Autolanka Funniest Moments
Apparently it's supposed to be a "Mustang" now. At least that's how the news is going around: http://www.apisrilankanbro.com/bro/3379 "Thada thada bro!"
Tire Air Leak
Did you try the spray bottle method? Basically fill a spray bottle with soapy water (shampoo works best) and spray all over the tyre and carefully look for bubbles. Pay close attention to the bead of the tyre (both sides) and also check the valve stem as well. Pretty simple DIY job and works better than submerging in water if the leak is very small like yours.
Honda Grace Gearbox question
Check the response below:
Exactly. Manufacturers sometimes are known to severely under estimate certain service requirements. One thing I have first hand experience is the TC-SST transmission currently on my car. The service schedule says the first oil change needs to be done at 90,000 km! Experts all over the world strongly suggest changing oil and filter every 40,000 km (some even suggest shorter intervals like 20,000 km for track cars) due to the design of the unit. This is actually one of the reasons the earlier TC-SST units gave trouble. People ran with old oil close to 100,000 km, and naturally the transmissions failed. Not saying this will happen to every car, but this is one instance where "manufacturer specification" was just too infrequent. The thing with agents and dealers is that they do everything by the book. So they don't even open up the transmission and clean the pan (not their fault - its not in the service schedule). For a country like Sri Lanka where we constantly strain our gearboxes driving abruptly and crawling in traffic half the time, it doesn't take 15 years for these filters to get clogged. So taking the car to a separate garage every 40,000 km or so and doing an ATF change where the pan is removed, cleaned, filter is changed and gasket is replaced is actually a good idea IMO. The bottom line is that the agent follows a reactive approach whereas consumers prefer the option of carrying out preventive maintenance. On the topic of transmission maintenance, sealed transmissions are becoming more common now. What that is basically a car with a maintenance free transmission. I believe some manufacturers including Mitsubishi and Hyundai have already stepped into this scene. In fact the TC-SST transmission is supposed to be "sealed". You break it, you replace it! However, many workshops now carry out successful overhauling of these transmissions.
Peugeot 406
Sorry I missed that in your earlier post. Was an ECU reset done after replacing the sensors (i.e was the battery disconnected and reconnected after installing new sensors)? If yes, how many kilometres have you roughly driven since the repair? Also, was a diagnostic scan done?
Sorry, just seeing this. The filter is not a service item from what I remember. It's considered to be used for the lifetime of the vehicle (which is usually about 15 to 20 years max). Also, from what I have seen in workshop manuals, most manufacturers just recommend a "drain and refill" procedure. The gasket that comes with the kit is the one for the transmission oil pan. In order to access the filter, the pan must be taken out, and the gasket should hence be replaced. Most mechs use gasket maker to seal it up.
Peugeot 406
My first guess is that there's a "dead spot" in your throttle position sensor. Get the sensor checked (simple resistance check throughout it's rotation range, observing sudden changes in resistance). If the sensor is faulty, replace.
Unusual Tire Wear
Loss of pressure isn't the issue here. It's chunking as seen in the photo above. And under-inflation usually causes even wear close to the sidewalls of the tyre. Also, the article in your link says 1.5 PSI loss is for 32C ambient temperature which applies to car that sits in a garage all day. An asphalt road can heat up to twice that much which is more likely what applies to a car that's driven daily in the hot Sri Lankan climate. As the article correctly says, this heat causes exponential air loss. The remedy is to check and maintain tyre pressure weekly.
Unusual Tire Wear
Can you explain how that will solve the issue?
Suzuki swift beetle indian
Can you please stop opening multiple threads for each question that comes into your mind? You couldn't find because you didn't search properly. Also: If you have related questions, you may ask in a relevant thread.
## Post Whoring - Part 3 ##
- Wheels corroded.
