Everything posted by The Stig
Vitz Cvt Issue
That is most likely the problem, you haven't changed cvt fluid in 54k.
Octane 95 vs 92 for Vezel
There is a mix up My compression ratio reply was actually for tux. I thought you replied to his theory
Theoretically yes but practically dont think so. For example in Mazda skyactive engines the compression ratio is 14:1 but manual recommends to use 87 octane (92 for us here) cause they have made a fancy exhaust to reduce knock. You cant judge the octane needed by compression ratio alone. This is taking a shot in the dark, better stick to what the manufacturer has recommended.
Where To Get Low Rolling Resistance (Lrr) Rated Tires In Sri Lanka
I have these and have kind of mixed feelings. I upgraded from Achilles normal tires. I mostly bought these because I was tires of the Mazdas road noise. Definite improvement over road noise and the ride is more conformable. Acceleration is quite good as well. No noticeable difference in cornering grip and wet grip is definitely better. The ride is floaty and I don't like that, it feels a bit unstable at high speeds on bumpy roads. Breaking distance and straight line grip is quite bad and abs kicks in constantly because wheels lock up (I have a little aggressive driving style) there is also body roll because the sidewalls are soft and breakdive is noticable as well. You have to break a little harder than normal also, you might even end up eating through breakpads faster. Conscluison is if you want comfort, less road noise and economy this is the tire for you. But if you are a spirited driver stay away from these. I'm planing to swap these out soon, just not my cup of tea.
Mazda Demio 2009 Gear Box Oil Change
There are direct substitutes for Toyota and Honda oils, this is judged base on chemical composition and viscosity properties. But there is not a single substitute for Mazda mv, as Mazda owners we have all put hours of online research and read through hundreds of online forums only to come to the conclusion that a there are no suitable substitute in the local market. You can compare the chemical composition if you want. Compatibility is a broad term, most of these all in one atfs have some compatibility at selected temperature ranges. But chemical properties change based on temperature and they may not match the exact specs throughout the operating temperature range. For example if you don't have the required viscosity at high temperatures gears may slip but the oil may work perfectly in cold city driving, above scenario can still be counted as compatible but it really doesn't give the full picture.
As Davy has pointed out no he has gone the cheap and makabass way. BTW he hasnt even used Mercon V he has used Mercon LV which is a lower viscosity fluid. Take that baby out for a long drive and watch the gears slip Good luck to the unfortunate souls who will buy this car later on, may their gearbox rest in pieces
Running GPS on lower end head units
I think your unit should be compatible. You can install the navgo unit from Pet#o, it costs around 24k i think. Just check with them if your unit is compatible.
Buying nissan tiida as a first car
If you are wondering why no one has bothered to answer its because you are lazy !
Please help me.....
Good advice, OP's budget is 1.7 mil and you are recommending a car that goes for 2.6 mil, im sure you aced your grade 5 maths tests. 316/320 are terms used to describe models in the same generation and does not define the generation. But I believe the generation you are looking for at this price range would be an e36 3 series, and the short answer is dont buy it if you are planning to sell it soon and dont have some budget left for repairs etc.
Mazda oil is called Mazda M V (V as in Roman number 5), this is not the same as mercon V There are no compatible substitutes AFAIK In the local market. Asiri motors, rainbow and new rainbow carry this and price is arround 13k for 4l. Mazna motors papaliyana also has this oil and they give it only if you change Atf from them. This has been discussed a million times and if you bothered to search you would have come across multiple threads.
SLT ADSL data limit on old Home package
On the note of fiber you have to pay 25,000 to get the connection and the data packages are the same as normal adsl packages. Thats kind of like giving someone a Ferrari and saying you can go as fast as you want but you only get 5 liters of petrol.
Spot fine vs Courts comment by traffic cops
As stated whether it's going to courts or a spot fine depends on the offence. What they usually do is change the nature of the offence to one that suits spot fines.
