Everything posted by YALA
Body Lift Nissan D21 Pickup
Did you try with ironman or mot*rc*de. either way whats your requirement a body lift wont give you the ground clearance a suspension lift would give you
Buying A Vehicle Clocked Over 250,000Kms
not sure about the other two brand but nissan engine is built tough previous pickup had done 500,000+ when i solt it and the current one has done 324,000. so like crosswind mentioned just make sure the maintenance is done on time and a sanity check on the vehicle when you test it out
Roh*na M*t*rs Radiator Repairs With Aluminium Tank
well why cant you find a recon one for the same make instead of going for a aluminum or a chinese one. Quick walk in pachikawaththa tomorrow you should be able to find a decent specimen by lunch and if you have the time head out to buhari for a biriyani also
Buyig Nissan D21
Two types of bodies 1) Basic square shape 88 to 92 2) Embossed body - 1992 upwards from what i remember Both body types came with basic option or the full option. Avoid new body fitted specimens unless you are ok with the risk associated with buying such a vehicle. Unless taken care of well you are bound to see corrosion or shoddy jobs done to make it look clean. Chassis where the rear differential is set should be checked for cracks and the rest of any rust. Also check for water leaks from the front windscreen usually this problem would lead to rusted floor boards. Underneath the door sills and the doors are also prone for rust. Stick to the TD27 engine or the TD27T earlier models carried the TD23 and TD25 engines. Usually the engine and gearbox is rock solid my last d21 with a SD25 engine had done 525,000 never missed a beat or failed an emission test. Make sure the oil is flushed and filters changed at the usual intervals and it should run fine. Do the basic test when testing the engine and you should be fine. Not quite thorough in checking the turbo so ill leave it for some one else who knows about it. Check the radiator to see if gaskets need replacing and the quality of oil and when it was last changed. You should be able to get a decent idea of the engine condition. Also check if the power steering is whining when making a full turn might be that the pump needs to be replaced or the owner had replaced the hoses with lower grade quality.
Where I Can Buy Used Japan Tyres
doubt any are from japan but you can try the place in mount next to ioc. but most are retreaded and cut into to make grooves you will spend an awfull amount of time on roads with flat and hopefully that will be the worst experience you will have to suffer. buy a set of brand new tires and maintain them properly you should be easily able to get good life span and or millage. If you look at it from a cost aspect id bet you anything you would have spend more on replacing used tires instead of getting a brand new set one time.
- What's The Best Vehicle I Could Buy For $25,000 Permit
4X4 Recovery Kills Two
yep this was in negombo from what i remember. strangely on 4WD action aussie had posted on fb today that one of the shows on tv will be showing a towing gone wrong and two people dieing wonder if its the same.
- Land Rover Defender 110 Full Restoration
Are Air Coolers Any Good ?
got one at home its utterly useless so dont bother better off with an actual aircon.
- Place To Buy Automatic Gearbox
What To Buy Between 3M-3.5M
Your requirements are so vague that options are from Toyotas up to alfas and jaguars in terms of cars and a similar range of suv`s. i think the forum can help you out better if you let in on more details or specific criteria
The Check Engine Sign (Malfunction Indicator Lamp)
also some vehicles are very sensitive to the battery if your having a weak or dying battery the car tends to give out random error codes. If you reset the codes and the error lights pops up again on starting the car up then you definetly have a cause to be checked on
- 12 replies
- check engine
- malfunction
- indicator
- light
Cvt Oil Changes On A Honda Fit Hybrid Rs
abu simplest answer would be to check the owners manual it will have a section on maintenance which will describe each service you need to do at each internval i.e - 5k, 10k, 15k etc go with that and give allowance for the driving and environment conditions
Interesting Or Usefull Android Games/apps
I have seen a obd scanner with most used vehicle manufactures included in the list while its definitely useful i haven't been courageous enough to plug it into the car and run a scan
How Important Is The Thermostat?
Also anytime a bass says to take off something that its not really necessary i always tell him there is a reason behind that item been put there in the first place so if its removed due to non functioning then replace it
ah been haggling about this topic for the last week..my problem was quite opposite the cab never came up to the half mark in 3 years of owning it except on the highway and recently been passing the half mark after a short 6k mark, checked everything except for a radiator block and thermo which i left for this weekend. Any clue on how to check if the thermo works fine ? like cold start will you see coolant circulating when you pop the radiator cap or do i need to take it apart and do a test.
Need Advice On Importing Baby Monitoring System Through Ebay, Do We Need To Get Any Approval?
I just collected mine yesterday all i did was send it to a family friend flying down from Uk and she carried it without ever been questioned by anyone.
Best Sedan Car For 1.3 Lks
cant say fb14 is bullet proof but our family car is one old steady and reliable girl since 95 and still is and the old girl just keeps going..my father is so engrossed with it that he wouldnt even think for a split second on replacing. true we had replaced most running parts any car that has been running for the last 19 years would need to do so. i also suppose it boils down to who has been using it previously since we got it back in 95 its been with the family and taken care of it as part of the family. My dad used it from inception and to date, i used it for my weekend and late night runs until i got one of my own so did my brother after me and now its used between my younger brother and my dad.
Automobile Association Of Ceylon
I think its valid for one year but the catch is its valid for one month from the date of entry to a country..atleast that's the impression the US folks gave me. though that was mentioned i used it for 6 months at a stretch without a problem for two years.
Ever Seen A Wp Ea Number Plate?
my double cab number totals to 13 never had a problem running but like someone mentioned think they were only issued to gvt agencies initially....think the lj79 is still manufactured in some parts of the world and i think your referring to the blue landcruisers that have popped up suddenly since last november
Best Car To Buy Between 2.5-3.0 Million?
lets save the hassle of this thread running into multiple pages and go with supra corrolla 121 for you.
Importing A Car From Uk For Spare Parts.
find a place that had already broken down the parts and has it in one place when you order the whole lot the price can be negotiated for far less than buying each item individually at different times. There will definitely be a tax on this side of clearing maybe upto 100% of the value.
Best Mid Size Rv/suv
1) And crocs Also get some breather lines soughted out once you get the vehicle help keep the differentials and gearbox clean...take off the factory door cards you might spoil them pretty good in your wading...
Wouldnt the toyota surf fall within your budget its toyota reliable for your offroad adventures plus its a decent suv for city use...
Car Audio
component is the way to go if you are the type demanding for high quality together with an amp and equalizer should do. the general factor should be the type of music you listen to some speakers are more attuned to that sought of music polk audio, mtx, sound ordance and infinity are some of the brands you can experiment or atleast review online about. dont forget the installation part. clean installation results in cleaner sound. outcomes are limitless you only need to be aware of your budget and how much of a sound freak you are
