Sylvi
Everything posted by Sylvi
  1. 'charminda_wadu3854', Glad to have you on this forum with experience by fitting a double A/C to your Jeep. With valuable advice. 4DR5 engine produce about 75 to 80 HP on normal running speed. I don't think that will be a burden on the 4DR5 Engine. When you off the A/C compressor do you feel extra power from the engine and your speed goes up. When you drive and you want to overtake another vehicle on a clear road. I too off my A/C if I want extra power to overtake another vehicle. Like to have your comment. Your advice to insulate from heat cover the soft top is a very good advice. I have fitted an A/C to a small maruti omni van which has three cylinders and very much low engine capacity of 790 CC. With a fan on the inside to give cooling effect to rear passengers. I have painted white to reflect the heat of the van top and insulated very well with two Mac-foil heat insulation. Even engine compartment is insulated again with Mac-foil, and all inside too pasted with heat treatment Mac-foil. Sylvi Wijesinghe.
  2. 'Kavvz', To my knowledge ECU has a tolerance of voltage. I think it is from 9 Volts DC to 15 Volts DC. Any member who reads this if I am incorrect please correct. Sylvi Wijesinghe.
  3. 'Kavvz, Your post is totally correct. Sylvi Wijesinghe.
  4. 'Kavvz', As far as I know if the alternator is working correctly there cannot be any connection with any other components of the vehicle. He says he had changed a new IC regulator. I think if "JayZ's" do get his voltage checked up it is better. Alternator Voltage should be under 14.5 Volts DC. If voltage is more than that then there can be problems prop up in the electrical system. I am not very good at new ECU systems. Alternators yes can do from A to Z. That was my early subject for few decades. Sylvi Wijesinghe.
  5. 'rangerover', Srilanka no emergency law at percent. But still there are very few check points. If you are stopped at a check point the request from the law officers, where do you come and what is your destination. This is a democratic country I don't think they can Question that Question. I have complained this Question to DIG, he contacted me and told me say any thing you like. Some officers are drunk smelling of liquor. I have some interest in Hambanthota I travel once a month there, due to new EO1 not much of problems with Police only at Galle to Hambanthota the police men wants us to get down and show our documents to them. I never get down I get them to come and examine the documents of my vehicle. This is srilanka we are first class citizens of a (third class) developing country. Cannot expect the curtsey from a first class country Police in our country. Sylvi Wijesinghe.
  6. I Wish A/L members that your all dreams comes True.. *HAPPY NEW YEAR 2012* Sylvi Wijesinghe.
  7. 'The Don', Thank you for your post. I agree that distilled water is expensive I buy in large 4 gallon cans so the cost is not that much As I use a new vehicle I examine the Radiator periodically. I have still done only 7650 kM on my vehicle. After that incident I did not want to take a chance for that reson I use coolant diluted with distilled water. I have municipal water supply. Use same for coocking and washing eatebles. I live on a commercial building so every lessee is given seperate tube well water supply with a seperate pump. For drinking every one takes big water bottles from a commen supplier more than 50 big bottles are dilivered to us every 6 days. Happy new year to you and your family. Sylvi Wijesinghe.
  8. 'JayZ, I don't think your alternator is having any issue. Re: pO443. please read following link. http://www.obd-codes.com/p0443 Sylvi Wijesinghe.
  9. TRINITY, Happy to hear your experience on that trip. Cannot forget Miniace because he gave the best link to find out any destination. Must thank him for posting same to A/L Forum. Best wishes for the coming new year. Sylvi Wijesinghe.
  10. Members, As for my experience you have to use coolant in all new automobiles, If you dilute then have to use distilled water. Once I used tube well water and my radiator got blocked totally. had to remove one end and use thin strip of steel blade to clean the entire Radiator. I have number of tube wells in my garden and they all have water with plenty of corrosive effect and chemicals which will block radiators. I did it my self because I have the facility to do most automobile repairs. Sylvi Wijesinghe.
  11. 'Ripper', You are perfectly correct. I have refused number of times and end up at cop station. But the OIC listen to my story and let me go I don't stop at that next morning I complain by fax to DIG number of times I have given statements at DIG's Office. Srilanka Police today is dancing to the tune of Politicians and big time racketeers. Sylvi Wijesinghe.
  12. 'terrabytetango', Your post,what I understand to close all window shutters at once. Is that correct. I have come across Vehicles which has that facility. that control switch can operate single window separately or all windows at the same time. Above mentioned function do you require. Sylvi Wijesinghe.
