What to buy for 2.0 - 2.6 Million?
You can find yourself a nice well maintained YOM 2000 Corolla/Sprinter 110. Those are solid cars, and will remain solid for many more years to come as long as they're looked after properly. And I daresay they're quite a bit safer than any Indian car you buy at that price.
[Q] Alternator about to crap out?
12v45a, don't remember the battery make, it's got a red top with white sides. That's a good idea! Never thought the issue would be between the alternator and battery. I brought my multimeter along today, I'll check it out during lunch time.
The Shitbox is a 1993 Toyota Starlet. Still have the Axio as well. All the Pereras, Pieris' and even the De Sarams are wholly impressed by it.
tl;dr - The charging voltage is around 13.8 without any ancillaries switched on, but when the A/C, lights and fog lights are switched on, my trust Fluke shows just 12.4V. Is it time to get the alternator rebuilt? So the Shitbox's battery died on me this evening, as I was about to leave the office. Thankfully some good Samaritans first helped me push start the car, and when that failed, a set of jumper cables and a volunteer came along to give me a boost. The battery is only about 2 months old, having been replaced by the previous owner shortly before I took ownership of the car. The lights dim whenever the windows and/or the A/C is operated, but I attributed that as normal since the Vios displayed such tendencies as well. HOWEVER, this morning, the driver's window got stuck in the down position, how it had miraculously come up by the time I had finished closing the gate (it's got auto power on driver's side, and i yanked it hard a few times before getting out). Then at the office, I tried to lower the window to speak to the security uncle, but the window wouldn't go down, although I felt it struggle. I attributed to it finally have jumped a rail, and thought I'd fix it during the weekend. So imagine my surprise when I jump in, twist the key and nothing happens except for the start solenoid struggling. I immediately attributed it to the window, BECAUSE, my mum found an easter egg (which is also there in the Axio, but that car's like 2 decades newer and has more complex electronics than the first moon mission); the windows remain operable once the key is pulled out either on a timer or until the doors are opened. I attribute the sticky window and this feature (?) to the draining of the battery. So this evening, I decided to check on the battery (after driving home with no A/C and only fogs), and the battery is at 12.45v. I then proceeded to test how well the thing was charging, and 13.8v with everything shut off except for radio, 13v with A/C, and only 12.4v with everything switched on. So might this be normal for a 90's car, or is the alternator on it's last legs? Long, and pretty much useless details. but it's been a while since I've typed out a proper forum post (wife is in Mannar, so jobless till Friday).
- Llumar Window Tints- Anyone Used Them?
Post Whoring - Part 2
Quote isn't working for some reason. That's a one way street obviously. But you're right, he had to have provoked the bus driver. It's always a pushing match between us and buses in the Fort and Maradana area, and so far I've never heard of anyone being attacked like that. Which is why I always say, road rage only if you can handle the repercussions.
What is Best vehicle with the Best resale value ?
This is a fkn retarded thread and a complete waste of time.
- [[[[[[ AutoLanka.com Revamped Website - 2016 ]]]]]]]
Proton Gen 2 Vibration during highspeeds
Yes an auto, and didn't have it replaced. It didn't give me nay trouble during my 4 years of ownership.
Had to awaken this old thread, as the Shitbox heats up massively when compared to the Axio, quite apparent when the sun is on my side. Clearly automtovive glass technology has improved vastly in two decades. I hate tints, therefore need to install a transparent film that rejects heat. Any advice on what's currently available in the market? The local Carepoint wants to install tints, but I'm looking for alternatives first.
An unbalanced flywheel can cause this as well. My Vios had this issue, even racing the engine in neutral while standing still would cause small regular vibration which could be felt by the driver through the steering wheel.
It's an irreparable issue, and you should just sell the car to me for 15 laks.
- DIY steering wheel skin/cover
D.I.Y. A/C register fix
So I had had it with being unable to direct air flow from the A/C in the Starlet. Being too lazy (and cheap) to buy new vents, I decided to spend my Sunday afternoon fiddling with them. I popped them out using a long shaft flat head screw driver. Please note YMMV with your particular make of car, but I think it's safe to say this is common to the majority of 90's Toyotas. It's a very simple mechanism, each louver has a pivot point, to which is attached a spine (for lack of better term) which moves them along in unison. It's this spine bit which disintegrates with age, along with inserts on either side of the vent which mate with round nubs in the vent itself which hold it in place and allow vertical movement. My theory is that these bits are made from a low friction plastic which is more brittle and prone to aging. The fix requires a bit of patience, and some left over pieces of PET (collar inserts from new shirts in their packing work a treat). Note, my fix is extremely ghetto, and I only spent 10 minutes per register; one could easily fabricate much neater and robust pieces, but I have the patience of a 4 year old child.
Remote Key Replacement Toyota Hilux 2007
Ebay has housings. I'm looking for the silver ones for my car.
Perodua Axia
You guys understand that just because the speedometer indicates a maximum top speed, that isn't an indication of the car's capability yes? My Vios' speedo went all the way up to 200, but there's no way a 103hp car can do 200km/h.
- Autolanka Rc Build Thread
Digital Camera Photography
So over the weekend I restored my old Zenit 35mm camera, wanting to bring it back it into service. Took apart the lens, cleaned each element thoroughly, lubricated the diaphragm mechanism, focus ring etc, and also lubed the film transport mechanism in the body. The problem now is, where can I find, if at all, fresh 35mm film carts? And are there still any places that develop 35mm film?
Viva Elite Community
Sorry to bump the thread, but how does fender lining wear out? When I had my Vios, the fender liner fell on the wheel and there was a hole worn into it by the time I stopped, but the one on the opposite wheel was fine, and that was on a 10 year old car.
- Post Whoring - Part 2
Maruti Alto or Renault KWID
My shitbox i.e. Starlet was maintained quite well during the 20 years of ownership by the previous owner. It has no problems apart from broken A/C vents, 2 sticky power windows and mushy door handles.
Windows Task Scheduler Does not work
Sleep mode does not drain the battery that much I think. I have a Lenovo T450S from the office, and I always leave it sleeping, even over the weekend, and there's more than enough battery. Check the windows logs to see exactly what happens. You can look for the wake up event and follow what happens from there on.
Did you specify "run whether user is logged on or not"? if so, Utorrent may not work without a user, since settings are saved to and taken from the logged in user's profile. It's been a while since i've dabbled with windows in general as i'm mostly a *NIX user.
