Post Whoring - Part 2
Reminds me of a story of how being a Tintin fan actually landed myself a job... Being a software engineer, I was given a practical test and it was to build a simple website to manage ships and shipments. As sample data, I entered ship names like "Karaboudjan", "Sirius", "Aurora", "Peary" and so on. I was called in for the final interview and the interviewer (who was apparently the reviewer of my work and also a Tintin fan) and his first question was "A Tintin nut are we?" We spoke about Tintin for about 10 minutes and then.... I got the job.
- Post Whoring - Part 2
Mitsubishi Lancer RalliArt
Thanks Supra! Much appreciated. Tell me about it. I think they are too sensitive to carbon deposits on the throttle body. One morning I started the car and this is what I was greeted with: https://vimeo.com/142104361 Glad it was sorted after the IACV was cleaned.
- 108 replies
- cy4a
- twin clutch
- cy
- sst
Vehicle Service - Maruti Suzuki Alto
Fuel consumption depends on a lot of things starting from your driving habits, whether you drive in heavy traffic and the condition of the car etc. Since you have 25,000km on the clock, I suggest getting a fuel system cleanup (this is what is referred to as a tune-up for EFI vehicles) done. Since your car is not under warranty, you don't have to go to the agents to get a tune-up done. PreseaLover got a ultrasonic injector clean-up and a throttle body clean-up done recently from ASNU Lanka in Battaramulla. Read it here. The cost should be similar for you and this I believe will be cheaper than the agents.
A little update: After driving the car for a few hundred kilometres, I noticed a few issues: 1. Erratic idle RPM The first issue was that the idle RPM was jumping around between 500 and 1000 when the engine was warm. On a cold start, it goes up to about 2000 and slowly comes down as the engine warms up, but still the RPM needle was just moving about. I got the throttle body cleaned up and this issue went away. Noticed that the agent had only cleaned IAC and had not done a full throttle body clean-up. I was advised to get a upper cylinder clean-up at the next service. Something very commonly done here in Australia and this is the general "tune-up" you get here. 2. Rattling gearbox when warm Experienced a faint rattle from the gearbox (with the same kind of feeling that you get when the clutch is slipping on a manual). The transmission oil was flushed and refilled with a replacement transmission oil filter (the oil was really expensive!) and the issue was solved. The transmission shifts much much smoother now and is more responsive as well. The reason behind the rattle was explained beautifully by the foreman there. The wet clutch packs are pressed against each other using the transmission fluid (this is explained in one of the articles I shared previously on this thread). When the oil goes bad, it is unable to generate enough pressure on the clutches to engage them properly, causing them to slip and emit a rattling sound. He also advised that the issue might resurface again, and to bring it back if it does, so that they can open up the transmission and give it a good clean-up. 3. Brake squeal when cold I advised the agent to replace all brake pads, but they got back to me saying that the brake pads have been replaced only 10,000km ago and that the pads are still in very good condition. They had cleaned the brakes and now the squeal is no more. 4. Suspension noise when going over a speed bump I felt that this comes from the upper strut mounts, and I was right. The shocks, bushes and linkages are all good, but the upper strut mount needs to be cleaned and re-greased because of excessive gunk and mud build up. To do this, the entire front suspension needs to be taken out, but they didn't have time to do this. So this was put off until the next service. However, I took the car and washed the wheel wells with a high pressure washer and I didn't hear the noise afterwards. Apart from the above, the routine service was done, which includes an oil change, topping up of all fluids and a full inspection of the entire car followed by a diagnosis. She feels even better now.
