Everything posted by Sifaan
Mercedes-Benz W124
do you mean the max. rpm?
Need Someone Who Knows French
@Peri: Thanks; my brain tells me it can't cope with all of this tonight, so I'll go through it tomorrow @Leyland: This seems interesting; will give it a try and see (guess it should work at least for the text PDFs)
thanks Mani; fingers crossed that the other one is more informative
- New Car
thanks for searching for the issue I had already seen the bba-reman link; as well as many more on the topic on citroen-owners-club.co.uk, and the C5-L yahoogroups - all with problems with mixing on the left hand side and all due to the socket wearing out. I've got the issue posted up on the UK owners club as well as aussiefrogs, but it's got everyone stumped so far. can't remember particularly about the honestjohn link btw I don't need all the stuff in the docs translated, not even all the stuff related to the climate control - just anything that might be an answer to my questions. (of course, to figure that out IS a lot of reading!)
OK, the two french docs are here and here. what I am trying to find is some info to troubleshoot a climate control problem... background: there's a common situation where (on RHD C5s) the passenger side blows hot - this is because the plastic socket that engages with a flap control motor sprocket gets damaged and remains stuck in the position to provide hot air. it appears to be a problem only on the left hand side because there are a couple of coolant lines near that socket, which may be making the plastic brittle or something. There's a documented solution for this which is to use a replacement motor with a longer shaft (or glue to motor to the socket!) I seem to be the first person to experience this on the right hand side; it's possible it's the same reason (damaged socket) but I'm also trying to find out if the fault can be elsewhere (e.g. temperature sensors) - because sometimes things work fine (could be the socket is marginal, or that it depends on the sensor reading). And sometimes it blows warm air from both sides (as if the compressor is cut off; but I think it's still running cos if I switch the A/C off I can notice a drop in idle rpms; and a subsequent increase if I switch on again) I would hate to open up the dashboard only to be unable to locate the fault! Questions 1. How does the temperature sensors (inside (how many, where?) and outside) influence the operation of the system? 2. Under what circumstances does the A/C compressor get shut off? 3. Any other info in there that could be relevant to my problem Thanks! PS I hope MasterDon can at least temporarily suspend his amorous tendencies
Audi Market Prices
don't know to comment about audi's; however, a useful resource for Euro cars is usedcarexpert.co.uk - they have checklists of what to look for (i.e. common faults) on different models. e.g. see http://www.usedcarexpert.co.uk/cars/audi/a4/fault-guides/ for the full info you have to register.
Is there anyone here who can read French? I need some help to translate some technical documentation. (Initially figure out if the doc. even has the info I'm looking for) (I could use google translate, but it'll be a pain to sort out OCR; plus I'd trust a french speaker with some knowledge of cars over google's translation abilities)
Can We Rent Out Our Cars To Taxi Services ? Whats The Average Pay ?
and then it becomes very expensive that's another advantage of renting to a known private individual - you can agree with him to report that he had "borrowed the car that day" in case of making an insurance claim
what started out as a practical, relevant thread now reminds me of the proverb about wrestling with pigs.
Wheel Alignment ?
what does the warranty cover? that the wheel balancing weights will not come off?
don't know to comment on the rates. however rented cars have a tendency to get abused - although of course it depends a lot on the person who ends up using it. If it's at a rent-a-car, or taxi service (yes, it's possible to rent the car to them), it will get used by different people and chances are that most of them will not be so careful (I am referring to things like not slowing down much on bad roads -> lifetime of suspension reduced; careless driving -> dents, scratches etc.; might run the car even with low batter water, low air, low engine oil, etc.) If you want to rent it out at all, either rent direct to a (preferably known) individual for a long-term (even if you can't charge him as much) or get a reliable driver and put the car+driver on a taxi service (you will be paid a rate per km for hires; all other costs borne by you).
March K11 - The Engine Stops Automatically
You mean to say A*W doesn't know this guy's upto monkey business?
Turboman, Afzgtr's And Dilku's Thread
Hmm; I forgot that we used some WD40 on that stuck screw
it was only 6 posts to look up, didn't take even 5 mins. and I see you are maintaining your 100% on attacking other forum members; while your useful post stat has dropped from 14.3% to 12.5% Don't think so; car was serviced recently and doesn't need any oil. Oh, I didn't realize the two of you were having a private duel
Hmm... let's see what the sum total of your contribution has been this past year. Hunting for new VW Beetle - Useful to OP, NO; Attack on forum member, YES Porsche Panamera and this and this - Useful to OP, N/A (all 3); Attack on forum member, YES (all 3) HC Bikes - Useful to OP, NO; Attack on forum member, YES BMW 318i parts cost - Useful to OP, YES; Attack on forum member, YES So including the post on this thread, you have made 7 forum postings in the last year, ALL of which have been attacking people, and only 1 of which has contributed anything to anyone. Statistically, you are the one who keeps posting pointless and stupid shit.
Advertising Policy On Autolanka Forums
Hi! When there is a "no advertising" policy on the forum, can someone clarify what is/isn't allowed? The only thing I was able to find (from an Admin/Moderator) was Madz's post (#4) here. Is this still valid?
Personally I don't like people working for a company (in this case A*W) also doing work on their own - they are essentially in a conflict of interest with their employer (if you owned the company, would you like to have such a person working for you?). And it's even worse if they canvass business from people who come to get work done at the company (I have no idea if this individual does that or not; but I have received such "solicitations") Of course, when it comes to the technical ability to perform work, they are probably better than someone who hasn't received specialized training on the brand. OTOH, I wouldn't be comfortable trusting such a person, and I would rather work with people I can trust.
Prius Met With An Accident
You're evading the point. Above would possibly have been valid excuse, except 1. this wheel cover thing is supposed to be a "feature" to increase economy; didn't google turn up info about it? 2. When Mani wrote you could have gone and taken a look at them and checked (or at lease googled) before you wrote
Tata Nano
isn't it "all fart but no shit" ?
I was at Kleen Park recently and a Prius came in (to get some carpets done) and I went over to take a look; I'll admit I also didn't notice it had wheel covers - the brake disc and caliper was visible so I also assumed it was just the alloy wheel. Admittedly I was paying for attention to the "killer" gear knob and the dashboard than the wheels though. However, if I had a Prius, (and assuming "I look at Prius wheels every day") and I saw pics of an accident where wheel covers are visible, I would at least think "damn! those wheel covers look exactly like what's on my wheels" rather than say
Alto Noise
In addition to your other faults, do you also now suffer from short term memory loss??? The only reason OP wrote was because you said So the point was about brand new indian cars having so much trouble even during the warranty period; not about 10-20 year old jap cars needing work done at garages.
Seat Belts In An Accident
rofl trying to visualize this
how did it manage to have the post on top of it? looks like it had wheel covers over the alloys and two have come off actually the dash/steering look to be in the right place for the prius except for steering wheel moving downwards (compared to the frame, which seems to have retained shape except for windscreen caving in). However it looks like the driver seat has been pushed forward (very short driver or moved after accident?)
Tata Nano
I was at a Creativity/Innovation session by Frederik Haren last year; and he said he was at the Launch event for the Nano. He said the car was being bashed in the press (not sure if he meant Indian press or European press) for not being "safe", but his take on it was that the Nano was not about building a safer car, but about building a safer alternative to motorcycles (and I guess tuk tuks), which was what the lower income people could afford. I don't know how the price positioning of Nano in India is, compared to motorcycles and tuk tuks; but if was at a price where a person could stretch their motorbike budget and buy it, then it would be a good thing Of course, at nearly a million bucks that argument is anyway not applicable in Sri Lanka
