Everything posted by Mani
Catalytic Converter
That warning is for overheating cat. Main reason for overheating the cat is that the car running rich. The un-burnt fuel is burning up in the cat and causing it to overheat. There could be many issues that can cause this but the main culprit could be your O2 sensor or the coolant temp sensor. BTW. There are no O2 sensors on the intake AFAIK. The sensor on the intake is the air temp sensor. Generally there will be two O2 sensors. One before and one after the cat. The one before is what you need to check and make sure that it's sending the proper signal to the ECU. Also check your coolant temperature sensor as if this sensor is bad, the ECU will think the engine is cold and add more fuel thus causing it to run rich. Running rich will kill your engine performance, create carbon issues and foul your O2 and eventually burn up your cat.
What's This Engine Bay?
Datsun 510 with AM turbo.
Madz..this Is A Small Suggestion
Don't know about the rest of you boys but I'm laughing my ass off here. This is good stuff. How's the weather in SL these days? Hot and humid as usual?
- Post Whoring - Part 2
- Gran Turismo 5 Hd
Release date is on Nov 2nd. Get your pre-orders in.- New To Forum
I'm going to go on a limb and say he is from Michigan USA but born in Kandy. Welcome.- What's This Engine Bay?
Man I suck donkey cutlets at this. That is all.- Gtr Arrives In Sri Lanka
Do I read this right? RS. 24.5 mil is ~ $245k US! no?- Gtr Arrives In Sri Lanka
- Disconnecting The Battery Frequently
Don, You have it exactly right. However, it will only go into learning mode if you start the car. You may also notice the car running a bit rough for few minutes until it 'learns'. No damage to the ECU by doing this as far as I know.- Gtr Arrives In Sri Lanka
Not to be an ass but why is everyone asking for pictures of this white GTR? Pictures of a white, or any color, trim, spec, are dime a dozen on the net. As far as I know they are not making a special edition for SL.- Adding An Extran Radiator Fan Pros & Cons
Adding an additional fan will not solve your problem. Fans are only good for up to about 40 mph [~65 kmh]. Anything beyond that speed, the incoming rush of air is more than what the fans can push/pull. That said, the environment conditions in Japan will have no affect of how your car is built. They are all built to operate in a variety of climate conditions from freezing to extreme heat. All cars are made to be able to handle the temperature variances. Further, Sri Lanka is not that much hotter than Japan during summer. I think your best bet is to root cause the issue and address it rather than adding a fan. First and foremost, make sure the obvious things are not malfunctioning. i.e. temp gauge, thermostat, water pump in good condition with no damage to the bearing, clogged radiator fins etc... Your problem most likely is caused by water flow problem. Also inspect the radiator fins from the outside and make sure that they are not overly bent or clogged with foreign debris blocking the air from passing through the radiator. Good luck.- What's This Engine Bay?
You may be thinking of the 180SX.- Quick Trivia Part 2
- :: Autolanka Forum New Memberships ::
MADZ man, I have no place to go for my daily porn fix since you made it more complicated for the boys to post links here- Post Whoring - Part 2
- What's The Fastest You Have Gone?
2010 Prius pagged at 186 kmh.- Plz Help Me To Find I Need To Find The Interior Dome Light Door Switches
Did you have the switches tested to make sure? One switch I can understand but all of them to go out is highly unlikely.- Gran Turismo 5 Hd
Can't wait for this game to finally come out. Racing with friends should be easy with this version compared to Prologue. Damage on with all the classic tracks, what could be better. Dilon, Master Don, AL race league is definitely in order.- Hppy Birthday Damn_it !!
