Everything posted by Uditha88
Carina 211 (Si My Road)
Pressing "Manual" -> Starting gear will be 2nd Pressing "Power" -> Car will be in sporty mode. More performance. Less economy. Just try those. No harm...
Mzda Axela Dvd Setup
Did u check in "DN C** Au***" ?
Engine Rpm
It should go to the end... But never rev this much after just starting ur car. It's bad. Do it after engine has run & hot. btw. Did u try in "N" ?
Honda Fit Ground Clearance
I had a friend who got this car & no complaints regarding ground clearance though it's not much comfortable though excellent on fuel economy. U can increase the ground clearance using spaces in suspension system.
Hard To Start
Many Thanks Mr. Chulanga, Let me follow ur advices & will surely give an update. Thanks again...
Hard To Start
ShintaroX, So then, won't this indicate bad readings when checking with "Fuel Pressure Regulator" ? It gave correct readings. ???
Hard To Start
Stig, Thanking you, 1-> 1996, Nissan GA15 EFI 1.5L engine, Battery age is 1 year & 8 months. (Checked voltage, alternator etc. & all fine) 2-> This is the explanation mate. what else u want more clearly? Ya. this seems to happen if drive the car sometime, stop it, let it parked about 30 minutes or few hours. Eg. go office, park the car, try starting evening Morning starting happens just fine almost all the time. but there were some times it was hard as the same too....
Hard To Start
ShintroX, Thanking you, 1-> Ya. I hear "hmmmm..." sound of the fuel pump when key "ON" and I always as a practice, start the car after that initial fuel pump working. I used to do so. (And also tried key "ON" "OFF" few times & crank. It didn't work) 2-> Engine tries to start. But it hesitates like no fuel. (Not like what u experience when battery is dead & say starter motor is bad)
Hard Starting
http://forum.autolanka.com/Index.php?/topic/11926-hard-to-start/
Hard To Start
Hi Friends, Car(EFI, Automatic) is hard to start after drive & sitting for about hours in day time. If we off & try to start after these hard startings, it starts just fine. I say "daytime" because it's parked in evening & try starting next morning, it starts first time. Running condition is perfectly fine & the following things got checked & no issues. 1. Battery voltage & charging system. 2. Cleaned & oiled the starter motor. 3. No error codes after scanning. 4. Correct fuel pressure. 5. Plugs & wires are ok. 6. Cleaned injectors, iacv, TB Please give a help
Belt 100Cc
Definitely. Due to the excellent "weight-power" ratios & matching things like that. And u might need light acceleration to move the thing...
Auto Gear Issue - Fb 15
If 1,2 &3rd gears changes without an issue, it's not something related to ATF. And also oil condition cannot be visually checked. You better test whether u have "ON" overdrive. (4th gear) If ON, u might have gear box issue or overdrive circuit related issue.
Power Steerin Oil Type
Nissan suggests Dextron III type of oil. Doesn't matter the brand name is it's Dex III. This is same as ATF. Brand name doesn't matter a lot but always Better ....
Water Mixes With Gear Box
Hi, In for automatic transmission cars, there is a cooling pipe bottom of the radiator to cool the transmission gear oil. If there's any damage to that pipe, it causes coolant to mix with transmission oil. This makes transmission oil a pink color milky look & also coolant will get milky look. Solution: 1. Remove coolant & fix the pipe bottom of the radiator. 2. Remove all transmission oil. 3. Flush cooling system as well as Transmission (Cooling system u can use water. But for transmission, u have to use oil which will be costly but can't help (Use cheaper oil brands)) 4. After coolant & trans oil get clean, then only fill both for final. That is fill radiator with coolant & transmission with ur loving good quality oil. Good Luck
- Belt 100Cc
Nissan Tiida Latio - Fuel Efficiency And Other Info
* Test when trip is >= 200 Km * Use same filling station * Drive ur normal way without thinking that "I'm about to get a reading"
Hard To Start
Hi Harshan, I have been doing this as a practice for quite long time now. Big help if you guys can tell me a good place that I can get the Fuel Pump, Pressure regulator checked & do the necessary fixes. (Better a place which has good EFI Knowledge & instruments) and preferbly around Malabe, Koswatta, Battaramulla. [Pls message me if naming in public not possible] Many Thanks!
Hard To Start
Hi Harshan, I got to know that in order to test a faulty fuel pump, do OFF & ON the ignition key several times & then crank. If it works, culprit is the fuel pump. So I did try this already. But it didn't make any change. Still it was hard to start like the same. So I decided that nothing wrong with the fuel pump. Please tell whether I'm correct or not
Hard To Start
Hi Harshan, The thing is once the fuel pressure was also checked & nothing suspected found..
Hard To Start
Friends, I got Starter Motor serviced. According to the technician, it has no fault @all. He said it's in original condition & never serviced too. All bushes were all right. So he just cleaned carbon deposits & oiled it & fit again. After that, no change in my original issue. Please look the following patterns I have recognized. 1. Car is hard to start after it sits "engine OFF" for a period of time. 2. It starts when I hold the key in engine "ON" position for a little more time. (about 3-4 seconds) 3. If I try to start after few minutes of a successful start, it starts in 1st try without any issue. Please help !
How To Clean Yellow Oxidized Head Lights?
Only "Signal" ?? haha Ya it's good. & regular washing with Shampoo will keep lights clean...
Hard To Start
Great Help Crosswind ! Sure. I'll follow ur advice..
Hard To Start
GeNex 1 -> No "TAK" noise. Engine tries to crank 2 -> Ya. It does crank
Hard To Start
Hmm well is it? Thanks evergreen. I'll see the luck in it too.. Any other ideas friends?
Hard To Start
Crosswind. No I have not. Should I? But you might see that i stated above it starts very fine sometimes like no issue @all. So is it logical us to assume starter motor is culprit? Advice??
