Davy
Top Contributors
  1. Thanks! The few hatches that are around should be facelift examples then. They've taken a good looking car and made it look even better. It's very popular in Australia and the two door Fiesta ST is also seen occasionally. Anyway, I'm guessing the price of the fiesta hatch is gonna be a bit over my budget at the moment though.
  2. Thanks, Good to know that the dash can be locally converted. Thanks for the suggestion The Don. I actually thought about this, but I couldn't find any Fiesta hatchbacks around. About spares, yes it's kind of an important factor and I'd rather have my father find spares easily. He used to love getting grease under his fingernails, but not so much now.
  3. That's actually the second car I called and this too is sold. This actually is not a basic version right? It does have fog lamps, double din dash, auto headlamps, rain sensing wipers and so on. The only thing I see missing are projector headlamps and multi-function steering. I'm currently doing exactly what you said and looking for one with a tachometer... and CVT possible. If it has fog lights and the double din dash, then great! If not, I'll probably buy the kit and install them I guess. Did you fix the double din conversion kit after you bought the car or was it there when you got it? I hope the multi-funciton controls work on the aftermarket player; I believe they do.
  4. Thank you for the response. 1. Makes sense as to why the facelift version is nowhere to be seen on ads. Like fookie has said above, it could be due that importers are reluctant on bringing down non-hybrids. Especially when it comes to hatchbacks since there are options like the Fit Hybrid and the Aqua. 2. There's more in existence then than I initially anticipated. 4. Lucky you. Hopefully I'll find a similar one. I found out that the factory spec fog light kit is also available on eBay, similar to the double din conversion kit. So I'm wondering whether it's okay to go for one without them. The tachometer is a must and CVT is nice to have. Glad to know that the agents and third party workshops are good as well. It's just about finding a good example now.
  5. Davy replied to aadl198733's topic in MITSUBISHI
    You don't have to spawn multiple threads on the same subject. Your "Evo Bodykit" and "Beat Silencer" threads are all part of one project right? So stick to one thread. Please. The simplest answer to your question is "No". The Evo has a wider rear end. The rear doors, quarter panels are different from the Lancer, so you'll have to get down the entire evo conversion kit if you want to do a proper job. Some swap the entire rear end while others make do with a wide bodykit and change the tail light inserts. Ricing up a car so that it looks and sounds like something it's actually not is frowned upon on the forum. At least by most members. So tell us about what you are planning to do with your Lancer. A cosmetic makeover or the real deal?
  6. Thought so. I removed the upholstery and greased all four doors because of this issue. Water drains directly over the central lock actuator (which is sealed), but the actuator motor shaft (and linkage) tends to corrode and get stuck when water comes into contact with it. The photo below is of a CS door actuator. Note the metal tip at the top of the actuator - this is what gets stuck - most of the time. Due to this all the linkages up to the lock cylinder "freezes" in one position making it hard for you to turn the key. At least that was the case in all my doors. Not sure if using WD40 on this part is a good idea because if the chemical gets inside the housing, it might damage the moving components inside. So I suggest spraying some WD40 to a piece of cloth and cleaning the shaft with the cloth. Then apply a liberal amount of grease to cover the entire shaft (and the linkage that looks like a small metal plate) so that water does not come into contact with it. Did the trick for me on my CS3. You can spray WD40 onto the rest of the mechanism as others have suggested.
  7. 3. Good to know that more are out there. 4. I understand about the double din player. I just thought having one opens up options like having a reverse camera and stuff as well. Again, it's good to know that the car is spacious. My father is an average sized person, so I'm hoping he'll be comfortable. As for enjoyment, it'll be my father who will be enjoying the ride then. I will definitely drive it when I come down for holidays. Watched a few reviews as well and the comments about the bumpiness was mentioned in more than one review. I too assume that it's not something to worry about much, especially because my father will just be driving the car to work about 20km a day (return trip) and maybe a quarterly trip outstation towards Kurunegala, so it should be fine. Fuel is also not much of a concern because he is provided a good portion of fuel by his company. Thanks for the pointer about the mounts. Most 2009 - 2010 Demios that are up for sale have done between 40,000 - 60,000kms on average, so depending on where and how the car was driven, your point maybe valid. I contacted C0lonial Motors to inquire about spare part availability and they replied saying that they cannot provide information without me providing them a chassis number. It actually looks like C0lonial Motors has built up a good reputation though, regardless of how long C@r M@rt was the agent for Mazda. Apart from the agents, I believe M@zna Motors in Pepiliyana will also undertake repairs for the car. They're supposed to be good. Thanks again!