- 108 replies
- 5
- cy4a
- twin clutch
- cy
- sst
With all due respect to gayanath, I have to disagree. To get the best out of a vehicle, it needs to be maintained properly. Failing to do so will result in nothing but premature wear of the engine and whatever components that were left without being looked into at the specified interval. Let's take a simple example: All manufacturers specify a replacement interval for the timing belt. In most situations, the replacement interval is 100,000km. This doesn't mean that the timing belt will snap off at 100,001km. It might survive much longer in real life, but driving without replacing it is a huge gamble. Having heard of many horror stories of timing belts breaking off, this is one risk no one should take. It is similar with everything else. fluid replacements can greatly improve the driving conditions of the car. Brake fluid attract moisture and lose it's viscosity over time - resulting in poor braking performance. Coolant also lose their heat absorption properties over time and can cause the system to corrode as well. There is a reason behind the manufacturer suggestion each one of these. The dusty, humid environment in Sri Lanka causes carbon build-up in the intake manifold and throttle body of any car. This needs to be cleaned out periodically to ensure a smooth drive. You can of course drive with all the carbon and gunk in the intake, but your car will simply not perform or drive the way it is supposed to. It will not be as economical as well. There are many sensors attached to the engine that either get covered or clogged up with carbon, resulting in sending faulty readings to the ECU. The ECU on the car can only control things to a certain level. Rookantha, is the car in question still under warranty? If so, wouldn't skipping a periodic service at the agents void your warranty?
Eva! My Journey With An E36
Excellent work! I miss reading threads like this on the forum.
Was actually thinking the same thing while I was watching the clip. @4:48 . That cop can thank his lucky stars! Most of the accidents seem to have happened at junctions at which there seem to be no road markings (give way lines, lane markings etc.) at all. That junction near Lake House roundabout is a perfect example.
2008 Mazda Demio
No worries mate. I gave my father the location. Let's see how it goes. Thanks again!
- Nissan Presea
2008 Mazda Demio
Well guess what! My father told me that the driver's side mirror stopped retracting and opening a couple of weeks ago. Seems to be a common issue on the Demio. He said that he got it repaired once from a place in Thalawathugoda, but it only worked for a couple of days. Will show him this thread. Thanks SamG for the response. Will contact you if I need more info.
Top Gear/fifth Gear/jeremy Clarkson Videos!
The former Top Gear hosts have started filming their new Amazon showhttp://www.theverge.com/2015/10/7/9471643/top-gear-hosts-amazon-show-jeremy-clarkson
- Nissan Presea
Best Place To Fix A Riverse Camera.
I'm pretty sure OP was referring to a shop where he could get a reverse camera installed without damaging the body and not the actual place on the car body.
Dear deadpool, Please search the forum before opening new threads. Most of the things you have asked so far have already been discussed on the forum including reverse cameras and car navigation. Please search the forum as instructed here and use one of those threads to ask your questions. Redundant new threads make it impossible for new members like you to find information you're looking for. Cheers!
Nissan Presea
It totally WAS your day. You got back your money, the biker didn't crash into your car and you were only 15 minutes late. If it was not your day, you might have not noticed the bill in the first place, the biker would have crashed into your car and you would have had to attend to the accident and would have missed the client meeting altogether. Two ways of looking at it.
Buying First Car
Please search the forum (follow instructions given here). Your questions have already been answered many times.
- Sudden Vibration Of One Side Of The Vehicle
Just For Curiosity
Wheel alignment and balancing are two different things. Were all your wheels balanced as well?
Sloshing/splashing Sound From The Fuel Tank
Good work! That doesn't look bad at all. The unpainted metal bracket is the door pull support and it's natural for it to develop surface rust. I sanded and painted all four when I had my CS3.
Just For Curiosity
No, it's not normal. 1. Inspect your tyres for abnormal wear and lumps. If worn abnormally, get a wheel alignment and balance done. Balancing is important. Consider rotating the wheels before the alignment. 2. Check if one or both of your front tyres have a puncture repair done on them. Having one can cause the wheel to lose it's balance. If this is the case, move the wheel to the back or balance the wheel. 3. Get a wheel balance done anyway because one or more of the weights might have fallen off that causes the wheel(s) to lose balance. 4. If none of the above solve your issue, it could be due to a font suspension/drivetrain/bearing problem.
