Seat belt warning beep
Do you get the beep when you put the gear in Reverse? If not, it maybe disabled. There should be a combination of buttons that you press on the dashboard or an option in the menu to enable/disable it.
- Seat belt warning beep
- Vehicle Service Stations & How They Cheat Their Customers.
Ford Fiesta
Pretty sure ST is 6 speed manual only. The Ford Focus ST and RS also come with a 6 speed manual. I have been contemplating on getting a hatch for my wife and the Fiesta is on the list. Been looking at ST as well but had to give up because she wants an automatic and ST was not offered as auto.
Difference between Putty, Cataloy and Filler
Well said! May I suggest creating a thread to share progress and details of your Moris Minor restoration project? While it can seem daunting to attempt to do bodywork, with the right tools and a bit of perseverance, you can achieve great results. Of course if you are a first timer, you shouldn't jump in the deep end and attempt to paint an entire car or do bodywork on an expensive Lamborgihin or something. It's an art and skill you should master to attempt to do complex repairs. You should start small and make your way up. Carrying out small repairs to start with is not that hard. I am in the process of learning myself. The thing is, in Sri Lanka, labour is so cheap, so you might as well save your time an effort and get a garage to do the bodywork for you. But I agree with Kusumsiri's comment about how most of the local tinkerers and painters are very poorly skilled. In other countries, labour is expensive (because every tradesman is qualified), so many car owners are driven to do mechanical work as well as a bit of bodywork on their cars. Below is the most recent body repair I attempted on my own. It's my uncle's Nissan. This is in Australia and I managed to save him more than half the labour charge because I did all the prep work. The pros just had to do a final primer, paint and clear. Damage after straightening out a bit with a mallet and hammer. It was worse than this, but I don't have a photo of the original damage. It was caused as a result of reversing the car and hitting a concrete stump. And right away you can see my "professional" skills by seeing how I have applied that filler. After hours of sanding and re-shaping: After primer. Ready to be taken to the painter: It's holding up pretty well, so I don't think I ruined it.
CVT Vs Conventional Auto
In CVT, the RPM climbs and stays in one place while the car accelerates. In conventional auto, you can see the RPM slightly move as the gears shift. On the Demio, the CVT doesn't have an S position (has button on side of gear lever for S and S/S indicator appears on dashboard when. The conventional auto does. So yours is a conventional auto. Example from The Demio Thread. Conventional Auto: CVT:
- 11 replies
- cvt
- automatic
- auto
- transmission
- PickMe or Uber Rental
- Engine Oil Overfill
Charging battery while connected to the car
Haven't heard this before. How long are they? Or are you saying that the car is parked in a garage, facing a wall and there is no way to being another car close to it? And yes, it should be fine to charge while the battery is still connected to the car. This is essentially what the alternator does. You just need to make sure the charger doesn't output more than 14.7v or so. If you're not sure, just disconnect the negative terminal. It's literally a 30 second job.
- ## Post Whoring - Part 3 ##
Can a lancer cs2 be converted for evo 7 or evo 9
So many "Evo conversions" are done in Sri Lanka. Although it's called a "conversion", what really happens is that an Evo VII, VIII or IX is brought down from Japan as parts (half cut, nose cut, roof cut etc.). Then it's re-welded here and a chassis plate from a CS Lancer is attached to it. Basically the firewall is cut off from the CS Lancer and welded to the Evo chassis because that's where the chassis number in the CS (Lancer) and CT (Evo) are. Some just bribe a guy at RMV and update the chassis number in the registration book because that makes the car look more authentic as it has an Evo chassis number. The chassis of these Evo converts are probably not even as strong as the base CS Lancer. The moment you cut the body in half and re-weld it, the car loses it's structural integrity. Especially if not done properly. So this is a bit of a controversial subject due to the legality and safety concerns. As for converting an actual CS Lancer to Evo, then it's a bit of a complicated process. You will have to find a donor Evolution to replace the rear floorboard (to accommodate the differential and drivertrain). The rear quarterpanels of the Lancer will have to be cut off and Evo ones welded in. Front fenders, bonnet, rear doors will have to be swapped. That's just a fraction of the changes. It will still not be as great as an Evo because they have additional spot welds to strengthen the chassis. Saw this video on YouTube a couple of years ago. Just for you to get an idea of the process:
Nissan Presea
There are risks associated with any purchase, whether it be a car or not. The best you can do as a buyer is make an informed decision. If you're having doubts about the car because of this lights flickering issue, get the seller's permission and take the car to a good auto electrician for inspection before the purchase. On an online forum, I or any other member can only tell you what might be the issue as it's sometimes difficult to diagnose issues based on a description (especially of noises and vibrations etc.). It's up to you to take further action based on advice given here. From your description, it certainly looks like the rectifier in the alternator is on its way out, or already is. And as I've said before, if this is the issue, it is a simple repair where the alternator needs to be taken out, serviced and rectifier replaced. The rectifier (some call it the regulator, but it is a rectifier circuit really) is responsible for converting the alternating current (AC) produced by the alternator into direct current (DC). This is done with the use of a set of diodes. The diodes are essentially what forms the rectifier circuit. When one or more diodes in the circuit becomes faulty, the resulting current is not a smooth DC current and has small spikes. This is what you see as a flicker in the lights.
