MV-5
Everything posted by MV-5
  1. MV-5 replied to Watchman's topic in General
    No point of mentioning fuel figures for a Prius on highway for a short trip like 100-200km.on highway the "effective" fuel figures might me 35kmpl. how? simply it will give better figures when it is driven by the electric motor. figures will not be so good when battery is being charged. then, to have better figures you should have "not that good" figures.
  2. MV-5 replied to udararaj's topic in PERODUA
    Brake fluid should not be top up under normal condition. in your case problem might be brake pads(worn out). then one day with the new brake pad set , fluid level will be restored to the previous level. if your brake pads are almost new, then you need to check for a fluid leak. if your car is manual and if the same fluid reservoir is shared for clutch, then break lines and clutch lines should be check for a leak(AFAIK 90% case is bad washers in clutch pumps). My advise: keep on eye for further fluid level drop, if it is noticeable then act.but never allow to drop it beyond the MIN level.
  3. i faced the same problem (when engine is hot), but in that case in the first attempt it made a just "click" sound. problem was the starter motor relay mechanism (Solenoid). that is why i asked this question. my post hides a very important question raised by Rumesh88(#2 post). please answer for that post.
  4. you said that in first attempt it doesn't start. can you hear the crank sound? or you just hear a "click" sound?
  5. pls more info.... MT or AT? slow down means 0 throttle ? engine temp? last tune up or MAF,TB cleanup? plugs,air filter condition?
  6. AFAIK, water spray from exhaust (first start after long time, probably morning start), then white smoke(due to high moisture content) is well known sign of "head gasket leakage". This high moisture (H2O) content will be there in the exhaust as totally in "gas" form. at the very end of the exhaust pipe, it will be turn into water drops(in to liquid form). technically , water in liquid form will not be there in the combustion chamber.
  7. try this (if you haven't tried). switch the key to "ON" (IGN ON) and wait few seconds and start.if you see the "time lag" is same, then try what watchman said.
  8. Please edit your post and crop the first image (to remove the bottom part), otherwise Mods might completely remove your post.......
  9. to start your own business, the most important factor is "domain knowledge" what you are trying to get through a public forum which is not practical.
  10. home page search box (http://www.autolanka.com/) would produce this same result.
  11. No No, no need to be an expert, i just focused on fuel figures you mentioned (10kmpl was improved to 12kmpl). based on that observation , conclusion is obvious(3500 RPM burn less fuel). then in the same post you raised a question which make some contradiction with your own observation. I also thought that cruising at 70kmph in 4th gear consumes more fuel than in 5th gear. according to your observation 4th gear is more economical. that is why i am interested on your experiment and observation.
  12. in sri Lanka, is there a SX4 model which produces approx 135bhp?
  13. So you are not sure about your own observation
  14. MV-5 replied to TCS's topic in MAZDA
    you may search the forum. there are several threads that can help you. ex: http://forum.autolanka.com/topic/14624-engine-tune-up/
  15. MV-5 replied to TCS's topic in MAZDA
    8kmpl in Colombo (if it is with AC) for this 1.3 engine .............. it is not bad at all (even for a MT).
  16. MV-5 replied to Magnum's topic in BMW
    to pay bank loans and credit card bills Yes, as VVTI said , reliability is not a "YES" "NO" thing and it is not measurable. But still reliability can be converted to a "comparable quality" if we can come up with a mathematical model.but unfortunately we don't have facts to do that. What kind of facts??? need to go through all records in consumer reported problems (probably within warranty period) based on models and based on equivalent models made by other manufactures.and problem should be categorized based on a functional area and technical area. NOTE : I am just kidding...............because i feel so sleepy
  17. based on observations,I think speed sensor reads the correct value and ECU also read and return the correct value. but speedometer doesn't show what it is asked to display. Just forget about Tyre size. as a percentage error is just like 20%(means actual 100kmph is shown as 80kmph). to produce this kind of error effective radius should be increased in (20/80 *100) = 25% which is not practical. problem might be in "pointer needle motor". To exclude some other possibility, just try to test the ODO meter readings, Ex: if you travel again in E01 you can compare the actual distance (distance has been marked by 100m to 100m in E01 ) and the ODO reading, but at least you have to travel 50km for a better comparison.
  18. Next -> Ignition coil assembly (power coil). don't buy, if you have a friend who has a same model, then you can give a "trial and error" attempt.
  19. spark plug?
  20. How did you get this figure? is it from ODO meter it self or just you knew that distance is 98 Km?
  21. if it has a OBD2 port , then try to use a diagnostic tool and check the speed. if speed in diagnostic tool == speedometer speed , then problem might be in the speed sensor.
  22. hah ha ha...... I like that term.
  23. @dilan_randika what is this magic number 2000? higher gears are fuel efficient? aggressive driving consume more fuel??.... why fuel consumption for the same vehicle depends on driving patterns or driver. Answer: "fuel efficiency" is non other than fuel injection rate vs power. i will just mention two theatrical points that you all know. you may build up practical explanation on top of that. Travel in constant speed also it consumes power. This power depends on the speed.Ex: if 60kmph -> 10hp, then for 120kmph it might be 50hp. Vehicle has an unlimited number of torque vs RPM curves. For the simplicity you can assume that, there is a torque vs RPM curve for a given throttle position. Power vs RPM curve can be derived from Torque vs RPM curve. At 1000 RPM, half throttle position might produce 30hp, but full throttle position might produce just 40hp. but the fuel injection rate might be few times higher than the half throttle position. At 3000 half throttle - > 50hp Full throttle -> 90hp (40hp extra power is worth for additional fuel injection rate, but in 1000 RPM it is not).
  24. anyone got a link to download "Wangan full throttle"?
