Davy
Top Contributors
  1. I can confirm this is the only difference. There's no other difference between the LHD and RHD bezels.
  2. Yep, the fuse box is the same for all grades across all markets. The layout is the same. The fuses for optional equipment may or may not be there based on the circuit design. I've seen many CS Lancers in Australia with cruise control, rear fog lamps, rear windshield wiper with washer, retractable power mirrors, sunroof etc. Couldn't help but notice that one of the Omron 4 pin relays on @nagaya's fuse box is installed differently to Sampath's (the ones on the left hand side column). Both Sampath's relays have the arrow pointing to the right while nagaya's bottom relay has the arrow pointing to the left. @nagaya @Sampath Gunasekera, can you please do a small test to help nagaya? Switch on the car, take off the fuse box cover and keep your finger on top of each of the black relays in the fuse box while pressing the fog lamp button. If any of them are related to the fog lamp circuit, you should feel a the relay turning on (possibly with a "tick" sound).
  3. Correct. I can't believe people think a 2008+ regular Japanese car comes with carburettor a engine. Even most of the previous generation (2002+) came with EFI. My father was maintaining the Demio at the agents and decided to switch to Mazna after so many blunders (missing dash trims, broken AC vents etc.), poor workmanship (power steering repair didn't even last a month, their tune ups don't even include a diagnostic scan). Mazna on the other hand was able to fix the power steering, carry out body repair to perfection and maintain the car to our satisfaction. I honestly think they're better than the agent. Just my 2 cents.
  4. Yes, it should be between the min and max marks. This is to allow room for overflow if the system builds up pressure. Since you're filling it for the first time after draining all coolant from the radiator, it's safer to fill it up to the MAX mark because there still might be a few air pockets in the system which will be filled in by the coolant in the reservoir. So the level will drop a little bit anyway. This is why it is important to keep an eye on that level for a couple of days until it settles down.
  5. Hi Sanjeewa, welcome to the forum! It's a bit difficult to diagnose noises without inspecting it, so we can give you some pointers based on what you have described. It looks to me like the issue is with your braking system. A few questions first though: 1. How's the level and condition of your brake fluid? Are the brake pads good? Do the rotors show signs of wear (grooves)? 2. Are the front brake generally clean/free of brake dust and rust? 3. Does your car have ABS? 4. Carefully carry out the following: Start the car, open the bonnet. Put the car in drive and gently release the brake pedal while asking someone else to note where exactly the sound is coming from. If your car has ABS, the modulator should be sitting near the firewall towards the passenger side. Pay special attention to determine if it's the ABS modulator that's making the noise. 5. When you say that the pedal is "making a noise", does the pedal vibrate as well?
  6. @Supra_Natural should be able to help you.
  7. You don't need to measure the amount of coolant because you need to fill the radiator to the brim. After you've filled the radiator, run the car with the AC on for about 10 minutes to bleed out the system (get rid of any air bubbles in the system). As the air goes out, the coolant level will go down a bit. Top up as necessary, secure the cap and fill up the expansion tank to the MAX mark. Keep an eye on the expansion tank coolant level for a couple of days. If you're asking to determine how much coolant to buy, a 5L can should be sufficient if you are using coolant that's pre-diluted. Others require you to mix coolant and water to a specified ratio. EDIT: The US/Canada version of the Owner's Manual says 5.4L. This should be more or less the same for the JDM Demio.
  8. Since you had coolant in your radiator before, I assume there is no rust in the system. If this is the case, you don't have to do a flush with a flushing liquid. What I suggest doing is to drain the existing water, run a few cycles of fresh water through the system (to get rid of any debris or rust) and then fill with coolant. Here's a DIY for reference. Skip step 2.
  9. You can get hot glue rated for different temperatures. The regular crafting grade hot glue can withstand about 50C from memory. So if you're concerned about it melting, the best is to get sticks that are rated for a higher temperature. I personally think it wouldn't matter in this case because the entire mechanism is tightly secured to the dashboard. The glue itself isn't under stress because it isn't carrying any weight.
  10. If the radio has RDS, try switching that off? I'm not sure if Sri Lankan radio stations transmit data via RDS, but if they do, the channel you're listening to might be receiving an alternate frequency through RDS. When the radio detects that the station signal is momentarily lost, it tries to tune to the alternate frequency which might not be having a good signal strength. Therefore it jumps frequencies again and so on.