Need mechanic/experienced guy in vehicle filed
Welcome to the forum! If the car is in Kalubowila, take it to Car Checks in Nugegoda. That's your best bet IMO.
Nissan Presea
Sounds like a bad alternator to me. Probably a faulty rectifier/ v reg. If that's actually the issue, yes it can be repaired. Get the charging system inspected, battery tested before attempting to repair the alternator because it just might be a dying battery. Edit: When I said it can be repaired, I meant the alternator. Usually the rectifier is replaced with a new part. The rectifier is basically a set of diodes that sit inside the alternator. It's normal for them to fail as the car ages.
- How much 1000cc < Car price affect from coming budget?
Honda accord wiring problem
It's possible that the new fuse box you used works with a different wire harnesses. Meaning the pins are different. Can you switch back to the old one and see if all these issues are no longer there? If that one works, I suggest swapping the housings of the fuse boxes and using the new housing on the old fuss box internals. If at all that's possible.
Scams on autolanka.com??
This one has got to be a missing zero at the end. Probably an honest typo.
- Brake system failure
Honda Fit GP5 or Toyota Aqua
I wouldn't call it rare. Honda themselves issued 3 recalls for their early (around 2014) DCT units on the Vezel, Grace and Fit. There's so much discussion online and even here on the forum as well where members have had issues. Given that pretty much all Vezels and Fits in the country are grey imports, they would definitely be affected by this recall and no way to get them fixed. So the issue should be common in the country. However, newer cars seem to be having these issues rectified. So as long as the car is not affected by any of these DCT recalls, you should be OK. So considering the DCT issues as @asrock said is a valid advice. The overheating error message on the other hand is not due to an issue with the transmission, but due to the very hellish driving conditions in Sri Lanka as @matroska correctly mentioned. Unlike many performance cars that have wet clutches, Honda's DCT has dry clutches which has limited capability to dissipate heat. Constant acceleration, braking, cutting others off and being cut off by busses and three wheeler drives causes the transmission to shift back and forth all the time. The (dry) clutches in turn heat up and the error message pops up in the dashboard. I've heard many people suggest driving in L gear in traffic to prevent the transmission from shifting up and thereby reduce clutch operation. While that maybe a workaround, the country's general population just needs to learn to drive properly.
These are probably the same people who back in the day said automatic transmission will give trouble and not run as long and will be less reliable than manual. Obviously when a new technology first enters the market, it can have it's issues. Especially as the tech becomes complicated. It's been quite a while since CVTs have been on the roads and the newer versions are pretty reliable. If the transmission oil is changed on time and proper service is done, I don't see why a CVT shouldn't last as long as a conventional auto.
- 11 replies
- cvt
- automatic
- auto
- transmission
- Torque Power curve for Bajaj Threewheelers
Depends on where air is trapped. If there was air not big enough to cause a consistent issue, but sufficient enough to throw the ABS module out of whack (especially once the system heated up causing the air bubble to expand), then it could have caused the issue. But if there was no repair done, this is probably not the case. So yeah, maybe you can try bleeding out the system and keep an eye out for any air that's purged out. If you hook up a transparent tube to the bleeder valves and bleed the system, you will see air bubbles coming out as you pump the pedal. Make sure to keep the reservoir topped up during the process to avoid air reaching the ABS module. By the way, you can do a simple test on your own to determine if the brake booster is leaking. Follow the steps in the post below:
Vehicle to buy for 6mn
Welcome! If you want members here to help you, you're gonna have to give us more than that. Otherwise get answers like the one above. ?
Allion 260 Transmission Vibration at inclines
Please stick to one thread to ask your questions. There is no need to open copies of the same thread in different sections of the forum. Threads merged.
If it was a master cylinder issue, the brake pedal will consistently behave the same way. So I hardly think that's the issue. Once you were in the garage, did you bleed the brake system and check if there was air in the system? Also, was there a repair in the brake system done or at least a brake fluid change done recently?
