Everything posted by Kavvz
KIA Sorento and Sportage
Not true, at least in my experience. I don't have any Sorento and Sportage seat-time other than driving the odd Sorento rental, so I can't help you there but the post above contrasts starkly with my experience and makes me want to speak out: I've had seat time in petrol and turbo-diesel versions of similar vehicles from the same brand, (slightly different AWD bodystyle, but same chassis underpinnings and roughly the same weight) and in my experience the petrol version is better. The diesel (which I owned and have now sold for a petrol) certainly had lots of torque and was awesome to drive but I won't say it was any better than the Petrol version of the same vehicle, nor did it have noticeably superior over-taking prowess or any noticeable performance capability over the petrol version. Even though the diesel has more torque available at a lower RPM; when passing other cars during daily driving the Petrol engine was better as after around 50-65kmph the petrol engine pulls harder (the petrol torque band is more practical for overtaking and daily driving). I don't know about you but most of my overtaking is at around 50-65kmph and the petrol engine is a better fit. Plus at highway speeds the petrol engine is quieter and has more available torque making overtaking at 100km + way more smoother in the Petrol. The only strong point of the diesel engine was the lower daily running costs (the lower cost of diesel fuel). Petrol Vs Diesel choice: Based on the fact that you drive only 500km a month if I were you: I'd get the cheaper (and in my case at least, the better) petrol version and save money. You'll be getting a better / the same SUV for cheaper. (The cheaper cost of diesel is irrelavent as you don't drive enough to make it the main criteria for this purchase and I've expained the basis of my opinion when it comes to petrol vs diesel above) 95 Octane and 92 Octane: I'm going to get slammed for this but since I'm being truthful: I pump 92 octane when I don't have access to 95 all the time despite the owner's manual explictly recommending 95 for best performance. (Its beome so common place based on my driving habits that I don't even give it a second thought now.) To the best of my understanding, using 92 octane instead of 95 should not be a debilitating factor as the knock sensor will retard timing via the ECU to compensate for the lower octane level. The performance maybe lower due to the reduced compression level but honestly I don't notice a difference. It's been about two years since I purchased the car and so far no issues at all due to switching back and forth between the two different octane levels.
Importation of a car older than 3 years old
Awesome: Will look forward to reading about it...
Read above @Virenmg MasterDon did mention that there are a couple of the Sedan sytle Rover P5B's in SL just not any 4 door coupe versions...so you might be able to find one for sale and I hope you do, its beautiful. It would certainly be great to see a restoration thread on one here if you do get your hands on one!
A M272 with 268 hp and 350 N⋅m then? Oh mama!
- ## Post Whoring - Part 3 ##
Japanese Car News
- Japanese Car News
- Importation of a car older than 3 years old
Whoa! Seriously cool ad! I was going to say the Toyota Prius doesn't look that bad, but then I saw the Honda Clarity Honda Insight and remembered how aweful the 1st Gen and 2nd Gen Prius was lol !! But really clever ad...- Importation of a car older than 3 years old
The say dogs and their owners sometimes look alike but...I guess in this case the car too now?! ?- Importation of a car older than 3 years old
Well Hello-hello and what an attention grabbing picture! I love it: Happy to see ole MasterDon rolling in style. A totally rad ride... What engine is it rocking? (Also: I didn't know you were such an influencial fellow, able to sign things and grant approvals Et al. at the CCCC? Jeez! I shall have to make a mental note to start being nicer to you...)- Importation of a car older than 3 years old
No need to replace: Some models of the Laurel did come with RB25 variants and I believe a member here has something special like that or something very similar if I remember correctly... !- Vitz 2007 KSP90 3 cyl. 1000cc engine vibration story
Nice write-up Davy: I was hoping you'd chip in with more knowledge than I could offer...? Quick question: I've heard of the water on the belt to temporarily stop it slipping trick; but didn't want to recommend it, as for the life of me I can't figuare out how it works. I mean the water or WD40 should make it slip more right? But apparently its the other way around?- ## Post Whoring - Part 3 ##
Sounds good: Ask the garage guys to take it on a test run as well if there is nothing amiss with the pulleys or belt just incase its a vacuum line (but its more likely its just the belt or one of the pulleys).- Ceylon Motor Show 2017
Hello-Hello! Well at least one good thing came out of this COVID mess: Good to see you here again!- Ceylon Motor Show 2017
The above post is a bit of spam I think...but the last motorshow held in a physical space before the world went on lockdown was I believe the 2020 Toronto Autoshow. The Geneva autoshow 2020 was then held (for the first time ever?) virtually due to concerns over COVID19.- Vitz 2007 KSP90 3 cyl. 1000cc engine vibration story
Checkout this post on a different thread as @Davy and @varotone are discussing something similar...- Vitz 2007 KSP90 3 cyl. 1000cc engine vibration story
Pretty easy for a mechanic to do: They usually just take of the belt and spin / feel each pulley for bad bearings and repalce the ones that are worn out. I'd take it to a decent mechanic and him tell them to check the serpentine belt tension and then the pulleys etc. These are all pretty basic stuff that gets looked into when you change the serperntine belt so I am supprised this is an issue if you changed the serpentine belt recently... Also: Is your car down on power by any chance?- Autolanka Funniest Moments
Ah! A bit of chicane action for you on your drive huh? All good...Adds to the fun- Vitz 2007 KSP90 3 cyl. 1000cc engine vibration story
When you accelerate only? And you showed the car to a few garages but they couldn't find anything? That's a bit weird: Its a pretty common issue to have a whining noise (or similar high pitched squealing noise) when your belt is worn or slipping only to have it go away at certain RPM's. A good mechanic would be able to very quickly sort that out for you... Quick question: Is your belt shiny on the ribbed side by any chance? As most of the above members have mentioned it does seem like a belt or pully issue but: Regardless, I wouldn't drive it till you get it fixed / diagnosed. Having a belt break or having a broken pulley is nasty. I broke my serpentine belt once because I didn't change it, and felt like an idiot when it wrecked a bunch of pulleys' in the process. The car was laid up for days till the parts were shipped (the pulleys were suprisingly expensive and hard to source!) and I got lucky that it didn't damage anything other than some pulleys, it could have been much worse...- Autolanka Funniest Moments
- OBD 1 faults check through the SRS , ABS and Tyre pressure indicators , using error codes
Wasn't me: I don't usually give out negative votes, just positive ones.- OBD 1 faults check through the SRS , ABS and Tyre pressure indicators , using error codes
@Ted I was the one who (mistakenly) suggested he use a scanner- I didn't realize the poster was asking about OB1 error codes and not OBD2 etc. My mistake and my apologies to all concerned!- OBD 1 faults check through the SRS , ABS and Tyre pressure indicators , using error codes
@Crosswind good info.? I for one am glad I read through your post above: There's lots to learn there - on many fronts! Also, good link to the previous thread: There's so many little automotive nuggets of info on Autolanka...you just need to know where to look! (Infact its quite possible that it is because of that very thread that I bought my first bluetooth OBD2 reader off ebay! )- OBD 1 faults check through the SRS , ABS and Tyre pressure indicators , using error codes
Each car (brand, model and even YOM) sometimes have different processes; but this process sounds particularly wacky and I doubt it will work. (Give it a try though, but I'll be quite suprised if it works.) Your best bet may be to just buy a cheap bluetooth OBD reader off eBay or Amazon, and connect to it via your phone through the dozen or so free apps available for andriod or apple... - Japanese Car News
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
