Uditha88
Everything posted by Uditha88
  1. 1. Select the car 2 buy 2. Deposit money to bank account given by car's owner Or hand over him cash (If deposit, give him bank slip) 3. Take the car transfer form signed by him, car registration book(Strongly recommend that registration had been done to the person who selling it to you), Revenue Licence, car key & car. 4. Get a letter signed that you paid for car & he sold it to you. 5. Drive home. Do re-registration to your name. All the very best with your new Car!!
  2. Mates, How to find true market value of a used car in Sri Lanka. As you all know, 2nd hand car market in Sri Lanka is highly out-of-standards. Even prices in websites like autolanka.com rules the entire car market. So is there any formula kinda thing that we can come up so that we can get a rough idea of the 2nd hand market value of a particular car model/ made based on YOM etc. How helpful it would be having such an organization? Is this happening in other countries? Expecting your valuable ideas......
  3. Uditha88 replied to dpk's topic in General Automotive
    we can as long as battery is healthy. Ignition uses battery power. Ignition uses only battery power. when engine started, all electrical needs are satisfied by alternator & battery getting charged.
  4. You mean RPM stays same when AC On/OFF ?? Then issue. Like Ripper mentioned, should increase with AC ON.
  5. For some more info click
  6. Breather Hose
  7. Hmm... I extremely doubt the quality of the fuel in Sri Lanka...
  8. All Fit Area are not Japanese AFAIK. There are Thailands..
  9. Does that sound come when you turn the steering and move?
  10. 1. High RPM to Low RPM change in cool start(1st Start of the day) is very normal. (RPM comes normal when engine become hot) 2. RPM increment when shift from a gear to Neutral is normal. 3. Slight increase of RPM when AC is ON is Correct. So the issue you got is opposite to the above points, the very 1st treatment that a mechanic/ Engineer should give should be Tune-up with specially cleaning TB.
  11. Using G* for 2+ years no issues..... Every brand will need to have proper water level maintenance & avoid misuse...
  12. For 1.5M :-o
  13. Removing Sump or hose from transmission to Radiator bottom cooling line....
  14. 1. Tune & make car mechanically good. Be a economical driver 2. Carb cleaning, Plug clean/replace, Air Filter/Fuel Filter replacing. Engine oil condition 3. I know only EFI tune-up places in these area. Don't know they carry out carb.. 4. Depends on the model. But for most in Idle, 700, With AC 800, In gear 600 5. Ya it's a factor(not a Big) . Back pressure is a performance factor. 6. Not fuel saver liquid but fuel system cleaners. Most are used by EFI system to clean even injectors but you may use "wu**h" 7. maximum consumption is 0 Km/L [A owner will help you on this] 8. A place @ Malabe-Athurugiriya road befor Arangala juction I think. Check to see...
  15. http://forum.autolanka.com/index.php?/topic/7033-carb-specialist-mechanic/page__hl__%2Bcarb+%2Btune__fromsearch__1
  16. And this site has Old Japanese Demestic Nissans .... http://www.get-u.com/CATALOG/01_sedan.html
  17. Hi, You know that we can shift automatic transmission lever when just ignition "ON" & engine is not actually started. Usages: * when engine dies when car in "D" * To check the revers light working fine So question is, is this bad or no issue. (but it seems that manufacture should allow this as cases like car dies in "D" occurs)
  18. Don't know how many of you already watched this...
  19. Gear box is worn. Will have to rebuild or replace.
  20. Listed in most economical cars. Petrol Honda Fit claims to an excellent car, handling, economy, demand. Same applicable for Hybrid version
  21. This all applicable if you feel vibration with RPM drops. (which is a miss). Not just vibrations. An electric miss may happen due to bad plug wires as broken, damaged wires will disturb proper current flow.
  22. This is what normally doing. you will have to bring metal mount to a place where thing called "rubber bush gahanawa" is done.
