Everything posted by Sylvi
Buying a new smartphone
Crosswind, Try Metropolitan Computers (Pvt) Limited.Sony Ericson has at their show rooms,within your budget. Sony Ericsson Live with Walkman List Price - Rs.34, 990.00 Discounted price – Rs.32, 900.00 Contact number 4622471. for specifications log into the web page given below. http://www.gsmarena.com/sony_ericsson_live_with_walkman-4111.php I am not advertising this only for your information as there was a negative reply to my earlier post. Which I mentioned the mobile market facts. Sylvi Wijesinghe.
Ever Heard Bio-Diesel?
'rayman', You post is correct mixing petrol to Diesel. When a Diesel engine is difficult to start some mechanics mix 50% Petrol with Diesel and pour about 30 ML To the air intake operate the starter motor then engine fires at once with a very heavy knock. Once I drove a Diesel truck from North to Colombo long years ago when the Diesel fuel pump failed using small gravity feed to the intake Kerosine. I know one Diesel engine lorry ran for many years with kerosine. Every15 days the owner pump Diesel just to lubricate the Injector pump. later he had to replace the complete injector pump with a new one as it was beyond repair. I post above just to share my knowledge, not Members to do what I have mentioned on the post. Sylvi Wijesinghe.
Croswind, According to a well known mobile importing company, today fastest selling is Samsung mobile.. There are Chinese mobiles in Pettah mobile dealers, same as Samsung for less than Rs:7500.00 Touch screen,who import them through the regular Singapore travelers. One of my workers use Chinese phone with touch screen for last 8 months without any trouble which he bought for Rs: 6000.00. Sylvi Wijesinghe.
Members, Most long distance buses on our roads drivers add Gasoline 5 liters for full tank of Diesel, this practice was there for long time. I spoke to one Bus owner he informed me that he has not faced any problems for the engine. It is some thing like adding Acetone or Xylene to Gasoline engines. Sylvi Wijesinghe.
- Import A Kdh200 Dx
About Import Vehical Parts To Srilanka
'imalone', If it is in commercial Quantities, there are formalities you have to full fill. Yes you can import open a Letter of Credit from a bank with necessary invoices, from the agent who is going to ship them. You have to get an income tax clearance (Tin) number to clear the stuff when the shipment arrives to Colombo port. The shipment clearing will have to be handled by a clearing agent. If it is for personal use one unit at a time small parcels can import by sending A Telegraphic Transfer (TT).It is call wire transfer in west. Or a credit card, Can import through a courier, the charges you can pay in Srilanka they will deliver to your door step courier charges will be high. If you import by normal Air Cargo. You have to go to GPO to pay duty and clear the parcel. Sylvi Wijesinghe.
Pressure Gun
kushon, I think you are looking for high pressure washer they are available Chinese made. If it for your home use they are good. 11500.00 Rupees. 90 bar. Some shops in Panchikawathe have 120 bars for 14000.00 Rupees. Same made. Contact K.B.N. Machinery they do their imports directly so their selling prices are cheaper than others. They have industrial use H/P washers from 350000.00. Rupees on words. Their contact number is 2389667. I use for last five years or more ,Chinese bought less than the present cost. Chinese motors are good. Only two pressure hoses were changed. There are little bigger ones with 120 bar available in other shops you will have to walk round Panchikawathe road, on right hand side same where A.C.Paul is situated. Thudave brother’s Kacher show room at Elvitagala mawatha also has cost will be high. Contact numbers are 2369630-2 originally imported from Germany. Now it is made under licensed manufactures on other Asian countries. Sylvi Wijesinghe.
Battery Maintenance
Harshansenadhir, (1)Self starter motor will draw more than 100 amps depending on their manufacture. (2)In that case commercial vehicle batteries are fitted not in the engine bay they are fitted on the side of motor vehicle.Resistance is related to distance of 5 feet copper connectivity wire is negligible (3)The weakest battery will fail first to my knowledge. (3) I was in a well known Battery manufacture plant years ago. No two batteries are manufactured to same level they used to put out batteries in mass scale. Sylvi Wijesinghe.
- Disk Brake Wheels Are Dragging
Battery Maintenance
Members. I post under with my experience and my opinion in Auto and industrial electrical industry for many years. Changing positions of 24 volts DC batteries in Automobiles, for every month it is not a necessity. Like Automobile tire rotation. I have never had the experience of Automobiles 24 volts Dc battery system in other countries also changing the position of batteries. Because I have handled many type of commercial vehicles Electrical systems. We have tippers with electric Hydraulic tipping. They too work with 24 Volts DC. There are forklifts working inside store houses. They normally work on 48 DC some designs use 72 DC have number of batteries can be 12 volts DC or 2 volt DC batteries with very high amperage connected in series. DC battery banks are used. Supply mostly for Communication equipment fitted in relay stations emergency patient treatment rooms and EVs. They have separate Battery charging systems designed for the requirement. For example 10 KV 230 AC Volts .High capacity UPS inverters which are connected directly on line have input to Dc Batteries and the output load always connected to load. Battery banks inverters; Input voltage is DC 240/230. So that Inverter supplies continue 230 Volts AC. 365 days of the year they are connected 24 hours. Battery bank has 12 Batteries’ 200 or more Ampere batteries. They never change from the position of batteries until one battery fails. They are regularly monitored every month very carefully load tested every cell and the S/G. Above said batteries undergo very high discharge and high charging cycles. Sylvi Wijesinghe.