  11. Creating a new thread to share updates and discuss about Formula 1 this year. Race calendar: https://www.formula1.com/en/championship/races/2018.html Driver standings to date: https://www.formula1.com/en/results.html/2018/drivers.html Car rule changes for 2018: The 2018 season kicked off yesterday at Albert Park in Melbourne, Australia and in spectacular style. Hamilton managed to secure pole position, breaking an all time lap record in the process. This guy... damn! Lewis Hamilton pulled off from the line in first, followed by Raikkonen and then Vettel, He managed to hold on to his place, but the virtual safety car was deployed following an incident and Vettel was in the pit during this time (while Hamilton was still on the track - driving slow due to the virtual safety car). Hamilton had already pit the car by this time, so in essence, Vettel entered and exited the pit faster than Hamilton was on the track. This put him in front of Hamilton who was stumped, thinking what just happened. With Hamilton's tyres 7 laps older than Vettel's, all the Ferrari had to do was hold on to that position and continue the race. And that was what he did. Aussie boy Daniel Ricciardo finished qualifying 4th, but received a fuel irregularity penalty and suffered a 3 position loss on the grid, but he finished 4th, overtaking Max Verstappen who spun his car during the race and ended up finishing 6th. Race highlights below:
  12. I have also corrected the links in the previous posts.
  13. @nagaya, you're following the correct path so far. Yes, the connector near the horn is for the fog lamps. The gauge cluster should be having a fog lamp indicator. If you shine a torch at an angle to the cluster, you should be able to make out the outline of each indicator. You'll have to take the gauge cluster out and place a bulb behind the fog lamp indicator as it may not have been installed from the factory. Also, check the cabin fuse box for a fog lamp symbol and check it the fuse is there. @trinity installed fog lamps on his CS1 and should be able to assist you as well.
  14. Transmission oil inside a can with a broken seal breaks down much much faster than when it's in a sealed can or inside the transmission. Since the amount of empty space within the can is occupied by air, it will have moisture in it which condensates inside the can, depending on the outside weather. In a hot and humid country like Sri Lanka, this can lead to the oil breaking down quite fast. If the cap was not tightly sealed, if the can was placed in a place where direct sunlight can get to it, this can become worse. If you accidentally poured water into the transmission, I'd advice flushing out the oil and replacing with new oil.
  15. More or less the same process in the Department of Import and Export website. http://www.imexport.gov.lk/index.php/en/vehicles-others.html#issuance-of-license OP can always go to a freight agent (there are Sri Lankan freight agents in Australia who handle all sorts of imports and exports including vehicles) and get their service to minimise the hassle. They will charge a fee and do the paperwork for you and their Sri Lanka office might even assist you with clearing. @VecLa, send me a PM if you need to any contacts of some of them. You may already be knowing some of them if you have sent cargo to Sri Lanka.
  16. You forgot to mention that you posted it as a "limited edition" Swift Hybrid. That was the first joke. In order to prevent excessive trolling, I shall keep quiet about the second joke. Congratulations on the car @dilshant80. Shall we lock this thread down now?
  17. The Aqua has been discussed to death on the forum. Do a search. Search results Also, it is against forum regulations to post links to other local automotive classifieds sites on the forum.
  18. Please be more specific. Automatic or Manual? CVT or conventional auto? Regardless of whatever it is, replacing transmission oil has been discussed extensively on the forum. If you're talking about replacing ATF, read the following post.
  19. Not sure what you want me to say to that except okay. In an effort to keep this thread informative, may I suggest you share what you think about the car (other than the fact that it's a "limited edition" ) and your experience with it, on this thread? I don't think there are other threads that talk about the Swift Hybrid from an actual owner's perspective.
  20. You don't need that many photos to realise a certain car isn't a "limited edition" as the topic title said originally.
  21. You seem to have your wires crossed. All I said that I think the RS has better options than what you've posted pictures of. I remember the thread someone posted on the forum asking if the RS is a full hybrid, so I'm well aware of it.
  22. Sharing this (again) here for OP's information and because the thread seems to be veering off topic. http://www.gic.gov.lk/gic/index.php?option=com_info&id=415&catid=65&task=info&lang=en http://www.gic.gov.lk/gic/index.php?option=com_info&id=1534&catid=65&task=info&lang=en
  23. Sorry to burst your bubble, but if you check the AutoLanka classifieds, you can find half a dozen of these for sale. And most of them are the Swift RS which is a better grade (body kit, spoiler, alloys just to name a few). than the one you've posted pictures of. When you said "limited edition", did you mean "limited options"?
  24. As I said before, if this isn't the cherry on top, I don't know what is. Not everyday can we submit our daily into a drag race and win. Congrats machan! Kudos to the pit crew as well. Sounds like they had their work cut out for them.
