Sylvi
Everything posted by Sylvi
  1. Sylvi replied to Nishan.dj's topic in General
    'MkX', I understand your post is not relevant to the topic. There is a deep hidden meaning on same. My reply follows. As for your post do you want to buy or to have when ever you require a good grease gun attachment, the models you have mentioned there are plenty in Colombo in H shops. The cost will be more than what said in my post.What is preferable for your requirement is it jap, Ru, Sl. I can give you one advice the best is srilankan very well seasoned model over 3 under 3.5 decades with no productions to use same attachment for some time and pass on to some one.If not you will be in trouble will have to use same for life time.For 58 years of greasing experience in sl, jap, Thai, Cori, USA Sing and wherever I landed. My post too is not relevant to the topic, Moderator will not object to my reply. Sylvi Wijesinghe.
  2. Sylvi replied to fatjoe's topic in Mechanical problems
    'fatjoe', What did you do for the engine, repaired same or fixed a used engine. Sylvi wijesinghe.
  3. Sylvi replied to mensoft's topic in General
    'mensoft', The picture of your post shows a wiper arm spline drive shaft unit.Can you post what is your problem. As Your post I understand you don't have one side wiper arm spline drive unit attachment to fix to the body.Is it correct. Sylvi Wijesinghe.
  4. Sylvi replied to Nishan.dj's topic in General
    'Nishan.dj' Grease guns are available in most shops in Panchikawathe. I paid Chinese one Rs.750.00 about one month back. Sylvi Wijesinghe.
  5. Sylvi replied to mensoft's topic in General
    'rameez' Morris Minor discharge was nothing more than 15 amperes the HT Col takes 2amps lights were not more than 10 amps wiper is about 3 amps. They did not have A/C.Today cars have A/C and high discharge equipment.(MM)They had Dynamos after 1960 alternators were fitted to all automobiles Alternator is capable of handling above the Dynamo can generate. Alternators are build to handle high amperage.As I have told in my post you have to have a high amperage meter with thick wire to handle the new automobile demand. Volt meter you can have any small auto cable because they only read the voltage and can be connected directly so that full time the meter will be reading which battery will not effect or else can connect through your Ign switch when it is on only meter will read. When the engine is running the battery voltage will be more than 12 volts. Potential difference of the battery is volts Capacity is amperes. Fully charged battery some times will give reading of 12.5 volts or more. My recommendation is to have only volt meter this will give a reading for you to know the battery is over charging the reading will be more than 14.5 volts. Under charging with all your equipment on if meter reads below 12 volts. You have to connect the ampere meter correctly with correct wire if not the wires will get heated. Sylvi Wijesinghe.
  6. Sylvi replied to mensoft's topic in General
    'fatjoe', I think you are new to the meters you have mentioned. Ampere meter will indicate the discharge and charging rate of your DC electrical system. Discharge means when you switch on any unit the indicator of the meter will show the discharge ampere rate of the unit what you have switched on. Charging rate means when the engine is running alternator should compensate the discharge of the units working at that time including A/C ,Wipers, H lights, Audio setup and whatever the accessories which are working at the time engine is running.There should not be a discharge indicated on the ampere meter when you do your normal driving. Ampere meters are not fitted into cars now days due to heavy discharge from above said units. If you want to fix a ampere meter you will have to use special thick gauge wire which is expensive. Volt meter will indicate your battery voltage. This meter will give a low reading less than battery voltage (DC12Volts)when you operate the starter motor to start the engine.Gradually the meter will increase to about DC 14.5 volts when the car is running. If the volt meter shows more than above said reading then you will have battery water evaporating and that can lead into battery failure as well as your alternator. When the voltage reads high ampere meter too will read high. The above said meters are not necessary due to high quality of your auto electrical equipment manufactured today. If you like you can fix them as additional meters to monitor your electrical system performance of your vehicle thereby you will be able to detect a fault immediately according the reading of the meters which will help you to get a electrician to handle the matter to do necessary repairs in time. I personally advise you if you want only to fix a DC volt meter only. Sylvi Wijesinghe.
  7. 'carboy2011', We went to Jaffna about two months back I spoke to army personal there about coming back on that road they said some areas are not advisable to go due to bad road conditions so we came back on the same A9 instead of taking that road. Sylvi Wijesinghe.
  8. Stig', What you are referring on your post I have seen them. I don't think that have A/C.I remember driving close to one of them they are not Bajaj. That was a Diesel body completely changed to look like Thailand three wheeler. The modified three wheeler I saw was I think Ape built in India with a Diesel engine. As I wrote in my previous post if you want to A/C have to have a small separate engine with a lambretta Dynamo-motor in one unit to take A/C cooler fans condenser fans DC load and to drive the compressor.It can be done cost will be today around 250000.00 rupees or more with enclosing the body with Fiber glass and have one door for the passenger one door for the driver.To find a small Dynamo-motor will be very difficult. Sylvi Wijesinghe.
  9. 'MiraOwner', Specially when you discuss about engine mounts, you should replace them with imported mounts if it is available. Do not believe the Panchikawathe men who do rubber bushes and mechanics they will do temporary repair. If not you can get them molded by some one but the life time of them is not sure. Used to modify and mold during era 1962 to 1980 the time we did not have free import of spares. Sylvi Wijesinghe.
