Crosswind
Top Contributors
  1. Yawwnnnnnnnnnn.... got better things to do than arguing about this... And if what you are saying here is true.... don't u think u got bigger things to worry about, than temperature coefficient of petrol and the savings u get out of pumping early in the morning etc. etc. ? So if u think u are going to save by following the 'best practices' given in this mail, please go ahead. After all, its neither my car nor my petrol.
  2. Do read the post by Peri just above yours. That should explain it. If it's still incomprehensible, I'll explain it in simple English. Edit: I got numbers mixed up in my original post and it was corrected earlier
  3. Some people will believe anything, if it's in writing! Some of these 'valid' points (3 and 1) will help you save a few cents. While points 4 and 2 are utter rubbish.
  4. My recommendation is Ford Focus (made in Spain) if u are ok with a manual. It was around that price when I checked last time. Ford Fiesta (Thailand) is also within your budget. Try calling Future Automobiles 011 551 1111 Does this look suit your criteria for good looks?
  5. Will have to stop at KY because KZ is already allocated to those three wheeled chinese junkpiles.
  6. The predecessor of this model didn't have a grille (or shell as we call it). When this model came out, people started calling it the 'shell model' and although its successors also had the front grille, the 'shell model' name is now stuck with this model.
  7. Do I see a subtle message from Cali to JD there?
  8. does that give u an indication about the experience of forum members with Duet?
  9. My whole point is if u had a quarter tank of petrol ('first line') and even if the guys in the shed pumped zilch, still it should take you more than 40 km. Hell... 4 litres ought to take u more than 40km and that's like 600 rupees of petrol! U may have developed an issue with the airflow sensor or something so u might wanna get it checked. (Have never used an FB14 so I'm just making a guess here).
  10. u mean to say that their cheating is so good, they can even fool your car's fuel indicator?? Get off it dude... and get your car checked.
  11. There was an ad in the paper last week and Panda was quoted 1.59 Million. Check out Micro Cars website for details Viva with ABS and Airbags would be around 26. Check out Unimo Enterprises website for details. There's a long waitlist for Viva though.
  12. 1. $20,000 = 2.6 Million not 2.2 MIllion 2. Are chinese or Malaysian Products ok? Kelisa, Viva, Panda, MX7, Savvy (not sure about this one), Ford Figo (assembled in India) 3. Not sure about Chinese vehicles but generally this is achievable 4. Panda has all these features
  13. It may be an issue with the camber but if the wheel alignment people reassured you, then I would trust them more than your mechanic. Did you go to a computerized wheel alignment place? Their system would detect it easily. On the other hand, your mechanic can only 'suspect' it. I can recommend the two joints in Malay Street or the one in Hyde Park Corner if you really want to check if the camber is out. I could think of worn out shocks also as a reason but then I suspect your mechanic would have looked at it already and even if he didn't, the wheel alignment guys might also alert u if so. Was the car involved in any serious frontal accident? That may also have an effect on this problem.
  14. This topic has been discussed quite a few times in the forum. DO a search if u want to see all options and their pros and cons. To cut a long story short, let's just say that the best options u got are Corolla DX Wagon and VW Beetle.
  15. @fatjoe- r u sure it wasnt a 600 with an added zero to the badge?
  16. Is that a car with climate control (touch ac)? If it is a 4wd version without climate control, i would pay around 18 or less. There is a perception that 4wd cars have a low market value. The reasons could the lower fuel economy owing to tbe weight of the car even if 4wd is switched off. Also eif something goes wrong with the 4wd mechanism, repairing could be a nightmare. A black cruze with matching red and black seats with all options including climate controller and no 4wd should go for over 19 these days. PM me if u need any more help
  17. Starlets are pretty robust vehicles irrespective of whether auto or manual. There are no major known issues with auto boxes but u need to find a one which is working properly, considering the age. When you say Starlet, I presume you are talking about EP91s. Only trouble I see is they go for around 1.5million these days, which is rather expensive for cars of that type and age.
  18. Crosswind replied to evilbear8's topic in BMW
    Your question is fair enough. I don't know if any forum members own an F10 528. You can ring the local BM agent and see if u can get an authoritative response. For best results, pretend to be a potential customer. +94 - 11 - 2 875 666
  19. Friendly advice to you, before you are taken to the cleaners, May I suggest thinking twice before you post something in Autolanka forums. Neither of these vehicles are available in Diesel and within OP's budget here in Sri Lanka.
  20. Idle Air Control Valve
  21. I had the same problem in the Punto which I owned for a while. Ironically the problem popping up whenever the car was taken to Wheels Lanka for service and became alright on the next day or so. I assumed that Wheels Lanka guys are probably spraying water or kerosene on a sensor which makes it act weird. Does this problem happen when it rains? If so, its a good indication of a sensor being over exposed to water. In any case, like VVTi said, it needs professional attention and I would trust Indika far more than Wheels Lanka to diagnose and fix this fault.
  22. Now what was that old adage about wrestling with pigs? May I suggest:
  23. If thats the case, did you clean the IACV during your tune up?
  24. I was with MBSL earlier. Yes they are cheap. They will undercut competitors but there are two problems 1. Getting claims from them isn't really easy, unless u know someone inside. If you like, I can introduce you to the agent who handled my vehicle (PM me if you like). Agent had to intervene to get my claim sorted out. 2. The parent company (MBSL) is trying to offload MBSL insurance to some other company. It could go either way - could get in to better hands or bad hands so I don't know how it would affect you as a customer. However,If I were you, I would keep that also in mind when trying to give them business. ~55000 Premium for 3 MIllion is still high. If you negotiate hard or have some contact inside, you should be able to get it done for 50 or below.
  25. For me it looks like there's a problem with the cooling system of the engine. The cause may be a faulty thermostat valve or a radiator fan. That's why it becomes ok when the AC is on. Keep an eye on the engine temperature indicator when the car stalls. If the indicator is not working, you may need to get that sorted out first. Check if the fan speed is ok when the AC is off.