  8. Thank you! 3. Have you seen other Sport grade Demios besides the one that I've provided the link to? 4. Yes, you maybe right. The goo-net Catalogs shared by iRage above actually has indications as to which options were provided for each model year and some of what you have listed are optional. Hopefully I'll find a fully loaded model with the aero bumpers like yours. I agree on the fact that most of the Demios are basic. I didn't actually know anything about the model before I decided to go for one. After looking around, reading up and going through ads I found out that the ones sold soon are the ones having fog lamps, the RPM meter and the double din player. All of the cars I came across that had multifunction steering did not have the double din screen. I didn't mind that because I found this and this online to address that. It connects to the multi-function steering as well (as per the specs). Since you're an actual owner of the car, any comments that you'd like to make about the car in general? I'm not worried about fuel consumption. I heard that the car handles really well compared to the Vitz and Swift. How's the space inside? And all round visibility? As for the new Demio, Col0nial Motors is bringing the export version (Mazda 2) down. You will see it on the streets soon I guess. http://www.mazdalanka.lk/mazda-21.html
  9. WoW! Talk about a comprehensive answer! Thanks a lot iRage! Knew it was something good when I saw your name before opening the thread. So the white Demio was a 1.5 Sport! Should be a rare sight though! Too bad I missed it! I guess I can now carefully go through the options of each car and get to know the actual grade. Out of all these grades, I don't think I've seen one with the SkyActiv or the one 13C-V with CVT transmission. So, I will most probably go for a DE3 if another DE5 Sport doesn't pop up any time soon. It's difficult to find one (a DE3) that has all the bells and whistles though. I'll keep my eyes peeled. Thanks again!
  10. Hi Guys, Sorry for bumping up an ancient thread, thought this is the best place to ask my questions. I'm on the lookout for a hatch for my parents and I was considering a Demio DE3FS (2007 - 2014). After calling up the best couple of ads posted on the AL classifieds, I found out that all of them have been sold real quick. It does look like the model has a good market. I have a few questions since I'm overseas and don't really get to see how these machines are doing on Sri Lankan roads. Plus this will be the first Mazda I'll be buying. 1. The Demio DE series underwent a facelift in 2011 according to my research, but I could not find any facelift Demios advertised. Arn't any of them around yet? Pre-facelift (2007 - 2011): Facelift (2011 - 2014): Note the change in the grille, bumper, fog lights: 2. It looks like only the DE3FS (1.3L) is available locally (again, assumption made after going through online ads). Are there any DE5FS (1.5L) examples around? 3. The first Demio I called was a sport with tiptronic gears, red instrument cluster and a full bodykit with strut bars... off the factory. Unfortunately it was gone (this one). What are the chances of there being other Demios of this grade in the country? 4. Did an extensive search on trim levels and I found three for the Export model (Mazda 2) - Neo, Maxx and Genki. Neo being the basic and Genki being the fully loaded. But not for the JDM. And looking at the ads on the net, the options look very inconsistent. Does anyone know the actual trim levels of the JDM? Sorry these are very focussed questions. Many thanks!
