H.C
Everything posted by H.C
  1. Nice way to start the Sunday morning and really enjoyed reading your story!. All the very best to rest of the project!
  2. H.C replied to Komisiripala's topic in HONDA SRI LANKA
    Ayyo these garge fellows!
  3. H.C replied to Komisiripala's topic in HONDA SRI LANKA
    Me too machan!.
  4. Mr.Sylvi, what are the vehicles that you have fixed those Hid units. Im running with So called cheap Hids for past 2years and Im really satisfied with them . Mind you Im travelling to my work place during night hours, half of the month and fog or rain is so common there. I think what really matter is the type of the headlights that you fixing the hid . I think it's illegal to fix them to normal headlights (without projector lens) as light will scatter and blind the on coming traffic. In rain or fog those high k hids will give poor visibility.
  5. Ordered 3000k pair separately (7 $). You have to order the correct type of ballast (H3/H4, etc) and k figure is your choice.
  6. Received the ballasts via regular post (free shipping) within 2 week .package was really small as they were slim ballasts. (13 $ per pair)
  7. H.C replied to MADZ's topic in The Lounge
    No offense , but ideal name sould be Ponnasari!
  8. Make sure to clean the radiator as well. ( In these old radiators you cant get good results by flushing it. Need to remove the top and clean the lines separately).
  9. ordered 3000k bulbs and ballasts seperately from HK. will let you know the results soon.
  10. Ive faced the similar situation in my car sometime back (d15b3-M/T). As most suggested clean the radiator first. (If your radiator is badly clogged , simple flushing wont help). check the simple things first and if everything is working correctly, blown head gasket is also a possibility! .(In my case had to put a new gasket and ultimately replaced the radiator as well. )
  11. Happy birthday mate!
  12. H.C replied to kmcsb's topic in HONDA SRI LANKA
    Yep, he should have mention it here after the tune up . ( I don't know whether he thought its not need to mention here as he has received an expert opnion about it)
  13. H.C replied to kmcsb's topic in HONDA SRI LANKA
    Well, he has send me a message with those details and guess what, that particular guru's name has mentioned in this thread.! (Mr.Sylvy's post)
  14. H.C replied to kmcsb's topic in HONDA SRI LANKA
    Is it possible to have these symptoms due to faulty IACV. (According to Kmscb , last tune up guru has told him that IACV is not functioning and no need to correct it!)
  15. H.C replied to Komisiripala's topic in HONDA SRI LANKA
    Me too machan!. Hopefully drought at the CSTH car park will be over within next month!
  16. Check the battery ground . Sometimes lose ground connection can cause similar symptoms .
  17. Happy birthday mate!
  18. As uditha said this is most probably due to blocked drainage of the windscreen drainage pathway. Due to this water get collected in the gutter like space just below the windscreen and water get into the passenger compartment via Air recirculation door opening. Remove the plastic cover below the windscreen and clean the drainage line. Inspect the gutter for evidence of rust and do necessary preventive measures.
  19. H.C replied to kmcsb's topic in HONDA SRI LANKA
    Its not a D15B3 Rumesh. Its sort of a JDM single carb setup with IACV , Oxygen sensor and probably an ECU too. (Ive seen this engine bay once)
  20. H.C replied to MasterDon's topic in News & Updates
    No worries mate!.
  21. Check 2013 pioneer line up. They have some feature packed double din units starting from 250 $ range. If you can get one through a friend or relative, it will be the cheapest way. Good luck.
  22. As MD said use normal shipping method like USPS for those small stuff.For me, most of the items reached to home adress including somewhat big packages like 4ngk irradium plugs, OEM cup holder for Eg8,glow gauge cluster, etc.
  23. H.C replied to Komisiripala's topic in HONDA SRI LANKA
    Nice colour machan!. Is this heat resistant type spray paint or sikkens?
  24. H.C replied to MasterDon's topic in News & Updates
    Supra, is there a possibility to change atleast one retelecast time to 10pm.
