Everything posted by Sylvi
Parking In The Sun - Can It Shatter Windscreen ?
Members, Windshield Glasses Crack normally when there is a Crack ( Star or Chip) on same and the cracked legs of the crack can extend due to weather conditions like heat of the mid day or you drive to a rain after driving under hot sun shine that is because sudden changes of the temperature of the Windshield glass this happens only on safety glasses. I have never come across due to Air pressure build inside of the car parking under hot sun conditions. Normally when you park under hot sun during 10.00 AM to 3.00 PM in old cars where there is corrosion under the bonded end of the glass a line will start and than can extend to the center of the Windshield glass. All Windshield glasses are made with safety Glasses and fitted on to Automobiles by reputed manufactures in the Automobile industry. I have come across some Chinese New Vehicle Imports with Tempered glasses and few Japanese new exports to Srilanka 15 years ago had Tempered glasses and Srilankan replacements. Due to the cost of Safety glasses. Above is my Experience for last twenty two Years in Windshield glasses. Wijesinghe.
Most Expensive Cars In The World
How Morgan cars are made http://ritemail.blogspot.com:80/2010/09/ho...ut-of-wood.html Wijesinghe.
Starting A Car Which Is Already Started
Master Don, You are correct. MG TC some had If I am not mistaken the Starting handle but they all had Lucas Starter motors if the Engine timing is little too advanced you will get a back fire from the engine then the cranking handle will turn to anti clock which effect will come to your Wrist my father have had number of times treated for that problem he had told me in 1920S to 1940S Magneto Ignition engine cars which is no more even Motor cycles had the same problem on the kick start peddle it used to throw your leg out of the peddle when old BSA and most Magneto motorcycles had. Wijesinghe.
Top gear, If you take off the Starter Motor and have the starting handle you can have a less capacity (Ampere) Battery as requirement only for other Electrical equipment in the Vehicle can be 20 Ampere Battery when engine is running the Alternator will compensate the drain of the battery charging will be regulated by the Electronic regulator for the current demand of the vehicle. Yes it is feasible good for the health Cranking the engine but today every thing is made for the comfort of the driver. I cannot comment about the Environment clean matter. I understand what you pointing at my spelling mistake I have told in my previous posts I am very fast typist due to that I make mistakes. LIVER is a part of the human body. I wanted was to say LEVER on that post. Insted of E I have typed I on that post. I appreciate your post. Instead of humiliating me for my spelling mistake like in the past by one member you interpreted my mistake in Biological language which is very great of you. Thank you for pin pointing that mistake of mine. I only want to share my Knowledge. Wijesinghe.
harshansenadhir, Starter motor engages only at the starting point of the engine it is never full time drive with the engine. There was 1930 model Morris Cowley which had full time operating Dynamo motor one unit which works on a chain drive. when battery current is inter connected to that unit the engine starts when engine starts up battery get charged with that unit acts as a Dynamo. I remember in 1970s we had some small motor cycle and a three wheeler Italian build with the above said Dynamo and starter motor in one unit single Cylinder engine. Wijesinghe
Master Don, Removing the starter motor only reduce the weight of same that will save some fuel. Fuel saving for starter motor weight I think it is negligible. Then you have to use the stating handle to start the car engine or push start the car. Like good old day cars had the engine cranking handle in front of the car in build with a spring to push back as soon as the car starts like present day the two wheel tractor has De compression of engine with a small handle on the engine head operator has to turn number of revolutions and release the Engine De compression liver to start the engine This above said De compression liver allows the engine to turn without compression build up on the Cylinders. Wijesinghe
harshansenadhir, You are correct Lucas and Delco Remy Ignition switches some had this option there was a lock on the switch in build so that lock will lock the starting position when you operate the starter once next time you have to completely off the switch to operate the starter motor. There were no replacements for the said switches as they were assembled by a different party on order to lock the starting position switch cam. Wijesinghe.
Sifaan, There is no need to operate the starter motor when engine is running but some Automobile engine idling is not noticeable that is the reason the drivers try to start already running engine. Some new cars has this method from the ECU disabling the starter motor when the engine is running. All high powered Generator Diesel Engines had this method from 1970S one day every utility Automobile Engines will have this system what you question. It is a very simple system you have a speed censer not to activate starter motor switch when the engine is running on its power then you cannot operate the starter. As all ways speed of idling engine is little higher than before you operate the starter motor. Wijesinghe.
