Everything posted by Sifaan
Knocking In 2Nd Gear
just a thought... could it be that the timing was advanced too much during the conversion, hence causing knocking? and is the knocking happening only when changing to 2nd gear (i.e. goes away when accelerating), or right throughout in 2nd gear (and goes away in 3rd)?
Changing Odo Meter Reading...
well, that idea wouldn't work in my case cos the mileage is also stored in the ECU. If a cluster with a lower reading than the ECU is installed, it will download the ECU value (and vice versa as well). given that it's a 8 year old car, the technology may be present in other (newer) cars as well... (For the record: there's a motor broken in the cluster and I was toying with the idea of finding a used cluster and discovered this caveat)
Original Fan Belts To Reduce Noise ?
shouldn't the water pump be on a different belt (timing belt) than the alternator, A/C, etc.?
Assistance Needed!!
maybe stock they brought down for the "certified reconditioned cars" business that they still haven't been able to shift!
Random Question Thread
perhaps a 3rd party manual like Haynes?
The manual for the current car says to change oil filter when changing oil. But the manual also says to service every 20,000 miles/2 years ("normal" conditions) or 12,000 miles ("severe" conditions). of course that would be with the recommended fully synthetic oil. the severe conditions already includes short trips (engine not reaching ideal operating temp, hence more wear) and traffic (engine running more than what the odo would indicate). so I don't know what it is with the local conditions that make the service intervals so much shorter (dust? poorer quality oil? using mineral oil when manufacturer recommended synth?) but maybe that doesn't affect the function of the filter as much. In any case, more than the owners delaying the filter change I think it is the mechanics/service advisors who tell the customers that it isn't necessary to change the filter yet. We used to service the march @ Pitstop and if I recall, the service checklist in the booklet had something on the lines of "check oil filter".
"easily" depends on the vehicle... but bottom line is, as a buyer, you can't trust the odometer reading at face value. (if it's backed by maintenance records, reading matches the usage patterns, condition, etc. of the car, then it's probably genuine) a reset would be quite lame ass though, cos that would make the car's appearance/condition/age incompatible with the reading.
if it's the right spec for the car, is it still necessary to check the gap before installing? or is it that the actual gap may be different from what the gap should be (manufacturing defect, etc)?
Kia Spectra Coolent Overflow From Reservior Tank
if there was a problem with the thermostat then definitely the engine will overheat. however, the radiator itself won't get hot (because the thermostat isn't allowing the coolant to flow to the radiator). but the heat indicator should move up. BTW when you said coolant overflow do you mean it just drips, or was there vapour coming out?
Best Diesel Suv For Duty Free Vehicle Permit
USD 25000 if it's the recently announced one for public servants then there's also a limit of 2000cc for petrol or 2500cc for diesel (according to the news report)
Thinking Of Opening A Garage
Since you haven't said anything about whether you meant a one-man-show or not, I'll assume you'll start by yourself. Plus as you already have a whole bunch of equipment your capital outlay will be pretty low - build a shed and a ramp, and whatever equipment you still lack. Overheads would also be relatively low (rent for the land). The amount of business you can do is constrained by the amount of time you can put in, and therefore you probably need to charge a premium rate for labour. In which case you'll probably end up doing relatively difficult work, where people are afraid of makabasses messing things up and are willing to pay extra for a good quality job. If this model provides enough profits for your needs, then all well and good. But if you need to make more money, then either you will have to charge higher rates (for more specialized work? but depends on whether the market will bear it or customers will move away) and/or you have to expand by bringing in mechanics. and then you're going to face all the challenges that others have elaborated already. however, if you will continue to position yourself as doing high quality work at a premium price, I think you would stand a better chance of retaining good people (because you can afford to reward them better). if you are going to attract people on the basis of being good at what you do, people will probably travel anywhere within colombo suburbs (or even further). probably safer for you to start in a cheaper place (in the suburbs and/or away from the main rods) until you generate some regular customers. if you have space at home that would be the cheapest option You seem more of an allrounder so I think it's best to not specialize; however based on market prices for different types of work you could probably avoid the ones that have a lower rate of return (except maybe for your (eventually) regular customers who'd like you to deal with more stuff while the car is with you) all the best!
