Everything posted by Kavvz
Problem With Gear Change
Yes absolutely, I don't think you need to do anything with the transmission at this stage. Just ask around for a reputable automatic transmission place in case you need to get your car seen to but really the issue seems far removed from that. The error code P0443 isn't related but when you investigated the cause what did it boil down to? Why were you getting the error code and what was done about it? [Did it boil down to a faulty fuel filler cap? Was it the solenoid valve that was the issue or did you just reset the code and did the issue not show up again?] And did this occur before or after the alternator repair? My train of thought is that it could be your electronics which caused this malfunction. Nothing needs to be done urgently as your car is now running fine but if you have time: Check that you are getting the proper voltage and that your battery is charging properly. A low voltage can cause your sensors to give improper readings which in turn cause the ECU to go into limp home mode / shut down systems / throw error codes etc. Again nothing urgent, as your car is running fine now but the above could be an explanation as to what happened.
- Post Whoring - Part 2
No that scenario isn't normal for transmission slippage. Transmission slippage is experienced as over revving before shifting (hard shifting) into the appropriate gear. And usually its something that occurs on a consistent basis. The scenario you describe doesn't seem consistent with that. Is your car model known to have electrical issues? Or issues with its sensors? And have you had any check engine lights go off in the past?
I wouldn't worry too much about it, as it happened only once. Your transmission does have a fair bit of wear if its run 160k; especially if that 160k was clocked primarily in stop and go city traffic. A bit of slippage, or hesitation due to worn transmission gears might be expected. As this has happened only once, I'd just monitor it. I would however start asking around for a good automatic transmission mechanic from the other members in incase things change and you need to take your car in for a repair / rebuild. As 'mazdaspeed' states, automatic transmissions are a bit complex; and taking it to a reputable place will save you a lot of hassle.
Do you drive a vehicle with a lot of mileage on the transmission? If so, it could be that its slipping at hotter temperatures which as your mechanic states is a sign of a worn transmission.
Old Cars In Highway
Well wiki states that some of the Merc's from that production year were capable of doing 200 kmph; so its theoretically possible. I guess the car's been well maintained to still be able to hit those speeds. However I can't help cringe, at the thought of doing those kinds of speeds in an older car with no modern crumple zones, airbags or seat belts!
Old Cars In Highway
Whoa! You mean 110 KMPH right? Eitherway, at those speeds you need seat belts; not to comply with any laws that may or may not be enforced, but for the safety of the driver and passengers.
Place To Get Toyo Tires
If the comparison is between Toyo Teo Plus and Hankook Optimo K415 I'd get the Toyo's. But that's just my pick of the two based on my daily driving needs. 1 . I suggest you figure out what type of driving environment you're going to experience most of the time (eg. highway, wet, dirt / gravel side roads, low speed urban roads etc.) and buy an appropriate tyre. (eg. Some tires are designed to be better on the highway and others vs other that are designed for side roads etc.) After you figure out which category / type of tire best fits your driving needs look through tyre sites for reviews on those products to help you decide which one is best for your needs. (For example: The Tyo's are rated high as a good overall highway tire. If that's the type of driving you're going to experience: Great you're on the right track; but if you're driving at relatively slower speeds up in Ratnapura or Kandy 70%-80% of the time then that won't help you much, and you should look at something else with a different tread design. 2. If you just want to rely on per reviews via autolanka's members then I suggest you list what type of driving conditions you'd be experiencing as well for a more accurate recommendation / comparison. That may not be completely accurate (No offence CARBON B4). Based on my experience: Hankook has a wide range of offerings at multiple price points, and you've got to be careful what you buy as the lower end of their range isn't that great. (In this case its doesn't really apply as the Hankook tire referenced is from their mid to high range, but still...)
Using A Carnet & Left Hand Drive
Ouch. That's going to be one expensive vacation. Considering if you decided to vacation in Europe or the US you'd be able to get a rental, have it insured and get unlimited km's etc. for a fraction of that price easily...
I'd say a SUV or a 4x4 is great for Sri Lankan roads and outstation driving. Even in Colombo I'd rather be in an SUV/ truck despite it being a bit unwieldy in traffic. The only draw-back I see is the expense and paperwork involved in getting the vehicle into SL and potential hassle during breakdowns / maintenance. How would you lease? Can you get a lease for a month or two? If so let me know for I've been looking into getting a SUV/ pickup next time I'm in SL but anything getting other than a small car (Suzuki Alto) is super expensive. SUV rental prices are higher than in North America which is okay if the level of service is the same or better, but its not. The vehicles are older and based on my experience last time I rented in SL the onus is on the consumer to get things done. (To be fair once I complained and brought the situation to the notice of the the owners of the rental company they went out of their way to help out and fix things, but I'm not looking forward to subjecting myself to the whole thing again...)
Christmas 2011.
- Happy Birthday Mani And Sifaan!
- Colombo Road Race
you mean Dilantha...or does he have a brother who races too?- Colombo Road Race
You could get a black cover for it? I was flirting with getting one, but then read that the white paint was supposed to be done up that way so as to minimize heat absorption: Sticking a black neoprene cover over the thing would pretty much negate that; but on the plus side it does make the lens look like a cheapo knock off which is great when toting it around in public and while on vacation...- What's The Fastest You Have Gone?
lol!! That's going to be harsh on the tyres of the next guy coming along!! Talking of tyres I wonder whether the E01 is going to have maintenance staff drive along it every morning clearing it of such debris? (Other than loose car body parts there's bound to be rubber scraps from shredded tyres strewn all over the place as well as discarded garbage etc. on the highway after a bit isn't there?)- A/t Or M/t Tyres In Sl
How that come about? And does this setup cause more tyre noise / vibration than usual?- Vin Number Toyota Prius
What?? And you BOUGHT the car from them? Sounds like a dodgy outfit to me as the VIN number needs to stay with the car till it gets scrapped. I'd never buy a car that had its VIN removed / tampered with. You should check whether you can report this to the Sri Lankan Consumer Affairs Authority and do so at the earliest opportunity. Anyways to answer your question: The VIN is listed on multiple places, if its unavailable via the most accessible spot at the base of the windscreen then check for a sticker located on the driver's jamb (the lower part of the B-pillar, that is visible when you open the driver's door. If its not there on either of those spots then check: - On the door jamb/door post of the passenger - On the engine itself (machined pad on front of engine) - On the car's firewall - In the left-hand inner wheel arch - On the steering wheel/steering column - On the radiator support bracket- Happy Birthday Supra Natural!!! :) :)
- Express-Way Updates
I didn't get this one Velocity: You want to get yourself another Subaru for its handling prowess in rain / wet conditions? Or did you mean you want a Subaru 'cos it would be fun to have, now that there's a highway to drive it on?- Post Whoring - Part 2
As reported by Jalopnik: A single miscalculation from a Ferrari driver earlier today in Japan led to a chain reaction that ultimately wrecked or destroyed 14 vehicles including eight Ferraris, three Mercedes, a Lamborghini, a Skyline, and a Prius that was in the right place at the wrong time.- Underlights
lol !! (Your profile picture always makes me yearn for a cold one, and now all the neon on that car's making me HUNGRY! I'm going to need a pint of Guinness and a Kottu if I hang around this thread any longer!! )- Dslr Prices
I agree on the lens part, kit lenses are all but redundant. I wish I bought the 500D body only (Thank goodness I didn't get the bundled kit that offered the 300mm lens along with the 18-55mm!!). But am not sure your purchase should be driven by megapixels. However as 'Watchmen' points out perhaps the enhanced sensor options makes the 550D a worth while purchase... - Happy Birthday Mani And Sifaan!
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
