Magnum
Everything posted by Magnum
  1. <blockquote class='ipsBlockquote'data-author="JayZ" data-cid="281552" data-time="1439894386"><p> I got the same unit for around USD 60 with AV in function where yo can fix a reverse cam. Ask the seller to ditch the printed box and mark it as a tablet.<br /> My unit came directly to home.</p></blockquote> Is it the same thing? How is the quality? Does it use the Navitel maps?
  2. What will happen if i get it down here to Aussie and bring it with me when im coming there? Will there be an issue at the SL airport?
  3. This seems to be a good option for GPS http://www.ebay.com/itm/281640837314?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D281640837314%26_rdc%3D1 I think it comes with built in Navitel maps like those Chinese set ups, they work very well to be honest. cuz it has wifi you could probably use Google maps
  4. <blockquote class='ipsBlockquote'data-author="iRage" data-cid="281524" data-time="1439816672"><p> <br /> The front seems to use similar design ques as the 2015 Lincoln Navigator or even the Chevy Suburban. Nothing about a facelift for the US market so far (for the LC200). The Lexus equivelant the, LX (570) series, on the other hand got the typical Lexus front grill just a few weeks ago<br /> <a href='http://img-s-msn-com.akamaized.net/tenant/amp/entityid/BBlLtft.img?h=373&w=624&m=6&q=60&o=f&l=f'>http://img-s-msn-com.akamaized.net/tenant/amp/entityid/BBlLtft.img?h=373&w=624&m=6&q=60&o=f&l=f</a></p></blockquote> Yep looks like the Navigator That's the one I was referring to
  5. The front looks so much like some American suv, I can't figure out which one it is
  6. If it's an original xenon kit I highly doubt that it'll go out so soon! Kinda weird If it's not original when fixing the HID sometimes an additional relay is used and that relay is connected directly to the battery so you might wanna check that
  7. <blockquote class='ipsBlockquote'data-author="NPP" data-cid="281494" data-time="1439701587"><p> Well they would've cleaned up by now. But wonder what would have happened if someone on the spot decided to light a cigarette.</p></blockquote> I don't think anything would happen, diesel needs to reach its optimum temperature to burn and it's a quite high temperature. Which is why diesel engines have a high compression ration
  8. Sounds like your friend had a top of the range E46
  9. 2C engine swap is like the Sri Lankan version of the American LS swap, it goes into every god damn car!
  10. Going downhill would be more dangerous
  11. Thats a Tata, so its Indian
  12. Magnum replied to Jor-el's topic in General
    Don't stick to one place, check the price from different places. Search online too.
  13. Your lights are probably H4,it's better you take them out and check. On some vehicles you can see the bulb type marking by looking through the lens Maybe you don't notice it but Nightbreakers throw the light beams quite far!
  14. Your left light is way higher than the right one. People will probably flash their lights at if you have it that way
  15. <blockquote class='ipsBlockquote'data-author="PreseaLover" data-cid="281454" data-time="1439633016"><p> <br /> Ok so if my previous bulb set's alignment was alright, how can they newly added bulb's alignment change when it is just plug and play?<br /> Holes are there but nothing to screw on.... I mean the holes end in the air itself...<br /> And yes first time </p></blockquote> Alignment changes when you change the bulbs, look for that screw on your headlight then....it's pretty easy to find
  16. Is this the first time you are meddling with car headlight bulbs? To align the bulb you dont have to take it out.. you will find alignment screws somewhere near your headlight This is how they look and most of the time they are in between those holes you can adjust them with a flat screw driver, if you are not sure where it is try putting the screw driver into those holes, if the alignment screw is there the screw driver will fit in as if it has got fit on to a nail. Sometimes you will need to apply some pressure to turn the screws Its best you start with the vertical alignment you will need to align it and go for a drive to check if its fine
  17. The headlight definitely was not glass but I think the fog lamps were glass. I don't think manufacturers are allowed to use glass headlights now My Bluebird lights have that issue of becoming yellow...I think this issue is there with certain models. I have seen 121 lights becoming yellow too
  18. You have to open those cases in a way you would when you want to break it And those fake ones actually do break when you open them
  19. Magnum replied to Jor-el's topic in General
    Are there set ups which have specific out for tweeters?
  20. <blockquote class='ipsBlockquote'data-author="tiv" data-cid="281423" data-time="1439563476"><p> You will have to do something about those headlamps as I've seen the opacity starting the in latest prado, x-trail, and even the ever-growing wagon R population as well.</p></blockquote> The original Hiace lights seem to be doing OK, it's those thaiwan/thailand lights which are turning yellow.
  21. Whats so confusing about classifying them? PHV stands for "Plug in HYBRID vehicle"
  22. No news regarding the Allion/Premio yet?
  23. Magnum replied to Le Sabre's topic in NISSAN
    Okay on the topic of Osram Nightbreaker unlimited, it does improve the light output over a generic halogen bulb but its not bright as a proper HID fixed in a proper manner(focus on the word proper ). A poorly fixed HID for headlight throws light all over the place reducing the light output on the road, you will even see some light beams going up trees.. I got nightbreaker unlimited for fog lamps
  24. Link to the post: http://forum.autolanka.com/topic/11997-cool-ebay-gadgets-for-cars/?p=277988 Its better that mods lock this thread
  25. I managed to find something interesting regarding HID Kits AC HID kit vs DC HID kit The AC kits seem to be a bit more expensive and less in number on eBay compared to DC kits, I had a DC kit on the Suzuki Every I had earlier, when you point the headlights on a white wall you can see that both bulbs emitting a slightly different color from each other, I thought it was a common issue with HID bulbs and I think OEM kits are AC Check out this video, he does a comparison between AC and DC ballasts: The AC kits have an extra box like thing, it must be the inverter
