Kavvz
Everything posted by Kavvz
  1. Kavvz replied to MADZ's topic in The Lounge
    Yeap! Awesome site. Thanks for the link asrock. Some of them aren't too clear, but its not like you can't read it: Am totally loving that site.
  2. Kavvz replied to MADZ's topic in The Lounge
    Yeah I remember reading something in which Abdullah was in and wanted to re-read it. If I remember right they came and set up tents at Marlinspike Hall, which was pretty entertaining. Anyways many thanks and I'm off to read the Red Sea Sharks off the previous link asrock provided!
  3. Kavvz replied to MADZ's topic in The Lounge
    Thanks for the link ! Also: Do you know the first book that Emir Ben Kalish and his son Abdullah show up in? And you have a link to that too?
  4. Kavvz replied to MADZ's topic in The Lounge
    lol ! I bet Magnum rubbed one out to this clip!
  5. Well, I guess that's the air suspension kicking in and doing its thing. And it will get better with regular sidewalls, which you'll find out if you go that route when it comes to replacement tires...But congrats on the purchase either way
  6. Sure, as you wish. Personally, I think whatever it takes to make a picture look good is fine; and its the same when it comes to women. (And as I'd like to go on pretending to think I'm not shallow enough to care too much about physical beauty I shall leave it at that.)
  7. As in they swapped the RF tyres out for you?
  8. You could always tweak it / edit it later to look more blue...
  9. Kavvz replied to MADZ's topic in The Lounge
    Because he associated "Maha-nuwara" as to = Big City / Main City ? His next answer was Maha-ragama which transliterates to something along those lines too...
  10. I do, yes. And I admit when I buy a car I do pay attention to the service records as well but as long as detailed service records exist and the car is in good condition, I don't worry too much whether it was 'company maintained' or not. Especially if its something as run of the mill as a Nissan Sylphy or Teana. But you're right if you consider the typical Colombo used car buyer (its different outstation obviously) I agree, some people would put a premium on the fact that the car was exclusively maintained at the agents. However, I believe I end up with a better (and faster) service when I go to my local mechanic and follow the process as listed above. As I consider getting something better for cheaper as a win; I see little benefit in running after the dealer /agent just because at some point down the line when I sell the car; some potential buyer will be impressed because I went to the agent for every single service. I'd have a different approach if this were a new car that was under warranty; but for something that's out of warranty I'd not worry about doing all the services at the dealer as mentioned. Don't get me wrong, there are items that I'd only get done at the dealer for safety reasons or complexity reasons, but a simple oil change is not one of them.
  11. Kavvz replied to MADZ's topic in The Lounge
    How are they going to keep track of the points btw? And does speeding fall under the " නොසැලකිලිමත් ලෙස රිය පැදවීම (Reckless driving): 8 points" category?
  12. I'd rather keep the 2k and use it towards buying better tyres, better oil, or better brake pads.
  13. I agree with the above. You don't have to go to the agent for everything. For a simple service every service station including the local "under the mango tree" place is just as good. All you have to do is to buy the right oil, and the right oil filter (air filter too if needed, I usually change mine every 3rd-4th service depending on the condition) yourself and stay while the car is being serviced. The most important thing is to supervise the garage people as mentioned by two members above. If you want a good service- supervise the work and you'll have excellent results at ANY garage. A basic service is not hard to do or supervise, especially on something as awesomely robust like the Wingroad: The oil is drained, the filter is unscrewed and the car is left for another 10-15 mins with the filter and the oil cap removed for all the oil to drain. While the oil is draining out of the car ask the garage guy to check your air filter and replace it if needed (they will usually tell you whether it needs to be replaced, if so replace it. If not, carefully rewrap the air filter and save it for next time.) Then the new filter is installed (where the seals are lubricated with a bit of new engine oil) and the oil drain plug is screwed in. Fill with new oil as per the specs in the owners manual, check oil levels via the dipstick and adjust / add/ remove oil as needed. Close the oil cap when done and check that the filter and the oil drain plug are secured appropriately. Now ask the garage guy to check your radiator fluid levels, power steering fluid, brake fluid, windscreen wash fluid and do a visual inspection of the belts for fraying etc. If you want to get fancy you can ask him to check for play in the ball joints / control arms and do a visual inspection of the brake pads by looking at them. You can look underneath the car for leaking oil, hydraulic fluid, loose components, of damage caused by road debris etc. Ask the guy who worked on your car what his name is and tip him Rs 200-300. (Or more if you're a rich fart. I'm perpetually broke so that's my limit.) Its only fair to give the guy a tip; as if you followed the steps as mentioned above its likely he's done a bit more work than he usually does during a regular service oil. Thats IT. Basic service DONE.
