- Carburetor Tune Up.
Lancer Ex
Welcome to the forum! As far as I know, only the initial batches of the Lancer EX had this ABS sensor issue, and that too was repaired by the agent under warranty. So if you're going for a Lancer EX which was bought down before 2010 (Not sure if that is the actual year it was corrected out of the factory), you should check the service history of the car with the agents to get to know if the ABS sensor issue was actually repaired. For a new EX, you shouldn't worry about it. This was discussed on a few other Lancer EX threads as well.
- Nissan Sunny N16
Tire Size And Ground Clearance
70R means that the height of your sidewall is 70% of the width of your tyre. So, by going for 185/70R14, your sidewall height will change by about 5% and it will result in a slight speed 'o meter (and thereby the ODO as well) change. 1. Refer to this link to get a good idea about what kind of a change you'll be looking at: https://www.tacomaworld.com/tirecalc?tires=175-70r14-185-70r14 2. Your tyres will not touch the wheel well because of a 7mm change. EDIT: Nevermind... just saw the attachment and the manufacturer has indeed specified that you can use both tyre sizes. You're all good. EDIT 2: Corrected a typo
My First Car - Demio Dw3W
This could be due to a worn out bearing on the 5th gear. Instead of replacing the entire gearbox, you might be able to take it apart and inspect the gearbox first (especially the 5th gear and the bearing). If the bearing is worn out, you can replace it and then everything should go back to normal. This would cost you a lot less.
:::::::: Autolanka New Look 2015 ::::::::
I have a bit of a different view about the new site. Just sharing my opinion here. - I remember reading on this thread that the lack of the "buy" and "sell" buttons (like it was in the old site) is something bad. But if you really look at it, you can simply click on the "search" button which is identical to what the "buy" button did. Similarly, the "create ad" button in the new site is similar to what the "sell" button did. So this functionality is still there. - The format of the ad is pretty much the same as the previous site. So there's nothing new to get used to there apart from the new details that have been included. - The advanced and extended search filters (year, reg number, etc. etc) are optional. They can be left out blank if necessary, so this again makes the search kind of similar to the previous site (easy) in a way, but at the same time, giving some flexibility to a user who really wants to dig in to specifics. I really missed filtering ads based on the YOM and the price and the addition of those filters is just great! MADZ, Here are some issues I noticed after just a couple of minutes of playing around: - The "Advanced Options" link beneath the three radio buttons (beneath the Keyword Search text box), does nothing. It expands and collapses the three radio buttons alternatively. Not sure what the expected functionality is. (Just saw that this works fine in the search results page) - In the home page, "Car", "Van", "Bus" etc. are correctly referred to as "Vehicle Type" whereas in the search results page (search-results.html), they are referred to in the "Body Style" dropdown list which is entirely misleading. Body Style is something totally different that comes under Vehicle Type. For example, if you select "Car" as the "Vehicle Type", you should get "Sedan", "Coupe", "Convertible" etc. for "Body Style". - The "Any" dropdown list for the Price selection is redundant. It should be removed. When the user does not specify a price, "any" should be assumed. - The measurement unit for "Engine Capacity" should be stated in the label as "Engine Capcity (cc)". Users can easily enter 1.0 to 1.8 and the results would go blank because the system searches based on Cubic Centimetres. - The page refreshes when the "from" or "to" values are entered and tabbed out from the field. This is very irritating. The values should be submitted asynchronously (using AJAX maybe) so that the page doesn't keep refreshing when the user does the smallest refinement to the search parameters. - Clicking the "Clear" button on the search results page throws a 404 error. - If you enter a single quote in the "Registration No." field for example (yes, I was trying to break your database, lol ), the single quote characters are preceded by a backslash. I believe you guys do this to escape the single quote, but the end user shouldn't see this. In an ordinary scenario, no one would enter those characters, but just a cosmetic issue. - Any reason why each model list has the make as an option? For example, if you select Mitsubishi as the "Make", and check the "Model" dropdown list, you see an option that reads "Mitsubishi". Similar for Toyota and Mazda. That's all I checked. - When the browser window is restored to a smaller size, the pop up dialog shown when "Check Vin" is clicked (ad details page) can never be closed, because the close button goes under the top banner of the site. You need to scroll to the top of the page after the "Check Vin" dialog appears to re-create this. (Increasing the z-index of the div tag with ID "modal_mask" fixes this issue. It's currently set to 1 while the banner has a higher z-index) Hope this helps you resolve these issues. Keep up the good work! EDIT: The single quotes are preceded by a backslash and not a forward slash. My mistake.
The Mazda Demio Thread
Very nice (again the bodykit and spoiler)! We have green Demio twins on the forum. Saw an aftermarket bodykit for the Demio on eBay and it had the exact front bumper air dam that you've got. I'll definitely be bringing down a kit when I come to SL. It had a similar air dam for the rear bumper as well. Has yours got that too?