That is your brake disc. And the corrosion you see is oxidisation on them caused by water. Driving the car and applying the brakes a couple of times should cause it to disappear. And yes, it's normal for discs to develop surface rust when left wet.- Suzuki swift beetle indian
This has been discussed before. Please search the forum. http://forum.autolanka.com/topic/4754-difference-between-indian-and-japanese-swift/- The Ford Focus Thread
Almost all modern cars come with a motor speed controller that allows the fan to run at different speeds depending on the temperature of the engine. I'm quite sure your car also has one (a black box mounted on the radiator fan bracket/shroud). If it does, you can't simply use any old motor and expect it to last like the original one did, because the speed controller is designed to work with a motor rated for that. I guess your replacement motor failed due to this. It can also be a faulty controller module as well, that's not outputting a stable DC voltage - I doubt this is the case. So try to find the original motor or if you have the original one with you, check if it can be repaired. Although most of these motors are "sealed", they can be repaired with the right tools if you have no option. I have repaired a few myself. You also might want to check the output of the fan controller module if there is one. A simple voltage/current test with a multimeter while AC is on and off should give you two stable readings.- Autolanka Rc Build Thread
Ford F-150 Build I began the restoration of my Ford F-150 1/12 scale truck. I took everything apart and cleaned the chassis and prepped it to receive the new electrics and suspension. Here are all the parts in the chassis: The circuit board is just specially made for this truck, so no replacements to be found. I will have to hook up a receiver with an ESC to get it to drive the motor. The white plastic thing on top of the circuit board is the steering servo. It's actually a small motor coupled with a few arms to convert radial motion to lateral motion. I'm going to replace this with a regular servo. I will have to fabricate or buy matching steering arms and linkages as well. The motor: the one that's on the truck works, but it's a low voltage motor (6V by the looks). I connected it to one of my RC batteries, it ran and started to give a burning smell when I realised it's a motor rated for a lower voltage, so I may have to either make a voltage converter circuit or find a 7.2V - 7.4V motor of equal size. The motor mounts directly to the transmission, so if I'm unable to find one, I will have to do major fabrication work on the transmission housing. Fingers crossed on this. Also, note the rims - I'm gonna have the time of my life trying to find tyres that match because of the difference in diameter between the inner and outer sides of the rim. I think I will have to settle for new rims altogether + tyres. So bottom line, this is what I ended up deciding on: - Traxxas XL5 ESC - 540 7.4V motor (Tamiya or Traxxas) - Savox steering and shift servos (shift servo will be a smaller one) - Traxxas 3 channel radio system (drive, steering and transmission) The rear axle with two speed transmission. The red switch is to switch between low and high gears. I'm hoping to hook up a servo to this switch so that I can remotely switch gears from the transmitter. Inside the transmission. I have never opened up this transmission, and for something that's over 20 years old and after being bashed really hard, I was surprised to see how good it still looks. The gears look brand new and still has the new plastic smell that immediately took me back to the first day I got this. The shafts are copper and the red switch is actually the shift fork inside the transmission. Such a simple design.- Autolanka Rc Build Thread
Thanks Peri. I'm absolutely loving it! Already ordered a second set of rims and thinking of ordering a lighting kit as well. Some updates on the Tamiya: I may have said earlier that I want to drift the car although it's a rally spec Subaru. So I got myself another set of wheels. Planning to install plastic drift tyres on them. They were black, but I loved the design, so I got them with the intention of painting them in gold. This is how that went, some primer and then gold. The offset of these rims are a bit lower than the original Subaru ones, so they sit perfectly flush with the wheel arch. They don't look perfect with the rally spec tyres with that really coarse tread, but will look okay once the drift tyres are installed. The car looks wider with these on as well. Installing the rims gave me an idea, why not paint the brake discs in silver (they're black out of the box), so I did! Due to the less number of spokes in new rims, the discs can nicely be seen through them. A bit more detail on an already detailed car.- Suzuki Liana 2002 High Rpm At Idle....
Please stop responding to old threads just to bait people into clicking the link to your page populated with ads after each paragraph.- Unusual Tire Wear
Although drive goes to the rear, there is a considerable amount of force exerted on the front wheels under braking and cornering. Braking especially because the weight of the car is shifted to the front. If the tyres are old and brittle, chunking can happen. However, since we can't rule out suspension issues, I agree to getting alignment checked once more (special attention to negative camber and toe out). You might want to swap the rear wheels to the front after a balance before the alignment, just to make it easier to observe wear and to minimise risk of a blowout.- New Update on AutoLanka Forum - 30th July 2017
- Unusual Tire Wear
It's called "chunking" and caused by various reasons including excessive heat, aggressive driving, deteriorated tyre compound and incorrect camber/toe. In your case I think your tyres are at the end of their lifetime. 5 years sounds about over the limit especially in Sri Lankan conditions.- Toyota Land Curiser 200 Diesel - Minister permit vs Parliament permit models
- Hyundai sonata 2001 petrol 1,970cc
Pls kindly search the forum.- Toyota passo vibration problem
Welcome to the forum and congratulations on the car. Did you get all engine mounts replaced or just one (because you said "mount")? The are at least 3 mounts holding the engine and transmission in place, and all of them need to be replaced together to avoid premature wear of new mounts due to the inability of older mounts to absorb engine vibration as much. Also, does your car idle properly at about 700 - 750 RPM? If you don't know the history about when the last tune up was done, it would be good to do one.- Honda Civic Vtec Swap
Sorry I misread your original post about the car having a conventional automatic transmission. I've seen this done on manuals with no issue at all, but I'm not quite certain about issues with CVT and conventional AT. But I reckon you might be able to find which exact ECU you must use to get this to work by doing some online research on the many Honda forums out there (honda-tech.com, d-series.org etc.) Also, there should be other Honda enthusiasts on the forum who might be able to point you to a Honda expert who will be able to shed some light.- Honda Civic Vtec Swap
Your original transmission should work without any issue. That shouldn't even be your major concern IMO because you need to figure out how to wire up the VTEC oil feed and importantly, wire up the new ECU so that VTEC kicks in (yo!) properly. This is a very common conversion, a simple Google search would reveal a lot of results. Just search for "Honda D15B Mini-Me" - Wheels corroded.