Be Aware Of Vehicle Sellers In Sl
Members, I went there (A*W) personally to order 1 Vehicle for my self the sales staff informed me that I have to deposit Rs, 250000.00 and delivery date they do not promise earliest is December mid or end. I cannot understand their attitude to a prospective buyer. They want our money first to do any thing. Wijesinghe
What Is A Free Wheeling Engine Means???
Malaka, Free wheeling means according to my knowledge is when you release accelerator pedal and neutral the gear engine runs but the vehicle will move on the road without engaging on to the engine via gear box It is you drive and neutral the gear then the car will move with out the engine power vehicle speed will become slow and finally will come to stop the moment of the vehicle. for example home garden grass cutter has this method in the final drive when you accelerate the grass cutter engine the rotary cutter blade will rotate but when you decelerate the blade will rotate for a little time and stop. I remember old DKW cars had this system it was a option on them if you order you can get this system fixed from the factory then there will be a fuel saving on your driving but it is not recommended for hill country driving because when you come down on a hill there is no connection with the engine via gear box. Then you have to depend on the brakes to control the speed of the Vehicle on the down hill. Wijesinghe
Motor Bike Restrictions
Shehan_WCC, In your post you mention that.our fellow presidents son's have some of the fastest bikes in Srilanka including a 2009 honda cbr 1000rr. If one Srilankan is permitted to use high powered motor cycle I presume others too can import and use them. Wijesinghe.
- Beware Of Car Sale Scams
Members, Police have some BMW bikes with high capacity If police suspect that Vehicle is not to import restrictions they get a Court order and send same to German tech at Ratmalana with some authority from RMV for a clarification.I know personally one importers Vehicle was tested in that manner. Customs authorities had some problem with a leading importer few months back and all those vehicles was returned by a Court order without any Penalty. When Importer filed a case against Customs. Wijesinghe
Spare Parts By Post / Duty Reduction ?
Sifaan, If you hand carry any thing the items is for personal use you can declare some good Customs officer will believe you and will not levy duty it all depends on the person who carry's same as it is coming from UK if you get any one to carry not much of suspicion at the Air port. There are regular carriers the are friendly with officers can get a low duty rate. I have helped to carry others parcels when I was a regular visitor to US and Japan I always did not have my full baggage allowance so they used to put them on my extra left allowable their extra baggage I did that only for known Srilankans. Whom I know they will not carry contraband stuff. I suggest to get through EMS air parcel post normal way not express then the parcel will be at Colombo post office almost close to Lake House they will send you a notification then go their you can do the need full to declare that is for your personal use but export party will declare the actual cost if a friend can export same as declaring low cost you will be able to get a low duty. I get my parcels from reputed exporters they will never declare low amounts as it is against their Business etiquette. I pay correct duty through the Currier service and it is delivered to doorstep of mine. Wijesinghe.
Sifaan, To Air lift 1/2 Kg I paid US$ 59.7 To UPS three days back. Wijesinghe
A Volkswagen Beetle That Runs On Methane
Idnet, Thank you for the information there is one person in Srilanka trying to compress Methane gas. He wanted some advice how to compress to store in to a gas cylinder and run his motor cycle He had spend around Rupees 100000.00 building a big methane tank it is producing gas at present with Hay for filling the tank. Using for cooking and lighting and will run his motor cycle in near future. Very Talented Technician. Wijesinghe.
## Ward Place, Colombo - ## Scam
Chooti Putha, Yes I wrote I knows him and had lot of dealings with him with no issues he is a through gent by all means did Automobile import Business for last twenty years or more. Person can be a honorable person in the past but due to unavoidable circumstances this is an a unfortunate incident which had led his name Tarnished. He in past I know personally had got down thousands of Vehicles for Government Permit holders he used to Advertise lot in the papers S/O D/N before H/A was published his main operating office was Nawala Araliya gardens and his Brother in law used to be his personal assistant. If he did unwanted type of business most previous Government officers would have fix him up long time ago. My first post to this thread I advised to the Thread starter go and do a complain of the the matter to CID at Colombo 00600 and Consumer protection Authority For redress. He is Known to me as a Through gent once a high government officer out of Colombo came to me for some advise about a part for his personal Vehicle. He was short of funds I rang Mr. #### because he had directed him to me and got his authorization and cashed a Cheque to that officer to buy the part from Panchigawatha. If he had done a mistake he must be punished by law and authorities are there to inquire the matter and do the Justice People can change in matter of minutes for their whims and fancy's. There is no one perfect in this world. Wijesinghe.