  10. Stig, Your idea was tried by a Srilankan Engineer some time back but 150cc engine did not give enough power for three wheeler and A/C compressor. Three wheeler was fully covered fiber glass body with A/C. This three wheeler had to fix another small petrol engine fitted rear with the A/C compressor I made the self starter for that engine.Tried another project to convert a three wheeler to a four wheeler never completed. Sylvi Wijesinghe.
  11. 'shaanstop', Yesterday lankadeepa Sinhalese paper 3rd page carries a 1/4 page advertisement to say, that 27.8Km/liter was the winner's figures. Have his photograph with five others who got cash awards for Alto and K1O. Sylvi Wijesinghe.
  12. 'E L N I N O', You are correct, they have guard wheels as the rider cannot put the legs down, Rider will have to be careful to be within correct space when he stop so that their guard wheels will not interrupt any vehicles on the two sides. Sylvi Wijesinghe.
  13. 'Civic_B', If you go back on this thread you will find out all about what your pictures you have posted.This happened on 1st September. Sylvi Wijesinghe.
  14. Members, We are discussing about Tata Nano Fire to find Tata Nano Latest news.Gold plated car. http://www.newlaunches.com/archives/tata_nano_indias_cheapest_car_now_with_gold_is_most_expensive.php Sylvi Wijesinghe.
  15. 'CyRaX', OK I admit it is wrong impression gives on my post to you as for your explanation. I apologize for same. Sylvi Wijesinghe.
  16. Sylvi replied to Devinda_Z's topic in News & Updates
    Thursday, 22 September 2011 UK's first hydrogen refueling station unveiled at Honda plant 20 September 2011 | By Stephen Harris The UK’s first public hydrogen-vehicle refueling station opened today at Honda’s manufacturing plant in Swindon. The facility is designed to look and work like a conventional petrol station and provide similar refuelling times, delivering hydrogen from pre-filled cylinders so that vehicles can fill up one after the other. Built and run by industrial gases company BOC (part of The Linde Group) with backing from Honda and Forward Swindon, the station is intended to offer a strategic link halfway along the M4 between London and Swansea. The partners also hope to address the belief held by many in the industry that consumers won’t buy hydrogen vehicles without an established refueling network but fuel companies won’t build new facilities while there are no hydrogen cars are on the road. Commenting on the new refueling station, BOC UK managing director Mike Huggon said: ‘It demonstrates that we can build the infrastructure needed to establish a hydrogen-powered transport system. ‘But even with private and public support — as we have here in Swindon — we need government commitment to make this work across the country as a whole. ‘We can provide the tools but the government has to create the policy framework in which we can build the low-carbon infrastructure of tomorrow.’ Most major car manufacturers are developing hydrogen-vehicle technology, which is favored for its lack of tailpipe emissions and longer range than that of existing battery-electric vehicles. However, most industrial hydrogen is currently produced through the steam reformation of fossil fuels, which releases carbon dioxide into the atmosphere. ‘We are looking to more renewable technologies in the long term because that’s what customers want,’ BOC spokesman Simon Napper told The Engineer. ‘The issue at the moment is getting renewable production facilities up to commercial scale. There are only a few plants around the world that deliver at commercial quantities. ‘Linde has opened a commercial-scale plant in Leuna, Germany, based on electrolysis and one in Canada that works on hydro-electric power.’ I got this information from the web. Sylvi Wijesinghe.
  17. 'JayZ', I am not telling stories, till 1980s we used mostly UK USA European automobiles as well as domestic appliances. To day China India had come forward with some what high quality automobiles Computers domestic appliances. Can you tell me any other product comes from Japan ordinary monthly wage earner can buy due to the high cost. India has a large market once their economy was opened they went in for large production. I use a Bajaj new one but fuel figures in town running I never get more than 25km/L out of Colombo 34Km/L at 40Km. Now I will answer for your question I saw on drawing board and partly assembled bajaj three wheeler converted to four wheeler by a Srilankan Automobile engineer using two Bajaj chassis welded to gather with front suspension was very simple arrangement, with ribbed pipes canvas top 6 people can go few years back. He did not complete same due to a foreign job he was offered and migrated.Please note the Bajaj what we have in Srilanka is capable of carrying 500kgs. Sylvi Wijesinghe.
  18. 'CyRaX', You who say I am a fooled, OK that is your opinion,please understand if you go to the web you will find how to hack cell phones domestic electric meters. Our computers for what reason we use virus guards? Do not underestimate our capabilities of our technologists. Only a matter of time they have get their hands on those circuits then they will improvise some method to hack any circuit or an a meter. I only informed how upset that fuel distributor for his integrity his manager has gone to Auto lanka forum office to find out who is this person who has done this. Later got my contact mobile number contacted me. Sylvi Wijesinghe.
  19. Moderator, one Mr, Dumi##a contacted me regarding the petrol distribution center matter from his mobile 0778239603. He had a long discussion on this matter he is the manager on the said fuel D/C. I got the owners Mr. Nimal perera's mobile number from him 0714904898. He want me to come and check up the set up, he has fully computerized system. According to him it is 100% perfect, cannot be cheated. He informs me because this is a new distribution center to the area other distributors are angry with him and they have teemed up got this person from kandy to post this post. Corporation dad checked up the matter already. It is left to you to sort out this matter and if some one post a post he must be responsible to that post. I only verified from the relevant authorities reference given on said post. Sylvi Wijesinghe.
  20. 'JayZ', I am not. Happy to see more Indian autos in Srilanka. Sylvi Wijesinghe.
