Everything posted by Uditha88
Hyundai Accent
Wonder why you sold Presea. If you remain in the same price range, you could have kept it..
Nissan Fb 14 - Auto Gear Issue
Do u normally change oil by exchange machine or by hand? Anyway if sound come when gears change, there should be a transmission issue.
- Automatic Shifting And Related Engine Rev?
- Toyota Recalls
- A-Pillar Disturbs Visibility When Cornering
Hi all, How many of you have noticed/ suffer from that car's A-Pillar blocks your visibility when taking corners? Drove few cars including 121, & felt that & it was a pain. Think that well designed cars, specially sport cars never do this. Put any other models you experienced with the issue. This is what I refer for your reference.
Terios Starting Delay
Let me tell for the 3rd time, "Nothing to be done" mmmm.. seriously. only thing that comes to my mind that i didn't try but was under solution (as far as I remember) when I do hard net searching for hours was changing spark plug wires. Also for that, before change, u knw u can check for continuty by multimeter or something. But even no breaks, i would say possible to get failed under heat. If all fails, use to live with it as better than spend more n more......
- Nissan N 16
- Nissan N 16
Itz a answer less issue as had done for everything tended to culprit. have to get used to. Still starts & brings you where ever you want.... hold the ignation key bit time definitely will start the car... no longer living with it....
Very Very Same issue(believe started after SL fuel case) which was unable to find till the end of story. But got used to it as nothing like that happens :-) http://forum.autolanka.com/topic/11926-hard-to-start/
Allion Or Corolla Or Civic
Ayyio Salli Retarded Nilantha: Don't worry about 2C engine. city driving it will do 12kml with AC and 17kmpl outstation with AC if Manual gear one. i can sure that. Me: I too got to know from a friend that diesel, manual 141 had given them amazingly good km/l results in an outstation tour he participated. The Stig: Any diesel would give roughly the same figures, the e46 gets around 13 in city and about 17 in long distance Me: Just note that I've ZERO knowledge abt this Engine & fuel figure stated by friend was 19-20 Km/L..... chan5: highly unlikely , in colombo
Pls read post no 24
Hey are you ok? Should I repeat my 1st post?? "....amazingly good km/l results in an outstation...." What "colombo" u talking about ???
- Sound When Ac On
Autolanka Funniest Moments
- Starting Of Car
Is it automatic transmission? If so, U try this. Keeping the key at "ON", shift the transmission leaver to "R" and then shift back to "P" Then check it starts with no issue. If so it's a minor issue that transmission leaver doesn't signal properly that it is in "P". (As far as I know this signal sends via a switch installed on leaver area) Anyway try this & tell the results.- Axio.is It A Really Good Car?
Top 0 to 100km/h Accelarators Nissan There!- Axio.is It A Really Good Car?
Definitely better than 121 but not as much as 141 for me.- Axio.is It A Really Good Car?
+ No RPM Meter even [but don't know whether available in highest grades]- Tire Size
- Seeking Advices To Select A Car
More than Vios though...- Buy A Car For 22 - 24 Lakhs
2002-3 Nissan N16 EX Saloon Automatic with "K" Number !!!!! - Starting Of Car