Diesel Container
Cyclist, Plastic cans are sold for Rs: 5.00 in most Restaurants and hotels. Sylvi Wijesinghe.
harshansenadhir, It is regrettable to note your post to state by you I explained my experience in a vehicle I had and on my next post I have endorse you are correct ( knowing he gives those makabass type advises). When parts are not available to jack up the vehicle till new parts come. No motorists want to keep a vehicle idling wants to run the vehicle some innovative way. In my vehicle brake fluid was not returning back due to some parts of tandem master cylinder failure. So I was compelled to do that modification. When I removed the brake line caring fluid to Tandem cylinder end brake pads came back,after care full checking I removed the said cylinder. I have been in my entire life doing technical studies in many parts of the world. Started in UK 1960, JAPAN 1975, and ENDED UP IN USA 1988 to 1992 PIONEERING A AUTOMOBILE SRVICE TO SRILANKA. Sylvi Wijesinghe.
Tax Marked Down For The New Budget???
GTMAm, That tax really affected the small Maruti cars, Sylvi Wijesinghe.
harshansenadhir, You are correct as what on your post. I agree to your post, had a problem on mine then washers were not available for same. Only alternative to remove that and connect directly. I used to carry heavy loads, never drive more than 50 Kilometers with heavy loads. Sylvi Wijesinghe
Members, I came across on the web about bio diesel. http://www.biodiesel.com/U.pdf Sylvi Wijesinghe.
Battery Maintenance
Nishan.dj Log into following web pages. If you have any questions please Email me. [email protected]> <[email protected] http://autoexpert.hu...ery-Maintenance http://www.green-trust.org/battfaq.htm. Sylvi Wijesinghe. Sylvi Wijesinghe.
Yes mine was also petrol engine 2 vans. Check for tandem master cylinder do you have on your van. You say no block of brake fluid on the front hoses. So you check if the oil returns back to the cylinders. That is one reason to brake pads get wasted if calipers are ok. Examine the caliper fittings are clean so that pistons will go back easily. Sylvi Wijesinghe.
Members, Motor Vehicles duty gave very high revenue to the government. Due to increase of duty on cars, Vans, and the dollar. Government has lost that revenue considerably. Don’t think Potatoes increased tax revenue can come close to revenue that government got from motor vehicles. As (chan5) post says. Tax cut is unlikely with the current economic state of the country. Sylvi Wijesinghe.
Datsun Sunny Excellent
'mazda-svt', Go to Minuwangoda you will find the model what you want. Sylvi Wijesinghe
Hyundai Santafe
Kinghtowl, A relative of mine bought a 2008 Deisel Santafe for 5.8 million. Three months ago. I went and had a drive on that vehicle the original owner had all service records done only 49000 Kilometers fitted with 4 new tires. He paid the transfer fee too. I think that price is reasonable. Sylvi Wijesinghe.
Honda Fit Ge6 Xenon Lamp
LolithaB, Dealers sell motor vehicle HID Kits in one set of two bulbs. Any way try with a dealer mentioned by (KELUM_WJ) you will find their telephone numbers on the (Hit Add) today. They have advertised the HID KITS. they do the fitting also.If you fail to get a single bulb,You can try there are single HID KIT bulb dealers who sell for motor cycles. HID single bulb can buy from them. Sylvi Wijesinghe.
Diesel Container
TechHater, You can safely carry diesel in plastic cans. 5 Or 20 liter. Plastic cans. They do not explode Diesel do not get much vaporized like petrol. Do not fill up to the top of the can. Carry Plastic filling funnel also. Please note there are enough fuel filling stations around the Island at present, you will not be standard any where due to lack of fuel. Fill your tank whenever you see the meter is ½ empty on the nearest town when you are travelling. I always carry 4 liters of Petrol in my vehicle in a 5 liter can with a filling funnel. Because I always use petrol vehicles. Have helped number of motorists, in good old days when there were not much of filling stations like today. During last five decades. I have helped standard vehicles my out station, carrier for last 5 decades. Who were standard on the high way? Once I remember towing a vehicle which did not have Diesel standard on the way to Batti to Mahaoya filling station. Sylvi Wijesinghe
Rules To Double U.s. Fuel Economy To 54.5 Mpg By 2024
Quiktar77, Very good information latest from US.Thanks for same. Sylvi Wijesinghe.
Rpm
Kmcsb, Instead of removing the existing meter board you can buy a separate RPM (Tachometer) and get same fitted to your car. I think the meter on your post picture is little bigger than the one what you have. Separate RPM Meters are available at Motorchrome accessories dealer at Bary brook place Colombo 2 and get it wired to your ECU. By an auto electrician. Sylvi Wijesinghe.
Edc Injection Pump
SAMI, You contact mr. dilantha karagala0777320871 and inform him that your problem. Inform that you have the copy of testing Web link, print out copies of the link. For your reference I give you the link to do the testing. http://www.ase.com/getattachment/Tests/ASE-Certification-Tests/Test-Series/Electronic-Diesel-Engine-Diagnosis-Specialist-Cert/ASE_2010_L2_Composite_Vehicle.pdf.aspx I spoke to him he told me he knows about same he was busy on a job he told me to cotathim in the night. Sylvi Wijesinghe.