  14. Kavvz replied to MADZ's topic in The Lounge
    Ah! Nice to know the old guard's rocking some fine motors: Kudos Gentleman!
  15. Kavvz replied to MADZ's topic in The Lounge
    Oh Thank you! And I see its parked next to some familiar looking cars! I guess the owner's on AL then?
  16. Pretty cool effort. I do have some questions though: Shouldn't the maintenance costs / service costs be less for the Prius as it will be running in EV mode most of the time with minimum wear on the ICE? Thinking along the same lines: As components such as the braking and cooling system are comparatively under less stress in the Prius; won't they probably last a bit longer and be cheaper to maintain? Or did you consider those savings negligible and discard them?
  17. Its worth a try, but it probably won't help much 'tiv' as a regular run of the mill OBD scanner will just re-confirm that there is an airbag code / that the airbag system is malfunctioning. Usually it won't even tell you which airbag system is causing the malfunction but will just throw out a generic fault code. As much as I hate to say it, this is one instance where I'd suggest a visit to the agent / dealer as they'd be able to run their diagnostic tool / more sophisticated scanner on it which would indicate exactly what is going on and which airbag or sensor needs to be replaced. Plus as the airbag system is a key safety component that can actually cause a lot of harm if it malfunctions: Generally the agents are the only garage I'd entrust this service / repair with.
  18. But won't this mean that all the car sales will increase prices across the board and end up making more profit off the stocks they currently have?
  19. Kavvz replied to MADZ's topic in The Lounge
    You speak in riddles that are too complicated for my poor brain. I looked for Rapid Rev and ended up on an old facebook page...but no worries for my search ended up at Google where they had some nice images of MB 500E's mixed in with a whole heap of (the new) Fiat 500e (e=electric) images . I must say BOTH cars looked good! lol !! However while the Fiat 500 probably drives like a golf cart, based on the online following and the write-ups, I say its safe to assume that the Mercedes 500E is way more fun!!
  20. Kavvz replied to Le Sabre's topic in NISSAN
    lol ! Yeap! And also because its "not a Toyota"
  21. Kavvz replied to Le Sabre's topic in NISSAN
    I know you mean well, so thanks for the suggestion. But no, I don't feel that would be my cup of tea. A RB25DET equipped Laurel or something built / manufactured along the same train of thought would certainly be lovely to have, but if money's tight then or they are being priced at some absurd premium, then no worries: There's lots of Sylphy's and the odd Teana to be had! And as mentioned above those cars are generally a decent option. So no need to fuss too much! And who knows I may even end up getting a Presea if the opportunity presents!
  22. Kavvz replied to MADZ's topic in The Lounge
    Could one of you gents throw up a link to it? Thanks!
  23. Kavvz replied to Le Sabre's topic in NISSAN
    Yeah I admit that'd be my first choice as well. The only draw back to it all is that its a pretty rare setup so if anything like that ever comes up for sale its going to go at a premium...
  24. Kavvz replied to Le Sabre's topic in NISSAN
    AND the points
  25. Kavvz replied to Le Sabre's topic in NISSAN
    Great suggestion iRage! And you're bang on the money for I actually did have Sylphy a 2-3 years ago- It was a great car and one that I too would recommend. Not the most exciting to drive (and not as distinct from the mainstream as the Presea) but superb as a daily driver. It proved to be super reliable and as I later found out, super safe (I literally walked away after a major crash).
