The Stig
Everything posted by The Stig
  1. Thanks machan, but i think trinity cleared this part up Thanks for the indepth clarification. I believe i made a mistake on the yom and after seeing the reply i called my friend and clarified again, the car is infact 2011. Its a 1.5 for sure but with the gauge cluster sampath has mentioned as "Later brand new imports 2011-2012". So does it mean its cvt ? sorry still confused The car has roughly 109k miles, how is the maintenance intervals for the cvts ? Thanks for sourcing all the image The guage cluster is the one you have mentioned as "Later brand new imports 2011-2012"
  2. Guys a friend of mine has his eyes on a lancer cs. I need to clarify something : This car in question is a 1500, YOM is 2009 I believe (not exactly clear). AFAIK there was a cvt varient available and this car has a manumatic gearbox, does this mean it's cvt? The guage cluster is also different than the rest of the cars I have seen, it has black backgrounds with white writing. If it's cvt are these gearboxes common and how should the maintenance be handled? He is concerned about gearbox availability in the long run since he plans to keep the car for around 5 years.
  3. The Stig replied to sosh's topic in TOYOTA
    He is referring to the axio 141 I believe which should be close to the price of a second gen prius. There is no hybrid varient.
  4. No they are not 2004, mostly around 2000 ish. Is the 2004 limit something the leasing company told or is it your own openion.
  5. The wira is basically a lancer cb3 underneath, so it's surprisingly good. However most of the specimens I have seen are hacked to death and not looked after well. Doubtfull if a leasing company would give a good valuation for a wira. You would have a much better chance with an early jap like a bj, cs or a 110. And does it really check this criteria "Looks: Shouldn’t look horrible"
  6. Jumper cables or kits? I bought a jumper cable from wow for around 1400 (i think). It's nothing complecated really, just get the thickest wires you can afford. As long as your battery is 12v35 or 12v45 most cables will be okay.
  7. Sell the damn thing on yahoo asap
  8. Anyone else missing their transmission ?
  9. Honestly like Rumesh said any monkey with a wrench and some gasket sealer can replace the valve cover gasket. You could have adjusted tappets also while this was done if it was done at a normal joint.
  10. I had a somewhat similar issue with abs light comming on and abs being applied at low speeds. In my case it was was an issue with the wheel speed sensor. Simply cleaning the wheel speed rings and fixing it back worked. If the fault is with the rear abs sensor why is your mechanic recommending that you replace the whole abs unit? Seems like a typical makabass solution to me, replace everything and the fault will go away. If you are not sure about the scan results get it checked from mazna motors. Ring these guys and check for abs sensor prices, asiri motors 011 2 543355, rainbow motors 011 4 718967, néw rainbow 011 2 389589.
  11. Go to mazna motors papaliyana Lalith - 071 424 2464 Just get a diagnosis down from them, before doing any repairs ask us.
  12. Blinking hold light indicates something wrong with the transmission or even a check engine fault. There can be something wrong that you cant see or feel, It might not be an issue at all but even small loose connection or dirt on sensors gives this error. Either way get it checked.
  13. Well i am using something called aromate these days, it has 2 scents in one and usually last about 2-3 months. Its available in most car service stations and petrol sheds. give it a shot, its pretty good.
  14. Given the age of the cars whatever small gain you get from the cvt might be offset if you have to replace the gearbox. CVT's gearboxes are costly and even if you can repair one it will still be more costly than an auto.
  15. The Stig replied to Samanthi's topic in General
    Double wishbone take a lot of space to implement eating into the engine compartment and overall space, therefore it's not very feasible for subcompact and compact sedans. Also adds a lot of weight and more joints mean more repairs in the future. The last jap compact sedan to have double wishbone fronts were the ek3 I believe.
  16. The Stig replied to Samanthi's topic in General
    You can't expect us to tell you if the price is fair with us not knowing what is covered in this so called "list of repairs" The atapattam suspension is called double wishbone
  17. Not directly related but related to turbos, I wonder how the government will adjust the tax for turbo engines. With a lot of manufacturers looking at low volume turnbo engines the cc based tax structure is definitely failing.
  18. Then you will have to check in delkanda. But It would be just easier to get it from ebay.
  19. There is no 100% accurate way of testing if the gasket but you can check the following. Take off the radiator cap when the engine is cool and start the engine and see if you get any bubbles. Do a compression test on all 4 cylinders. Sometimes when the engine is revved high you can see a little bit of smoke /water vapor coming from the engine arround the gasket area. Also open the oil filler cap and see if there is any water floating around.
  20. During the tune up did you clean the throttle body, iacv and EGR? Sounds like an issue with your idle air control. It could also be the tps and maf, clean them both and see.
  21. While I am greatfull for organizers of motor sports events one can't help but notice how untrained the race marshal are in handling an injured rider. They move the legs, takes off helmet and move his head , one even tries to give him water. https://m.facebook.com/story.php?story_fbid=1780415668955809&id=1540515892945789
  22. Ok How much are you selling your cam for
  23. It is very very normal. That's what gives the car good steering feel. Also the rack is very fast (wheels turn a lot compared to steering input) so making it light would be dangerous as well. It is a little tiresome in stop and go traffic but you will love it on long distance trips.
  24. Take crosswinds advice. I also faced a similar situation where the owner I bought my current car from was on open papers and paid a lease under the previous owner. He showed me the signed mta form and the letter of no objection from the bank for the lease. However how can I know for sure that the signature on the mta form is from the registered owner? One can fake a signature and even falsify documents easily ,this is Sri Lanka after all. I got the car first converted to the name of the person that I was going to buy from via 1 day service. That way I know the person I'm buying it personally and I know the mta + no objection letter is legit. Then I bought the car from him. Yes there was an additional owner added and I had to get a normal transfer from the seller (only one 1day transfer per year is allowed) but worth the risk. This I think is the best way to go forward. Also do keep in mind that the government had a deadline to convert vehicles with open paper which has passed and you may face some trouble when converting it to your name (possible penalty fines).
  25. Was he using it to travel to the moon and back on a daily basis ? 150,000 in 5 years ?
