camera itself without needing any further interface to the head unit.
  12. The new RR is all aluminium, that's what excites me the most. It's a good 400kg lighter than the outgoing model, which is massive in terms of weight saving.
  13. To quote Jalopnik, 'Nice Ride' or 'Crack Pipe'?
  14. Broken engine mount I think, the "dadas" sound is the engine shifting and settling.
  15. 6.5 mil for a VW kit car? Trololz. Edit: Yes I know they're rare and collectible, but they're not 6.5 million bucks rare. Also the design has nothing to do with the Miura, I forget what car it's based on though.
  16. Most probably the micro switches are worn out, or less likely, the indicator bulbs are burnt.
  17. I would say the upper limit would be 7-8 laks.
  18. Follow your mechanic's advice, invest in a good trickle charger and a battery suited for diesel engines. You can use google to find out which battery is best for you.
  19. I would say for the investment, it isn't worth it. Granted Carinas/Coronas have the same options that G grade 141s do (and no, wanker mirrors, intelligent keys, button lock etc are not essential functions), they're overpriced. The Chevy Cruze is a nice distinct looking vehicle IMO, the Passo isn't bad either but the interior is quite spartan and lacking in options when comparing with the Swift/Cruze. In the end, it is your decision, but I do suggest you drive each vehicle and form your own opinion. Don't discount the Toyota Duet either, which is a rebadged Daihatsu Storia. And remember, if you do decide on an older car, check the service history.
  20. IMO, even the latest Carina you can find is still at least 11 years old, and paying ~2.5 million for one seems obtuse. You could easily spend the same on a newer Civic.
  21. In defense of the Jimny/Samurai, they are in fact proper off roaders, just pocket sized; they have solid axles, proper transfer cases and all, and they can be taken off road quite easily, the low weight being an advantage in sticky situations, but the compact dimensions do mean it has a higher center of gravity. The Terios/Rush are simply crossover vehicles which are based on car platforms, and their only distinct advantage is the higher ground clearance and seating position.
  22. fkn hilarious
  23. I'm going to attempt this during the weekend. It will be the first time I'll be properly getting intimate with an EFI engine. I've got a check list of things to do and this seems to be a nice place to start taking things apart from.
  24. +1 for filters. Did you check the fuel filter for clogging? My experience with worn 2C engines have been that, crank them for about 10-15 seconds with a good battery and they *will* start. Even without using the glowplugs.
  25. Surgical spirit might leave a white residue on some surfaces. Don't use Brasso if you dash has a texture, whatever gets in the cracks will show up when it dries, also Brasso is notorious for making matte surfaces shiny. It's fine for the gauge cluster window though, just make sure to use light amounts, if you rub too hard on one spot for too long you run the risk of making that area too concave, and you might start seeing odd reflections.