Before Buying Brandnew Maruti Alto Check List
that's why you get a warranty on brand new cars
Peugeot Automatic Transmission
well, if the solenoid is faulty, the ECU detects that there's something wrong in the gearbox and it goes into "limp home" mode (basically to ensure you don't do any further damage to it) but I think in limp home the reverse gear should still work, so it may indeed be some other problem.
Dropped My Torque Wrench
if you are going there to check if they can fix your wrench, you could also check with Cambridge Traders which is about 2 doors away
assuming the problem is with the valve; I checked with the mechanic and apparently there is a procedure where they remove the valve, clean it, and replace it. about a 20 minute job and supposed to be good for about a year or so (after which the cleaning may be needed again). however if that is all it takes I can't imagine that the AL4 would have such a bad reputation as it does. if the newer valve is available it's probably good for peace of mind to get it replaced. anyway, if you PM me your number I can give you some contacts of people who can firstly do the diagnostics and secondly clean the valve if that's what's needed...
What is the problem you have? Is it in "limp home" mode (only 3rd gear)? The AL4 automatic transmission on the facelifted (1999 onwards) 406's had a high failure rate (resulting in "limp home" mode); because of a solenoid that was used in it. You can find more info about it here: http://www.peugeotlogic.com/workshop/wshtml/transmis/al4/solenoid.htm
Recommended Tyre Pressure (in Sri Lanka)
hmm... silly of the manufacturers to bother quoting recommended pressures then
Hybrid Vehicles
well, given that hybrids don't waste much energy stalled in traffic, the numbers should still be quite good of course the higher load on air conditioning would mean the fuel figures won't be as good as in a colder country...
Belta 1000Cc Or 1300Cc Advice Please.
I was told the same thing by A*W (stiffer suspensions and more ground clearance) on models for Sri Lankan market vs. JDM (he didn't mention a number though). (btw the discussion was not because they were trying to sell us a car; they were giving us a brief...) Is there anyone who has driving experience in the export and JDM versions of the same car (e.g. 121) comment on this? If what the marketing people say is true then the JDM should be more comfortable on good roads (the softer suspension dealing well with the minor imperfections) but less comfortable in average/bad roads?
Hybrid Vehicles
Yup, I was referring to that bunch of farts
Hybrid Vehicles
there is a high density of natural gas emissions a few km from colombo city limits - could this be a sign of a deposit? apparently the emissions are only there on certain days though.
Hybrid Vehicles
of course propane has it's benefits, but for countries that have, or have easy access to, natural gas (which is mostly methane) running cars on CNG is quite economically viable
Hybrid Vehicles
but it is a renewable source of natural gas... now if we could only find a way to liquify it and burning methane is cleaner than conventional fossil fuels - no nasty NOx and SOx
Hybrid Vehicles
maybe... but it would take one hell of a tree-hugger to go around saying "I'm sticking to my 10-year civic rather than upgrading to a hybrid because it puts z emissions in the atmosphere to build it and that doesn't justify the reduced emissions of running the new hybrid", and such tree-huggers probably have push cycles made out of recycled steel
Hybrid Vehicles
AFAIK the basic idea in a hybrid is that there are 2 major sources of losses: 1. engine losses - engine not running at it's most fuel-efficient speed and engine rpms changing (accelerating burns up loads of fuel - check any car that has an "instantaneous" fuel consumption display) 2. braking losses - all the motion in the car gets converted to heat at the brakes This is addressed by: 1. Keep engine running at optimum rpm. Use excess output (e.g. if the car is moving slowly) to charge the batteries. If the batteries are full then shut the engine and run on the batteries. If more drive is needed, supplement the engine with the electric motor. if still more is needed (or the batteries are getting low), rev up the engine 2. regenerative braking. covert the energy loss in braking to charge the batteries. of course there are more complications, such as different torque characteristics of traction motors and gasoline engines (so it might even be worth to run the car on traction motors until it gets upto a particular speed), complications in the simultaneous engagement of engine and motor, etc. so it's not going to be as black and white as above. In the video posted by Big_D, the prius was being driven as fast as possible, so the engine was running at it's highest speed and the battery/motor was just dead weight (they probably had it with zero initial charge as well). btw may be of interest to you that PSA is working on a different hybrid system ("through the road") where engine drives front wheels and motor drives rear wheels, which is supposedly a much simpler implementation than what toyota uses. and you can selectively enable all-wheel drive. but there are drawbacks like needing a starter motor to start the engine (on toyotas, the traction motor can start the engine) and some other inefficiencies.
