Kavvz
Everything posted by Kavvz
  1. Or perhaps this link: http://www.core77.com/blog/sustainable_design/eliodomestico_solar_household_still_by_gabriele_diamanti_20893.asp
  2. Try the video: http://vimeo.com/47238447
  3. Hi Sylvi, I'm actually really interested in solar water distillation, for my own (somewhat selfish) needs. Care to elaborate on how its done or on how you propose to do it? Do you plan on using something similar to a Eliodomestico Solar Water distiller as depicted in this linked article? They say it would cost about USD$ 50, which is only about Rs. 6500, what are your thoughts on this?
  4. Kavvz replied to MADZ's topic in The Lounge
    The last one on the left? Its a dead pedal / foot rest to rest your left foot on when its not on the clutch....
  5. It wasn't all in jest: Deionized water isn't always safe (it is if purified first, then deionized or vice versa) but distilled water made in sanitized equipment is actually okay to drink. In many parts of the world people do drink distilled water; as they don't have access to good drinking water / or because the water has a lot of dissolved organic or inorganic contaminants that are tough to filter out. Its sold in 4 gallon jugs at grocery stores and the like...there is some thought that the lack of minerals in the water can be detrimental; but in my opinion its perfectly okay for someone eating a balanced diet in a part of the world where the drinking water is generally unsafe, to drink distilled water. If this is not in keeping with what you know; then please do post up some links supporting your opinion, so err... I know what to put in my whiskey!
  6. Ah! Too bad. No worries, more for me then...
  7. Done. I like a little whiskey in my water...how do you take yours? Or am i the only one doing the drinking?
  8. Of course you can...nothing wrong in drinking distilled water now is there? Drink and be merry !! Just don't drink and drive, unless of course you were actually just drinking distilled water....
  9. and he has one of those wiper attachments that use air resistance to provide more pressure onto the wiper arm as it wipes, on the REAR wiper...
  10. Kavvz replied to MADZ's topic in The Lounge
    Is this India or Bangladesh? If its Bangladesh then there's that crackpot bangladeshi car guy Leepu or whatever who has a show on Discovery called: Chop-Shop -It could be one of his monstrosities. He doesn't seem to really care much about camber, structural rigidity, safety or weight-to-power ratio, its a weird show...
  11. Kavvz replied to MADZ's topic in The Lounge
    You're right its sitting weird. From the first picture (where the front is shot almost head on) it seems like the front two wheels have some negative camber, and its probably so for the back too?
  12. Kavvz replied to syj's topic in General
    No I got this one new, so its free of filler. I guess I just hit it at a bad angle? (Upon closer inspection there looks like there is some abrasion and scruffing as well now that I've had time to examine it). So you suggest rubbing down the edges with some 3000 grit and seeing what gives? That seems to be the consensus online as well: I guess I could give it a shot. It can only get better, as currently it sticks out like a sore thumb. (Its on the front bumper and is the length and width of three fingers) Should I start with compound and then move onto sandpaper? Online DIY suggestions leave out any mention of compound. Is this because rubbing with compound would make it worse? Or is it because its beyond the point where rubbing compound would help, where one might as well just cut to the chase and go at it with sand paper?
  13. Kavvz replied to kmcsb's topic in HONDA SRI LANKA
    Ah a Nissan! Awesome. You could always call the dealer? Or google for Nissan Sentra with the year of manufacture: I did a quick search and found a likely source for gear oil viscosity see: Bob is the oil guy!
  14. Kavvz replied to syj's topic in General
    I need some advice: I had a brief encounter with a garage wall and my front bumper came out the worse for wear. The mild (friendly almost...) contact with the wall caused the front bumper to flex and although this didn't cause any lasting distortion in the painted plastic, the clear coat cracked / fractured around the point of contact. Normally I would reach for my wet and dry compound and a clean rag, but my gut tells me this would make it worse...what do you gentleman recommend I do?
  15. Kavvz replied to kmcsb's topic in HONDA SRI LANKA
    The google gods say:
  16. Kavvz replied to kmcsb's topic in HONDA SRI LANKA
    What kind of car do you have? Why not just google the owner's manual up?
  17. Kavvz replied to kmcsb's topic in HONDA SRI LANKA
    1. Mobil is a good brand, but you also have to pay attention to the oil viscosity or thickness / consistency of the oil used. As you can see above from some of the posts on this thread the same brand of oil can be bought in different viscosities such as 10w-40 / 5w-30 etc. The higher the numbers are the thicker it is. 2. People do tend to increase the viscosity of the oil they use as the engine ages, but at 49,000Km your engine probably isn't really worn to the extent that would justify it (for cars under 100,000km I would just stick to the manufacturer specified oil viscosity as per the car owner's manual) 3. I don't think you need to replace CVT fluid at 49,000km-That seems a tad early, but there's no harm in doing so if you don't mind the expense; especially as its a good way to ensure that your transmission stays in good order. When changing ATF its important that you use the right viscosity (and a compatible brand) when changing your AT fluid. As you got your AT fluid changed at a pretty well-known place I'm assuming they got it right; but its always good to double check that type of thing yourself as well.
  18. With all due respect, there's nothing wrong with the 'Saran Mudalalis'- They are the backbone of our economy so to speak and if a civil servant wants to sell off their permit to one and make some money, so be it. Come to think of it a lot of Sri Lanka's really nice automobiles / sports cars are all owned by 'Sarang (Sarong) Mudalalis' or by individuals who are one generation removed from these so called 'Sarong Mudalalis'. Its all good: We should gather around, sing kumbaya and revel in the fact that least someone, sarong clad or otherwise, is buying cars and spinning the wheels of our economy around for us...
  19. Maybe true, but the Government will have to use funds currently in circulation to pay bonuses or finance those payments by printing money. Of the two options the only feasible avenue for a country in debt is to print money, but that comes with its own risks to the country's fiscal policy. Issuing permits is the equivalent of printing money in a slightly more controlled, restrictive manner to be spent on only one type of commodity. This serves to allow GoSL to pay its civil servants more (if you take the current value of the tax break offered by the permit or its current equivalent resale as unpaid wages) while maintaining some sort of control on the country's debt and inflation. The move to issue transferable permits is probably (in the grand scheme of things) a reflection on the higher cost of living in recent years where most of the mid-level civil servants find themselves unable to afford a new car...
  20. Kavvz replied to GTAm's topic in OTHERS
    2012 Fiat 500 Abarth
  21. Ah I see...Thanks for the explanation.
  22. How does having a passenger riding on the pillion make a difference?
  23. I guess the imports laws are tougher in SL because our standards are higher. It makes sense in a way: There's no point filling up the country with older cars that are less fuel efficient, have less advanced safety features and higher / more toxic emissions etc.
  24. Digging the gear knob...but mittens for the clutch and brake fluid reservoirs? Seriously?