Members of the forum I received this note by E mail this morning 11Th August. A Volkswagen Beetle that runs on methane produced from human waste in sewage sludge has been unveiled in Bristol. Bath-based Green fuel Company converted the ‘bug’ so it could run on biogas generated at the Bristol sewage treatment works in Avonmouth. With support from the South West Regional Development Agency, GENeco, a Wessex Water-owned company, imported specialist equipment to purify biomethane in a way that doesn’t affect the vehicle performance. If both tanks were filled up with methane the car would travel for 250 miles The bio-gas is enough to power a conventional two-litre VW Beetle convertible to 114mph. According to GENeco, waste flushed down the toilets of just 70 homes in Bristol is enough to power the ‘Bio-Bug’ for a year, based on an annual mileage of 10,000 miles. Countries including India and China use compressed natural gas (CNG) to power vehicles and a number of companies in the UK are now using CNG mainly to fuel buses and commercial vehicles. In Sweden, more than 11,500 vehicles already run on bio methane produced from sewage plants. But using bio-gas from sewage sludge is yet to take off in the UK despite a significant amount being produced everyday at sewage plants around the country. In order to produce methane from sewage, it first must be treated with anaerobic digestion, a process in which microorganisms - in the absence of oxygen - break down biodegradable material to produce methane. In an extra step to purify the methane, the GENeco engineers used specialist equipment to strip carbon dioxide from the bio-gas. The methane is stored in two pressurized storage tanks in the boot of the Bio-Bug vehicle. If both tanks were filled up with methane the car would be able to travel for 250 miles. Ingram Legge, director at Green fuel Company, which converted the car, said filling it up with methane is fairly simple. ‘The storage tanks are pressurized to about 200 bar and you connect the vehicle up and it basically equalizes pressure so the tanks in the vehicle are 200 bar with methane in them,’ he explained. ‘There’s no pump in effect, which is quite clever.’ The vehicle still depends on petrol but only for a moment after starting the engine. Once the engine’s temperature reaches 30ºC, the petrol injectors shut down and the methane ones open up. If methane runs out, the car will switch back to running on petrol. While the Bio-Bug is being touted as environmentally friendly, Legge acknowledged that does not mean the vehicle produces no emissions. ‘It’s producing CO2 out the tailpipe but it’s important to know where that CO2 is coming from,’ he said. ‘Of course it’s not coming from yesterday’s CO2 buried in the ground as oil, it’s today’s CO2 from waste. So it’s very environmentally friendly.’ Mohammed Saddiq, GENeco’s general manager, said he was confident that methane from sewage sludge could be used as an alternative energy source and was an innovative way of powering company vehicles. He added: ‘Our site at Avonmouth has been producing bio-gas for many years, which we use to generate electricity to power the site and export to the National Grid. ‘With surplus gas available, we wanted to put it to good use in a sustainable and efficient way. ‘We decided to power a vehicle on the gas offering a sustainable alternative to using fossil fuels that we so heavily rely on in the UK. ‘If you were to drive the car, you wouldn’t know it was powered by bio-gas as it performs just like any conventional car. It is probably the most sustainable car around.’
- Post Whoring - Part 2
Sir, I appreciate your Bold writing how this thread started and ended up. Wijesinghe.
Members of the forum, like to have your comments about the issue. One member alerting not to patronize Mr. ##### advertisement. I only wrote of what I know about him. Members please understand this is automobile forum we should not fight each other. Automobile forums are there to share the knowledge in a friendly way. Some members of the forum was negative when I wrote Mr. #### is a good pay master. I think most members do not like my Writing to this forum because I am more practical. I request members to tell me direct to stop writing instead of abusing me like one member I had to complain his writing to the authority of the forum. In the reason past also he abused me he is proud of his number of posts I don't think he can time a Engine properly. Wijesinghe.
Members of the forum, Please note I only mentioned what I know about him. His assistant was thrown out from a car sales I do not know the reason he is related to a well known Cricketer. If any person go through my post I told the victim to complain the matter to CID. I told the facts of what I know of Mr.####### He used to work for a Finance company as a cashier later the assistant to the owner of that Finance company. Then he started his own imports. In Nawala By the road side Araliya Gardens in a big house. The victim must complain the matter to CID. Wijesinghe.
