Everything posted by Nilantha
Fb14 Oil Leak
happy to see your car engine room. its very clean. just like brand new engine. you are a really car lover.
Townace Noah Cr41 Rpm Wiring
who can help me to fix my CR41 RPM meter wiring. i already fix Diesel Injection pump with RPM sensor and complete wiring harnus. but i don't have engine side wiring harnus. for engine side im using my old wiring harnus. so can any one help me to fix RPM?
Carina Gt
don't worry. 150,000 is small. if you change engine oil and filters on time you can run at least 250,000./- minimum 5AFE is very good engine.. don't worry
Average Lifetime Of A Car Battery In Sri Lanka
Have used Globle for 5 years without any issue. ( I recommend Globle) Have used EXIDE for 3 years
- New Service Offered By Rmv
Engine Repaire
if your engine not giving any problem, so don't do anything. use that engine and do oil and filter change on time. if you treat her well she will not give you problem. BTW what is the price you got recon engine?
- Fuel Efficiency
Engine Repaire
Jami, frankly tell me why are you going to replace the engine? whats the wrong with your engine? normally petrol engines you can run 300,000 to 350,000km if you change engine oil & filters on time. tel me what is the wroing with your engine. i will tel you what to do. what is your car model and make?
Another Crash In Southern Highway
who is the fool dive 100kmph when raining? if you drive 20kmph on express way there is no offence. there is no rule for minimum speed. the driver has to keep the vehicle on safety speed depend on whether.
- Good Year Tyre - Indonesia
Trip To Thiland- Help
you have to take visa from sri lanka before go. visa fee is 4,000/-
2C Engine Re-Boring Help
My recommendation is buy recondition 2C engine and replace. everyone can't do 2C engine repair successfully. you have to spend around Rs180,000 to repair originaly and you can buy recon engine for Rs.200,000/- if you want to know more clarification please ask me. i did my 2C engine repair recently. i get it done according to my technical knowledge. if you don't have practical engine experience better you replace engine with recon one. all mechanics are telling recon engines are not good. why they are telling that? for engine repair they charge 20,000/- + commission from spare parts, for recon engine replacement they only can charge 5,000/- so they recommend to repair engine. so my advice replace engine with recon one.
My Complete Noah Build
Next NOAH Build started...........
- What Is The Best Battery
No two words. good battery is Global. i used Globle NS40ZL for 5 years without any issue. Have used EXIDE for 3 Years. but seems EXIDE Ultrs is not good. This week my brothers car Alternator going to replace because of the Diode plate have burned because of the Battery issue. that Battery is EXIDE Ultra but no have used 2 months. the battery also going to replace from the warranty replacement.
How To Check The Radiation In The Vehicle
you contact Environmental Authority. i think they can do this. or you can call 1919 and get some information regarding this.
Where To Buy Used Car Tyres
Don't buy USED Tyres and used shockshobers. they can't use successfully.
Diy How To Change Disk Brake Pads And Rotors The Correct Way
can't we use GAL Arakku insted of BEER?
Converted (Petrol To Diesel) Kr42 Price, Procs And Cons
call this number 0716810451
- Toyota Fuel Economy Survey
Engine Overhaul 2C
when you buy engine brand new it is no have sleeves (but big engines have slives) it has the engine body with size 25 (standerd size). when it warned out you have to re-bore it to 50 and you have to use size 50 pistons and ring set. next time you can re-bore it to 75 and you can use 75 size pistons and rings. after 75 you have boor it and have to put 25 (standers size) sleeves and you can use 25 size pistons and rings. but when you go to first time overhaul if the engine warn out badly, if you want to re-bore it to size 75 better you re-bore the engine and put 25 sleeves and you can use existing 25 pistons if they are good. ALPIN is piston model. its hard than normal pistons and light weight. ALPIN also have 25, 50 and 75 size
Engine Overhaul 2C
after run 10,000 km engine was badly vibrating and with black smoke. but i pass the green test and test guys told me engine is in very good condition. but lot of black smoke and vibration. i return to the bass and he told me to go to injector pump service garage. the injector pump bass told me to replace the engine mount. i told him i replaced engine mount with genuine ones. so again he pressure the injectors and fixed and problem not solved. i return to my engine repaired bass and told him the situation. he told me this vibration is normal for diesel engine. but i was everyday running the van with black smoke and vibration. so bas wan not be able to fix that fault. i had a question if engine new how come this black smoke and vibration. when come to engine around 15,000km there was knock sound also comming from one piston. so i show this to many garages and many diesel baas all told me this is normal situation of the diesel engine. when i was showing this to garages suddenly met one of my class mate. i told him the situation and he is a technical guy. he told me to take the vehicle to his home one day. so i took the van there. do you know what he did? 1. when he check the injector pump the bas keep the injector pump maximum advance position. my class mate took that injector pump to normal position. (retard) 2. there is a screw on the injector pump to adjust the diesel inflow to the injector pump. he close the screw (reduced the diesel coming in to injector pump) 3. also he check the tappet clearance and keep them to 25 please note:- most old bass don't know how to keep the tappet clearance of the 2C engine. there is special tool to adjust the tappet clearance. also there is 25, 30, 40 sizes "Sims" have to use for keep tappet clearance. most technetions don't know how to adjust the tappet clearance of the 2C engine. ### most impotent thing is the engine over hole of the 2c engine is use the GENUIN piston Ring set and the keep tappet clearance using only required size "Sims" ### after tuning the engine by my class mate now its running like petrol engine. 1. less noise 2. less vibration 3. no black smoke any time any load 4. very good fuel economy but remember i am using VIC oil, air & Diesel filters and change oil very 3500km,. also use DS40 ceypetco
Engine Overhaul 2C
well, good question. i will tel you good story about 2C engine overhaul. i have Toyota Townace CR41 with 2C power. when i buy the vehicle it was over 300k but body was good so i bought. it is manual gear one. when i buy the vehicle the engine was brand new as it is but totally finish. lot of ppl told me to replace the engine with 3C turbo second hand engine. but some ppl told me to repair the engine. any how i decided to repair the engine without taking the used engine risk. for repair i did following, 1. take engine down 2. unfix the engine 3. bass told me to take in to Edirisinghe brothers 4. boring the engine fix slives size 25 5. piston was damaged so i replace pistons with "ALPIN" pistons (ALPIN Pistons are expensive other than normal pistons (size 25). i bought 4 ALPIN postons for Rs.9,500 from Wijerama, in Edirisinghe brothers it was 14,000/-) 6. replace all bairings, 7. replace valve seats 8. replace valvs 9. replace oil pump 10. replace Genuine piston rings (15,500/- from toyota lanka) 11. use genuine overhaul kit from Wejerama - price around 19,000/- with genuine gasket 12. replace genuine Timming belt and made in japan Adjuster bearings cost around 18,000/- 13 replace all drive belts 14. service the starter mortor and replace bairings, 15. service and replace barings and brush set of the alternator 16. replace Injectors (Denso) and service and calibrate the Injector pump cost was 11,000/- 17. replace Radiator cooling fan clutch with recon one. 18. replace Engine mounts cost was 15,000/- genuine from Toyota lanka. finally totaly cost was 150k including 20k bass charges. cont.................
"cylinder Sleeve" & "ring Set" Replacement Mitsubishi (4G33/32)
yes DEMO do. don't buy replace spare parts from Edirisihghe brothers. they are too expensive. use alpin pistons and cylinders. you can buy from Wijerama. there is a brand new sparepartz shop i fogot the name. his price is very reasonable. also don't forget to use Genuine piston rings from Mitsubishi motors.