  11. Saw this circulating around the Internet and it doesn't seem to be true (at least not yet). See: http://www.roadandtrack.com/car-culture/entertainment/news/a25278/no-jeremy-clarkson-hasnt-quit-top-gear-yet/
  12. It's possible that the issue is actually not with the engine. The catalytic converter is part of your exhaust, and if it's clogged, even a brand new engine will not work as intended. Did you swap the engine only because of this issue? If so, it looks to me like your mechanic has taken you for a very expensive ride. If possible, take the car to a good workshop and get a diagnostic scan done. Explain your situation and ask them to test the fuel pressure (to rule out a failing fuel pump as MasterDon has suggested) and the Oxygen sensor values. If all is good, then you can try temporarily starting the car up while the catalytic converter is removed (not sure how feasible this is - all depends on how this model has the cat mounted to the exhaust pipe).
  13. What's the car Jor-el? Lancer CS?
  14. Welcome to the forum. Please stop bumping old and inactive threads. Thanks! Your claim about 99% of petrol engines not having timing belts is absolutely wrong.
  15. Davy replied to Watchman's topic in General
    Really? That just might be it then! Depends on the manufacturer specification for your car. What does the information card on the B pillar say? And are you running on the stock rim size and tyre size? I really doubt that 2 - 3PSI is going to give you significant ground clearance.
  16. The lack of power within a specific range in the RPM can be due to a clogged catalytic converter as well. A misfiring engine can clog the catalytic converter and cause significant back pressure at certain RPM levels which results in the engine bogging down. The behaviour is very similar to what happens when the fuel pump is faulty. I believe you can check the operation of the cat through a diagnostic scan and reading the inputs from the Oxygen sensor while revving the engine. You can also take the catalytic converter off the car and visually inspect whether it is blocked.
  17. Davy replied to Watchman's topic in General
    As the others have already pointed out, your tyre pressure is way too high. It should be somewhere around 28 - 30. While you might be saving a few cents off fuel, you are wearing out the suspension of your car faster - that's a repair that will cost you far more than what you will be saving on fuel. Also, your tyres will wear out much faster. You might want to consider all that and inflate your tyres to the recommended pressure. It should be printed on and attached to the B pillar of your car - driver's side. As for the AC, I don't think I have the right to decide what's the right temperature for you, but I believe 30C is way beyond the comfort zone of an average human being. Plus, you might want to try and wrap your head around this to determine if you are really saving money on AC: If your AC is manual, and if you have your temperature dial set a bit towards the warm side from the "max cold" position, the AC is still working the exact same way to how it would work if you set the dial to "max cold". Most manual AC systems reduce the cold by activating the heater and mixing the hot and cold air so that the air reaches a "less cold" temperature. Again, this is on most manual AC systems and I believe it's the same case for you as well. If this is the case, your passengers (and you) are suffocating for no actual gain.
  18. You can still use that thread to ask your "specific" question, because the answers you will get on a new thread (this one) will not be different from what you would get in the existing thread. We like to keep similar information together because it will help people like you search and find them much easily.
  19. Downloading Interstellar after the long wait! Yay!!
  20. Davy replied to aadl198733's topic in MITSUBISHI
    The second photo you've attached is from a company in Sri Lanka (Accolade). They do Evo bodykits (amongst others) and export them worldwide. Located in Ja-Ela. Check out their website. If I were you, I'd go for a factory spec bodykit for the Lancer as discussed here. But that's just me.
  21. Davy replied to MADZ's topic in The Lounge
    Doesn't work for me as you can see above. I'm on Chrome on a OnePlus One.
  22. Davy replied to MADZ's topic in The Lounge
    <blockquote class='ipsBlockquote'data-author="Jor-el" data-cid="274351" data-time="1426345004"><p> Ado awsome oi!!! They have corrected the error ( html tags displaying when quoting in mobile ) what a relief</p></blockquote> Really? I used to switch back to the desktop version each time I wanted to quote on my phone. Let me try if this works now.
  23. Welcome to the forum. Your question has been answered so many times. Follow the "How to search on AutoLanka" thread in the DIY section. If you have any new questions, ask in one of those threads. Thanks!
  24. It's annoying to see this thread come to the top of the list every hour. I'm all for locking it up if that's possible.
  25. Had a good laugh reading the chat. Yeah, good job trinity. You will be able to get rid of the dark spots if a bulb with 5 SMDs is used I guess (one SMD pointing at each direction).
