Everything posted by Sumiya
Quick Trivia Part 2
Hi Tango you came closure but not the exact this is Volvo 700 series(760) thanks regards sumith
Quick Trivia Part 2
Hi Guys Ok Another hint European Car thanks regards sumith
Quick Trivia Part 2
Hi Tango OK ... this is not Japanese enough right ? thanks regards sumith
Quick Trivia Part 2
Hi Don Nope machan thanks regards sumith
Quick Trivia Part 2
Hi Big D Nope Machan , I was expecting this answer but this is not trad sunny thanks regards sumith
Quick Trivia Part 2
Hi Guys ok i will take the chance again will see how this goes thanks regards sumith
Happy Birthday Mrm !!!!!
Hi MRM Many happy returns of the day thanks regards sumith
Gunners Supercross, 2010, Minneriya
Hi Ripper About 4 Hrs time Hope you are going through kandy road must be watchful of early cops usually at the week end i start 2.30 am to nawalapitiya still meet cops waiting to collect early tea and breakfast thanks regards sumith
Sohc Vs Dohc
Hi Guys I guess the main purpose of the DOHC is to increase the valve per cylinder since sohc lack of space to have more valves per cylinder,most modern engines almost most of them are dohc or either vtec, i think the old days car manufactures achieved power by increasing no of cylinders, now a days it is achieved through increasing valve per cylinder since the lack of space in engine bay instead of tunneling a big engine like v6 or v8 etc. thanks regards sumith
Radiator Core - Row 3
Hi Nishan Just check with these people might be able to buy on a cheaper price Radiator House 011-2699230 Radiator Auto Tech 011-2593888 Dolphin Auto Radiators 011-2433151 thanks regards sumith
Sohc Vs Dohc
Hi Mate in simply Both are better on some fact that is like SOHC : - simple and less costly and less power DOHC : - Complex costly and more power only think is that whether you would like more power and more cost or less power and less costs http://paultan.org/2005/06/22/sohc-vs-dohc-valvetrains/ this explains a bit technical review about them , hope it might help thanks regards sumith
Exchange Of Car
Hi Mate Yes , take Peri as an example if you can't afford daily cost park it home and use Shuttle service probably you get lot of luxury coaches to that area from Colombo and back to Colombo too, thanks regards sumith
Convert N 16 Manual Transmission To Auto
Hi Mate why don't you call agent ans ask them about the cost first, then you get an idea what it costs actually if you don't do with agent any way this is not a good move i would say you are going fulfill an old saying (if i am correct) "INGURU DELA MIRIS GATHTHA WAGE" thanks regards sumith
What's This Engine Bay?
Correct saw a car few days ago 2.6 V6 Omega thanks regards sumith
Convert Manual To Auto
Hi Mate the First of all i want to ask you why do you want to go for auto from manual ? there is no valid reason rather than (you can't balance the Clutch properly or you are lazy to operate manual)convert auto to manual will be possible you might be able to find a auto box for a reasonable price around 30-40K(not sure about this price), but you may need some cut and bud work to tunneling auto gear box that will be more expensive than your auto gear box prices sometimes thanks regards sumith
Help ! Suzuki Japanese Wagon R Speedometer
Hi Dude Most Probably your tire size or profile is out as don said,before you calibarate it check what is the factory specified Tyre size and profile for your car, is it matching with existing Tyres ? if so adjust it once and see how it reads , if it is not change speedo to match existing tyre and profile thanks Regards sumith
Low Vibrations After Driving Too Fast!
Hi BiG D Basically yes, But Old cars having mechanical ignition timing requires manual set up for the crank timing and ignition timing basically with crank pulley and distributor. most of the after market ECU allows user defined value to be set for ignition timing as required by the user.those will work on presets ECU values. thanks Regards sumith
Hi Big D it Might increase the engine performance a bit, means Firing take place earlier than it is usually before piston reach to it's TDC. if it is too advanced you feel difficult to start too and also engine tends to knock a bit on tappet .and also increase engine wear.. thanks regards sumith
Welcome New Look
Hi Guys At once Quote has a problem but not always looks great and cool thanks regards sumith
Hi Guys here is another one to go Uploaded with ImageShack.us thanks Regards sumith
Look At This Wheelie For A Change....
Hi Machan You have to do it yourself and see , to have a real change too thanks regards sumith
Need A Diagnosis Center - Electrical
Hi Ajith Here is Upul Auto Electricals no try it and see 0773737677 i doubt they will come to your place,but they get car carrier too, if you want by any chance they will bring it there and will do it for you thanks Regards sumith
Any Body Expierienced With These Bikes ?
Hi Peri Yes thanks Regards sumith
Hi Guys Thanks for reply guys, today bought a TVS Scooty streak(new Model) Black color one for about 138K + full Insurance and RMV fee it is about 150K Battery was fully dead could not operate Starter motor , thought of running few KMs will solve the problem i came to office with it today still no good ,call the fellow he said to bring it back tomorrow to make the starter motor and give Commonly good nothing bad has a good pulling power too. could only fill 450 Rs petrol, i was dam scared of cops since it is not registered.managed to come to collpetty have to go home safe too with cops thanks regards sumith
Car For Wedding Hire
Hi Supra Yes , Correct this is very famous car for wedding hires now, have seen a lot in everywhere, not even Colombo outstations too known person is there having white color 121, which is not available most of the days,he is renting it only for wedding .no any other hires , thanks regards sumith