Fast And Furious
Watched it in the cinema a couple of days back and I think it's still not the best movie in the series if you only take the story into consideration. Dom, O'Connor and the crew seem too much like superheroes who can endure anything. But it's a movie that should be watched. The last 10 minutes just kept me thinking about Walker's death for days. I was sitting close to a lady who kept crying out loud non stop throughout the last scenes. It's only natural that Walker's death had a strong impact on the cast and whoever linked to the production of the movie as well.
- Post Whoring - Part 2
Help Me With My Mazda Demio De3Fs 2007
1. Yes, the same principle applies to engine oil and change intervals for engine oils are shorter in SL compared to many other countries. 2. In countries like USA and Australia, you will not find people changing engine oils every 5000km or so. The average service interval ranges between 12,000 - 15,000km and this too changes depending on which state you live in. Hotter or colder, dusty or coastal states have an additional service between the service interval. Most parts of the States and Australia are far less hotter (and a lot less humid) than Sri Lanka, therefore the longevity of the oil is shorter in countries like ours. 3. The firs thing to note is that the transmission only takes a few minutes to reach operating temperature, therefore the damage remains insignificant unless the car is pushed too hard. Also, in such countries, people warm up their engines for a few minutes before moving off. The oil circulating through the radiator ensures that the oil is never too cold to a point that the transmission is affected. Your argument is sound (and valid), but my opinion is that the damage remains insignificant, hence the longevity is not affected for an average car.
- The Mazda Demio Thread
Well there you go. Thanks for the info. I guess the CVT oil change on mine was done on the agent's recommendation, because the mileage, oil and the cost matches what they gave you. Any kind of oil breaks down faster when used in hot conditions and even in humid conditions. Sri Lanka is both, so oil wears out sooner than it would in a cooler and less humid country. There are many other factors as well (like idling for too long and repeatedly driving very short distances).
My father uses a 2008 Demio with CVT. Identical gearbox to Sameera's. @Sameera, I think you should call up C0l0nial and get their recommendation about the service interval. Fookie is right, the US owner's manual does not have any information about CVT oil change interval. The interval might be different for SL conditions and C0l0nial might have a good recommendation, despite this being a JDM.
The car was on the classifieds site twice, and was only active for less than a day on both occurrences. My father is really happy with the car and is taking good care of her. And yes, you guys should share photos! EDIT: By the way, just noticed that the AC controls are different in aruna1's car.
I don't think the service interval is that short. The history of the Demio I got has a CVT oil change done at 40,000km with a bill of 26,000 from C0l0nial. I'm pretty sure my father told me that the interval is 40,000km. He also told me that the agent only recommends the Mazda genuine CVT oil only they import. Not really sure if there are others who get it down as well.
Thanks fookie! I know that it has automatic headlights where they come on when it's dark, but not really sure about auto levelling. I'll ask my father and get back to you on that. I guess you mean the indicator with the headlight symbol with two arrows pointing up and down from the beam? If your headlights have auto levelling, you will see an additional set of wires running into the headlight housing apart from the high, low, turn indicator and park indicator lines. If yours has the indicator and it goes off with the other indicators, you probably have auto levelling headlamps and the system is working fine. Try switching on the headlamps while the car is stopped on a slope (facing uphill). You will see the beam adjusting itself for a brief moment of time. This is better done at night.
He probably got it at a lower price due to the friendship with the registered owner. But it was sold at the same price it was advertised at by the first owner, so I didn't mind. Honestly, I was very skeptical at first, but my dad ensured that it's a legitimate deal.
Most Mazda2s I see in Australia are manuals. And all of them are 1.5L. Remember the car that was in Kotte? This is that car! Long story short: The owner gave it to a friend who was planning on giving the car on rent, circumstances changed for him and he decided to sell the car. Coincidentally, the guy was a lawyer too.
Clutch System
Good question. In one word, the answer to your question is: Friction. The friction material used to manufacture a clutch has a very high coefficient of friction, which doesn't allow it to slip that easily. The pressure plate secures the clutch against the flywheel and itself, so that the clutch does not slip. As long as the surface of the clutch has enough meat (to grab on to both the pressure plate and the flywheel), and as long as the pressure plate is applying the required amount of force on the clutch, it will not slip.
How Can I Avoid Body Scratches In A Black Colored Vehicle?
Fix it pens are usually for clear coat scratches. So if the scratch is deep that it has reached the base coat, primer or the sheet metal itself, then the pen will not work. In such cases you'll need a scratch repair kit which usually consists of the base and clear coat in bottles with an application brush. Some come as pens also I guess.
- Car Engin Scan Test
Fuel Consumption Of Hyhundai Elantra
What more advice do you need? The link I shared above has figures for the Elantra. And if you really did some reading up on the forum, you would find more info. Here's another one: http://forum.autolanka.com/topic/13698-what-would-be-the-best/?p=207583
Autolanka Mega Movie Thread
The second trailer for Terminator Genisys is out and it's just jaw dropping! This is the movie to wait for this year for me, being the Terminator freak I am. Have a look:
