Everything posted by The Stig
Car With Ample Luggage Space Below 2.2 Million / Nissan Wingroad Models
Also i was offered a forester for 2.3 by a friend, is it worth giving it a try ? BTW no one knows the difference between "Y11,VY11 and the WFY11" ?
Thanks for the replies guys, will take everything into consideration when it comes to the final decision making. Since you guys took so much time to reply to this i feel a bit guilty for not mentioning all the details, sorry about that Anyway things that i forgot to mention was that 100% fuel cost will be bared by the company so no need to worry about that and no need to go for a diesel. Basically to explain my situation i will be doing a lot of field visits outstations and will be transporting expensive items personally to mostly exhibitions from the showroom (colombo 10 to bmich) as i would much rather do it myself than to hand it over to some delivery guy. Also i dont need to go below 20, my upper limit is 2.2 anything around 2-2.2 i can bare easily. Van wont do guys, i personally dont like them and most importantly my ride needs to look a bit decent cause i dont want to be seen as a "delivery guy" Thanks guys, will take them all into consideration. Corolla wagon is definitely an option but the y10 i feel is bit too old, like mentioned above not exactly looking for the cheepest one just want the right balance dunno machan, was mostly looking for something a bit more mainstream but thanks anyway
Historic Images Of Old Ceylon - Automotive And Otherwise
Yes machan Sylvis post is correct, the Fonseka's are the one who own "Plates"
Hey guys long time no see So like the topic says im in need of a car that has some decent luggage space as i am doing a lot of traveling these days and am also carrying a lot of display items back and forth from exhibitions. My budget is maxed out at 2.2 Million, even 2.2 is a long stretch so would prefer if i could find a car below 2 Million. Currently the only car that comes to my mind is the Nissan wingroad WFY11, any other suggestions ? Also i want to know the difference between the Y11,VY11 and the WFY11 ? I saw some ads that have mentioned things like "G grade" , i didnt know that nissan had grades like that ? If so true what are the grades and what are the differences ?
121 Rpm Does Not Drop Quickly
Just to be clear again does the rpm go up after you release the clutch or before ?
Auto Gear
Absolute utter bullshit ! ! ! ! If you dont know what you are talking about dont talk at all, stop misguiding people . Auto transmissions dont have a Clutch to start with, they have something called a "torque convertor" and there is no clutch slipping happening cause there isnt a clutch in the first place. The torque convertor does not have plates touching each other, the connection between the input shaft and the output shaft is established through oil and it does no damage what so ever to any part when one leaves the car in "D" and pressing the brakes for long periods. Again if you dont know what you are talking about just STFU ! For those of you who are confused here is how a torque convertor works We got a real smart one right here No you dumbass its for towing purposes ! ! ! If you had to constantly shift between D and N why the heck would one call it an "Automatic transmission", i dont see much difference between a manual and an auto if it was designed to do all this meddling around. sheessssshhhhhh, unbelievable How the hell can you have transmission issues when there isnt a single part inside the transmission moving when the brakes are applied ? When one applies the brakes all the parts leading up to the torque convertor (Axle > Gears > Output shaft) stop moving cause of the force from the brakes and only the input shaft from the engine is spinning. Get your facts straight ! ! !
Audi A4, A6
Well IMHO if you are not really going to be driving that would mean that you wont have time to do maintenance either and on euros they bite back very hard when they are not properly serviced. I would say the sensible thing for you to do is to put the money in the bank or invest in stocks or something (or any other that gets you a monthly/annual income, you get the idea) and actually to rent a good car from that money for the period you are here. Just doing the math if you put an FD for all 5Mn you should get a good hefty 600,000 at the end of the year which would be more than enough to rent a good car for only a couple of months. My previous thoughts are based on the assumption that you wont be living in SL for the entire year.
Car 12V Cig Lighter Fuse Blows, Pls Help To Identify The Issue
I would highly recommend that you hook the gps unit to a multimeter and measure the amperage used, it would be better if you can plug it into an external source like a power pack instead of the using the car for this measurement. Also do you have any other devices that uses the 12v lighter in a car ? If so does the problem exist when they are being used ?
Introducing: New Moderators Of Autolanka Forum !!
This should make things run much more smoother, and good choice as well. Good luck guys
- Fuel Efficiency
- Toyota Vios 2003 - “Ignition Knock”
Buying a new smartphone
Well technically yes but i dont think most manufacturers make a higher amperage version than the standard and you will have to buy a third party one and im not sure if they will actually deliver what it promises,so far the highest i have encountered is a 900mA charger. How much is yours ? The answer to that is yes and no. Yes some batteries have a cutoff IC but not all and even if it does it doesnt necessarily divert all the current back, it only limits the amperage limiting the flow. If that was the case then charging the battery for the first time more than 2-3 hours after the phones meter says its full is pointless isnt it ? But it isnt, even though the phone reads it as full (they calculate the mAh and thats how the phone knows how much the battery is charged) all the individual atoms may not be saturated and thats why its recommended to leave it for around 4-6 hours the first time from which one can clearly see that even though the battery is full and the cutoff IC is diverting the current back to the charger still some escapes.Yes not a lot at once but overall over a lifespan of a battery roughly we are talking about 20-30 charge cycles being taken off and not to mention the damage done by the heat, so point being dont do it if you can avoid it but again its your phone and i dont care what you do with it.
Formula 1 - 2012
Dont you just hate it when you sit down with a bottle of coke and some snacks to watch the race and then some random relations come over and ruins it Any one know any links to where i can watch a repeat ?
Toyota Prius Is The Most Dependable Compact Car
Saw in some youtube video that Williams F1 sold some KERS technology that doesn't need a battery to Porsche, should be interesting.
