Shehan Niyas Wildchild
Everything posted by Shehan Niyas Wildchild
  1. ive used Ln106, Ln107 and LN85! superb vehicles and spares are freely available. they come with the 3L engine.
  2. u might find something useful here on the link below. at least gain some knowledge on how it works. http://sonirodban.com/fix-your-brakes.html
  3. guys guys guys!! if brake pedal goes down then ur master pump washer is not holding the pressure to push the pistons. so that means- 1. a leak in one of your wheel cylinder washers 2. a leak in the piping that goes from the master pump to the wheels. 3. Master pump washers worn 4. master pump cylinder housing scratched or not smooth enough to withhold pressure. if 1 and 2 are completed, and if problem persists, then replace master pump washer set. NOTE: always use genuine or at least 75% good washers like branded ones. i go for seiken. you dont want to have to go through the trouble of removing the master pump and replacing it again coz they wear off easily and dats y they are low priced!! if replacing the master pump washer set doesnt work, replace the master pump. that should do the trick. it must have been bored or scathed / scratched. Good luck! btw if you find murky dark coloured brake oil, its due to the worn washes and pieces of aluminium due to pump wear. flush off the entire system with new oil.
  4. visibly examine the front of your car and shake the bumpers, grill and number plate and see if its loose or whether you hear a similar noise. start the car and check. if no sound, then pull handbrake and shift to D and get out and check. thats the time wen the car will have more vibrations.
  5. the places where they do conversions are (Rila from mawilmada - 0777381494) Auto gearbox repairers are - Saman Motors- 0777528506 katugastota close to police station and 'Auto Niyas' at pilimatalawa - hes a well known person there but i seem to have lost his number. if you contact saman motors then you will be able to get his number too. cr27 auto gearbox will also go around 30 to 35 because it is compatible with hiace dolphin. so its a bit high in demand. you can also fix a dolphin auto gbox. try mawilmada rila. he has used ones. you can get it at abt 15 to 20k
  6. u guys know any place where i can get one? used is fine as long as it aint a murder weapon. i would prefer a pistol or any small handgun. btw any place in SL where i can purchase a stun gun?? Thanks!
  7. if ur transferring it into ur name then u have to go in person or send an accomplice with two passport size photographs of you signed by a JP or a lawyer and a copy of your NIC and vehicle CR, Original licence and a copy and duly filled transfer form. even one signed paper is enough from the booklet. else if ur transferring the cars ownership to someone else then handover the relevant documents to him. even if u send ur copy to the RMV or not if the new owner has submitted his part of the documents to the RMV for transfer then it will get transferred in his name. The address is : The Commissioner of Motor Traffic Registar of Motor Vehicles Elvitigala Mawatha, Colombo 5.
  8. first things first. try increasing engine idle rpm. if the engine is too slow then it might vibrate alot when a gear is engaged coz it tends to slow down when building up oil pressure in the torque converter. if this fails (which i dont think it will) wel, then seems you are having problems with a failing O2 sensor. try cleaning it.on the worst side u will have to replace it if cleaning doesnt help. best thing is to scan for trouble codes..
  9. yup i think its the front shock mount. its available to buy seperately. replace it with a genuine one or atleast the best of the local ones available. otherwise it might give trouble again coz its this mount which is subject to hard use constantly and wears off quickly...
  10. auto to manual conversion will cost you 130000/= i had a caravan QD32 engine and had probs wit auto trans too. after u shift it to D it takes some time to engage. if u press the accellarator before that. it jumps forward suddenly. then dismantled the gearbox and found that the plastic O ring seal of the D drive assembly had cracked and not allowing oil pressure to build up. replaced it from another dismantled gearbox and now it works fine! all probs can be repaired. afterall, they are metal right! if you cant find a good mechanic who knows their way aroung auto transmission, then just go for a reconditioned auto gearbox. nissan serina, caravan TD27 and QD32 all have the same gearbox. will cost maximum of 30000/= average price is 25000/= btw im 4rm kandy and there are three famous auto transmission repairers here. they do conversions too.