This is quite old news actually, I had the same package and used to download load over 60-80 gbs per month. Apparently they can't limit the gb download since this package is classified as unlimited but they have found a loophole. Basically the slow you down after 40 gb. There was a major case with TRC but in the end no action, most of us switched over to the new packages. Again very very old news, I mean almost 2-3 years ago so even if you complain to TRC I don't think anyone would even know about this package now. It's not such a bad deal though, you get 16 mbps speed and 30gb peak and 30gb off peak. I use dialog kbb package to do all the heavy downloading. Dialog 4g has also gone down the drain, lankanbell Is good but speed is pretty slow and reach is limited. I retained my slt connection because ping is important for me since I game online.
- cr 41
- Post Whoring - Part 2
The future of education sector in our country
Unfortunately you seem to have no idea about marketing at all. First look up what marketing is, marketing is not sale. Marketing is definitely not limited to the guy trying to give you a credit card or insurance at the petrol station (although I have no idea why anyone would even try to do that). The guy selling those obviously only needs selling skills. Do you know what a brand Manger does? Do you know a product manager does? Do you know what people who are in a market research function do? You say marketers require only communication skills? Explain the role of how a brand manager increases sales, increase brand recall, new product development, balances the p&l using only communication skills.
- The Grand Tour
is riding comfort depend on tyre Quality/brand
What does the brands ranking have to do with ops question?
First of all the vertical lines in the marked area are called tread wear indicators, if this and the rest of your tires tread are on the same level then it's time to change tires. Secondly your tires outer edge has not worn evenly indicating some issue with alignment or suspension . Getting to the point of comfort depending on tires there is a bit of a complex answer. Yes comfort can change drastically based on the tires but a lot still depends on the suspension geometry of your car and spring rates. Can you change the way your car absorbs bumps with new tires ? Yes but you can't give an Alto the ride of a Merc s class. I hope you understand the limitations. The other thing is ride comfort is not brand depended, it depend on the particular tire model of the brand and its intended purpose. Let me break it down for you. For comfort you want a soft compound tire with soft sidewalls so both the contact surface and sidewalls absorb the impact in addition to your cars springs. The negative side of this is you will get some bodyroll and car will feel floaty. For better grip tyres with soft contact surfaces but harder sidewalls are better since soft compound helps in grip (they get stickier as tires heat up) and stronger sidewalls reduces bodyroll. For long lasting tires you want hard compound rubber on the contact surface. Road noise will definitely be better if you go for a good brand like bridgestone, dunlop, Goodyear etc. You can try bridgestone ecopia tires if comfort and road noise is your primary goals at the cost of grip. Dunlop Sp touring tires are also good. As for the tire size change looks like the previous owner has increased the tire width, this will result in lower fuel economy but marginally better grip. Impact on comfort from the width increase can go both ways, you might glide over smaller pith holes because of the added width or you could hit a bump, pebble that you wouldnt have hit if your tires were narrow. Upto you to decide.
Toyota AE110
You can easily find a cs or a bj in that budget, unfortunately for you judging by your recent posts here it seems you don't have the skill required to hunt for a car (is that even a thing ?) . Right now I found more than 20 cars that fall between 20-23 laks from the models you highlighted from one particular site alone. I think the problem is you, not the car market. Get some help from a friend who is familiar with cars.
- BOSCH WIPER BLADES 50% OFF
FB 15 Splend 2000
I would be even more cautious if the car is sitting idle. Cars that are not regularly used have their own fair share of issues. Rubber parts including belts, engine mounts, bushes, seals crack and harden over time. Engine oil, PS oil, brake oil can loose their qualities if not circulated regularly, also these can block paths and build sludge. Electronic component can develop fungus and oxidise over time. Things like brake rotary surface can get rust. My point is if you get a horse you have to exercise it regularly , if not it becomes weak and dies. Same with cars. Lower mileage does not mean its a better conditions car. And I pity whoever is going to buy that 65k fb 15.
FB 15 Splend 2000
You are worried about the cars side mirror but not concerned about the fact that a 16 year old car has only done 100, 000 km ? Let me do the math for you 100000/16 years is 6250km per year. 6250/12 months /30 days is 17.36 km per day. Does that sound right to you ?
Best car to buy these days for 2.1 Million
Don't you get it? It's an inferiority complex thing, someone is trying to justify their purchase.