Tesla Motors - Cars That Will Change The World
- Buying a new smartphone
Like peri said it depends on the charger, the usb port can only give 5V 500mA so a rough calculation for a 1650mAH battery would be 3 hours and 20 minutes. I dunno what the amperage of the charger for the s2 is but generally a factory one give around 5V 700-850mA so that should take (again roughly) only around 2 hours and 20 minutes.- Buying a new smartphone
Ahhh i see tons of bad battery charging habits mentioned here, Ill share some things that i picked up and have some personal experience with. Well of course i cant prove any of them so you are free to believe what ever you want. 1) Forget what most of the sales guys say, you do not need to charge the battery 12 hours the first time. All Lithium-ion and Lithium polymer batterys come 40% pre-charged as an emergency reserve. Charging for 4-6 hours is more than sufficient. The extra charge time is to make sure that all parts of the battery are initially aligned for saturation properly. 2) For the first 3 charge cycles fully charge and fully discharge the battery, this is so that the phones battery meter can properly calibrate itself to read battery charge level. If you feel that the battery is out of calibration after usage for sometime fully discharge and fully charge, it doesnt hurt to do this process once every 3-4 months to keep things in shape. 3) On a regular basis do not i repeat do not let your battery drain out before you charge it. The whole "wait till the battery if fully depleted and then charge" is 90's technology and pretty much most of the phone sellers i have met seem to be giving this wrong information. In the ealry 90's when we used "gadol bagaya's" and those phones with antennas they used a type of battery called nickel-cadmium batteries and they had this issue called the "memory effect" where if you charge the phone before its fully discharged it will lose some of its battery capacity. This problem does not exist in Li-ion and Li-polymer batteries. In fact with modern batteries its the exact opposite, if you fully discharge the battery it will loose some of its capacity and life time. So tip no 3: charge the battery when ever possible, even if its at 40% or even if it has depleted only 10% charge it. Charge it when ever and where ever possible, trust me it will have a massive effect on the lifespan of your battery. (dont get this confused with overcharging, im not telling you guys to keep it plugged in all times but charge it in short bursts) 4) Do not over charge your battery. its like keeping a mug under a tap, once the mug is full the pressure from the water forces the new water to go in and the old to go out. Though this seems harmless in the scenario of the mug when it comes to batteries it has a massive effect. A phones battery life depends on how many fully charges and full depletes are done and cause each cell has its own lifespan of charge and deplete cycles when you over charge a battery what you are doing is pushing in new electron and pushing out the old ones. This process is equal to that of fully charging and fully depleting and usually batteries only have around 500 full discharge cycles and you will eat at right through those cycles if you over charge it as you are asking it to do overtime work. I think i covered most of it and if you guys want more proof here is a good article to read (http://batteryuniver...based_batteries) Oh yeah and to preserve battery life; switch off 3g and select gsm network mode (saves about 30% battery life) use less widgets and background apps, if you are not using an app close it don't minimize it. Turn bluetooth, wifi, gps off in not needed Urrgg i dont even want to imagine what you are doing in the toilet with your phone But seriously even a 5 year old can figure out a solution for your problem, charge it in the evening when you get home say from 7-9.30 maybe ?- Buying a new smartphone
And there is the cause of your problem, modern batteries dont need to be charged more than 2.5 Hours, the only thing you are doing is heating up the battery and its cutoff circuit and degrading its battery life. Set the phone to auto off at night and charge it in the morning when you get to the office, is that so hard ?- 2013 Range Rover
Does look stunning but in our shores it will cost a good 25Mn or more so the question is do you really need to spend that much on a vehicle that will probably never ever do any real offroading.- Tesla Motors - Cars That Will Change The World
Hey Phony-can why dont you take up the challenge ei ? ? ? We are eagerly waiting- Allion Or Corolla Or Civic
Any diesel would give roughly the same figures, the e46 gets around 13 in city and about 17 in long distance drives and keep in mind that the e46 is a car that weights much more than the 141 so what exactly is so magical about this engine ? Please do enlighten us.- Got To Drive Lamborghini Gallardo And Ferrari F430!!!
- Ever Heard Bio-Diesel?
People please making bio diesel isnt really a big deal at all, i dont see what the big "whoop" is all about. All you need is a little bit of knowledge on chemistry and about 5000/= buck for the other stuff. I've posted this before but for the benefit of those who seem to have been awestruck by this concept ill post it again. Here is the starting product, waste vegetable oil (filtered to a certain extent) Step 2 : Add some NaOH and Methanol (CH4O), heat it up and use a centrifuge. Step 3: let the residue from the oil settle Step 4: separate the diesel from the residue and viola you have Bio diesel. Step 5: Use it on what ever you want, we powered up an old diesel generator cause we were worried that the impurification may cause harm to vehicle engine and clog up the injectors or something.- Buying a new smartphone
So my search for a decent dual sim android ended in disappointment. Went for the setup i had before, bought an htc sensation xe and a nokia 1280 for the other sim.- Ever Heard Bio-Diesel?
Well you dont really need to be a chemist to understand how stupid adding petrol to a diesel is. Simple explanation; diesel engines dont have spark plugs and they use compression to ignite fuel. Petrol's autoignition point is much lower than that of diesel so what they are aiming for is that petrol ignites before the compression stroke is completes and the heat from that will make the diesel ignite more quickly. But the problem is when the petrol ignites the energy from the petrol ignition pushes the pistons downwards before the compression stroke is complete but momentum from the stroke keeps the pistons moving upwards and completes the compression stroke, this force that acts against the pistons movement can cause some serious damage in the long run. If we lived in a very cold country it would have made some sense cause starting a diesel might be a bit of a pain in extreme cold but with this climate its a pretty stupid thing to do on a routine basis. - Buying a new smartphone