  13. 'LancerL', 2 Members( The Don & Ripper) had answered your Question. I too have to mention what both members advised to you. Hope your Mechanic will do a good Job. Sylvi Wijesinghe.
  14. 'nilupa.uok', If you cannot get a original switch only, do as under. You can buy a switch 10 amps at 1st cross street colombo 11, will be under 100.00 Rupees. Center off two way and modify fix same to your door panel. If you want any technical help please do contact me. Sylvi Wijesinghe.
  15. 'DAY', You post a reply to a very old post did you read the date before you post the reply. Sylvi Wijesinghe.
  16. Sylvi replied to Nishan Rodrigo's topic in OTHERS
    'Sithira', Give more details, do you get any answer from the self starter when the switch is turned on. What made you to change a new Battery?. Did you have any problems on the self starter motor before. Sylvi Wijesinghe.
  17. 'thenuwara', About Isuzu Gemini was discussed in this forum some time back. Out of first two cars which was imported by CWE one car was bought and used by a planter friend of mine. He used same for total 200000, Kilometers without any problem.If you can get one of them it is a good vehicle to use. Sylvi Wijesinghe.
  18. 'Chaturathi', Glad to hear your experience on EO1and how helpful the emergency service. Sylvi Wijesinghe.
  19. Sylvi replied to jami's topic in General
    'Jami' lot of members had given their experiences, If you are capable get to the point mentioned by the members by yourself. Then try out do a care full examination of contacts. I too suspect same. Try to hold an air pressure and clean up the contacts. Do as suggested by the members or take your Vehicle to a good technician for a proper job. Sylvi Wijesinghe.
  20. Sylvi replied to SLA's topic in General Automotive
    'Pericles', Yes I agree with you. Originally when I first started to post I used to Address Members Sir. Let forget and help the A/L forum members for their problems of Automobiles. The best way we can. I thank You for your post giving an a explanation. Sylvi Wijesinghe.
  21. 'varunatech', Thanks for your post. It is a good lesson for our motorists. Sylvi Wijesinghe.
  22. 'The Don', I agree to your post to a certain extend. As far as I know only old engines manufactures requested for a running in period. Present engines has bearing clearances, Improved Engine oils. I don't think it is necessary to do any running in period. It is better if you do first 500 Km under 40 KMS. Still when you pick up on gears or go on a up hill the engine will run at high RPM. I have had experience very high capacity Industrial Diesel engines (Generators) New ones, I do 100% load test before hand over to the end user for 12 hours. Running at 1500 RPM that is the maximum those engines are recommended to run. To generate correct electrical requirements. Sylvi Wijesinghe.
  23. Sylvi replied to SLA's topic in General Automotive
    'JadeyBlitzen', I don't call normally any member in unwanted names. Dude was the member who had posted the post from Kandy with 214 Posts. I used his forum name to reply the post. I don't think he will get offended for same. Sylvi Wijesinghe.
  24. 'Straga', Moderator point out you have no reason to go with a underage person who smoke. As for NPP you joined the forum just to complain about your episode. What I get out of your post is that you was stopped by police and checked.They carry out random checks to find out any contraband like Prohibited drugs. You did not get the policemen identification numbers if so you can complain this matter to DIG Colombo for accepting a bribe of Rupees 1500.00. Still you can complain for requesting money as a bribe for having a packet of cigarets inside the pocket and demanding money to you'll to let go. Go to DIG office, they have number of officers for this bribery complains, definitely will entertain your statement. Act fast before you forget Policemen faces. If you are brave and want to stop corruption in the police department go forward make a complain today itself without delay. Sylvi Wijesinghe.
  25. 'Jith', My advice to you is not to convert the vehicle to Diesel. As this give you good performance with original petrol engine. Even if you have a some other diesel turbo engine on it you will face lot of problems.If you are mechanicaly qualified and do repairs by your self it is OK. It is better to have chat with the agents engineer and import a used engine from Australia or Any country which will exactly fit into your vehicle Similar model with least modifications to be fitted. Most of our diesel conversions are done by not competent mechanics in srilanka. Do not fix some other engine in Srilanka I did few years ago fitting diesel engines to cars and jeeps but they never gave the same performance like a petrol engines. Those days vehicles did not have Electronics incorporated to vehicles. They were simple mechanical and electric models alternator with a battery. Today most of the vehicles have electronic controls incorporated for better performance and easy driving to the driver. Today any motorist will want speed good road holding fuel efficiency trouble free running. By fitting a diesel engine your running cost will come down. Maintenance bill will be high. If you want to go for a Diesel exchange your vehicle to a original diesel. Above is my experience and opinion some others will not agree to mine. Sylvi Wijesinghe.
