[Q] JDM Starlet, uncommon gauge cluster.
From the other two gauges, it looks like a EP82.
Petrol Smell In The Cabin
There shouldn't be any fuel smell inside the cabin regardless of how much fuel is left in the tank. You should be able to easily removed the back seat and remove the hatch yourself to visually inspect if there's a leak. If you don't find anything, take the car to a mechanic for further inspection.
My first guess is that there's a small leak in the fuel pump gasket or one of the fuel lines is leaking fuel. The fuel pump is located under the rear seat. There's probably a hatch that needs to be opened to access it. A simple visual inspection should reveal any leaks.
Could be due to a fuel leak somewhere. What's the car?
Lifespan of Radiator Hose
What I've observed is that most new vehicles come with spring type hose clamps for radiator hoses. I think they're a brilliant design because: - They're self-tightening. So lower chance of over-tightening and damaging hoses. - They have a flat surface that comes into contact with the hose, so the pressure is evenly distributed - Very easy to install and remove. Just a pair of needle nose pliers, squeeze and pull. Done! - Durable. I am yet to see one of these things break or fail. The thread in the screw type clamps are known to split after you remove and re-install them a couple of times. With these clamps however, you need to buy them matching the proper size. Because if you use a very small clamp on a hose that has a bigger diameter, the clamp will have to stretch further than it has been designed and might cause problems. Similarly, if you buy a larger clamp, it might not hold the hose in place properly.
Need Advice On Mini Modles
Thank you. I figured as much, as I've never heard these vehicles being purchased by ordinary (non employee or non big shot) people.
Upgrading the front bumper..
@Hoonigan or @c1nder might be able to answer.
Ford Laser 2000 - Manufactured in Japan or Singapore
Haven't even bought the car... ... Worried about selling already. Sigh. If you are so concerned, buy the car and stick something like this on.
Not smooth when relaesing the clutch pedal
Thanks for responding back. The "fork" in the CS is actually the slave cylinder coupled with the release bearing. There's no "fork" per say, but the terminology is still used here even by the agent. Anyway, glad the issue was resolved.
Just curious (sorry for hijacking the thread), how often do these auctions take place and how's the general public informed of them?
To add to Rumesh88's response, the lifetime of hoses depend on how well your cooling system is operating as well. For example, if the radiator cap doesn't allow for the proper controlling of pressure within the system, the excessive pressure build up might cause a hose to give way. A few other reasons I can think of, that could shorten the lifetime of hoses are the use of substandard hose clamps, improper installation and using abrasive liquids (ex: kerosene) to clean the engine compartment. But if all is well, hoses should last the lifetime of the vehicle.
There is usually a reserved character/digit in the chassis number that tells you where the car was actually assembled. This is probably the most accurate way of finding out the exact country (or even assembly plant). Workshop manual or the manufacturer's website should have the decoding information.
Toyota Allion Nzt260 (Cvt) Gearbox Issue
There's no way of checking the "maintenance history" of a gearbox or engine. The closest you can get is to check the condition of the oil (bright red/pink) and how the car drives. That too only gives an indication of the most recent oil change only. A full diagnosis doesn't reveal maintenance history. At least not with the Allion. A diagnosis only reveals if there are issues with the engine management system and related components. So the best way is to check maintenance records.
Townace 2008
My first suggestion would be to find a different competent mechanic. This guy doesn't seem to know how to do a simple gasket replacement and now giving excuses to rip more money off you by hiding the fact that he messed up. After gasket replacement, was the cooling system fully drained, flushed and refilled? This needs to be done to remove oil in the cooling system. Depending on the extent of the leak, an engine oil flush and refill also needs to be done. On a related note, make sure the water pump is working properly and not leaking. You can check if the water pump is working by letting the car reach operating temperature and squeezing the top radiator hose with your fingers (be careful as the hose will be hot) and feeling the pressure within the hose as you rev the engine. If you can feel the pressure increase, this indicates proper operation of the water pump and thermostat valve. All in all, your cooling system needs to be checked fully.
Townace 2008
Welcome to the forum, and congratulations on the TownAce. There might be two issues here. The first issue is your engine overheating. The second one is the consequence of running with an overheating engine - the gasket leak. You need to address both issues at once because if you only replace the gasket without addressing the overheating issue, your engine will run hot again and blow the new gasket as well. This might not be the case, but a possibility. Do you have any of the following symptoms: 1. Does the vehicle lose coolant? 2. Do you see an oily residue floating on coolant in the expansion tank or the radiator? 3. Do you see white smoke from the exhaust? if the answer is "yes" to any or all questions above, you should get your gasket replaced. It will require dismantling the valve body of your engine, but should be a pretty straightforward repair. The overheating might be due to the gasket leak itself, but you need to make sure if your cooling fan(s) operate properly. Get them checked and keep an eye on the temperature gauge to see if it stays normal a few hundred kilometres after the repair.
- Honda Grace or Toyota Axio
- gear problem
- gear problem
gear problem
Hope it was a proper ATF change where the oil pan was removed, cleaned and filter replaced instead of just draining and refilling with new oil. If it was not, I suggest doing it properly. If you're sure the oil change was done properly, then the symptoms suggest that it could be due to issues with one or more of the solenoids or the valve body itself. A thorough test and clean up of the valve body might reveal the issue. Take the car to a good automatic transmission mechanic and get them to have a look. Did you get a "check engine" light at any point? If you did, get a diagnosis done to retrieve the code and that will tell you where the issue is. Failing solenoids should cause the check engine light to light up.
- gear problem
Toyota Cami
Yes, the Cami is the best. Now stop responding to 8 year old discussions.
Honda Grace DCT transmission issue is with only 2014/2015 model, not in 2016. is this correct?
Honda officially announced three recalls for their dual clutch transmissions and all of them were for their hybrid variant which came with the Fit Hybrid and Vezel Hybrid. (Both have 7 speed i-DCD transmissions with integrated motor). I'm unaware of any recall announced for the Grace. However, if the Grace also shares this i-DCD transmission, it may have been affected. Honda suspended production of the models when the issue came up, so the resumption of production only suggests that they rectified the issue in the newer models. Also, the issue was firmware related and from what I read, was solved by applying a firmware update. Having said all that, I have seen many Honda Vezel owners complaining about transmission temperature warnings in traffic. The Sri Lankan hot climate, coupled together with how people drive in traffic (abrupt braking, sudden acceleration etc.) is extremely strenuous for any transmission - let alone a DCT. The Vezel however has a dual dry clutches which makes the situation even worse because rapid up and down shifting (in traffic) heats up the clutches and causes the transmission to throw an error. So if you have a DCT, your driving style (in this case, the entire country's driving style )also can contribute to the longevity and behaviour of the transmission.
- 22 replies
- 5
- gearbox
- transmission
- overheat
- issue
Nissan Leafe
Please search the forum before opening new topics.
Fit gp1 or insight or civic fd3
150K within 5 years is 30K per year. So an average of 80Km per day. Quite possible for someone travelling around 50Km to work (one way and assuming 260 working days per year). I know many people driving from Colombo to Katunayake on the expressway and a couple who do daily trips on the southern expressway. Probably not a common occurrence, but it is quite possible.
Failure In Emission Test
Since you got the repair done by them, you should probably go back to them with the emissions test report as evidence IMO. Also, what are your CO and HC readings (most recent test) at idle and 2500 RPM?
