JayZ
Everything posted by JayZ
  1. Im using a Droid 2 Global for sometime now. :sport-smiley-027: the screen is a disaster. Doesn't respond @ all sometimes. Thank god is has the hardware keypad. Else i would have smashed it long time ago. Sigh. But Samsung screens are much better than of Motorola as i suppose.
  2. dude if its just one passenger .... WHY "sedan with adequate boot space" ?? :speechless-smiley-003: :speechless-smiley-003: anything special u want to deliver inside the boot ??
  3. This is a non permit Kyron. Ssanogyong do have petrol Kyrons and Rextons. But 99% what we see here are diesels.
  4. Kavvz, Yes the transmission incident occurred after the alternator repair. When initially i repaired the alternator checked the voltage and it was between 12.5 - 13 V as i can remember. And the battery was charging fine. After this incident also i checked the alternator voltage and it was the same. Can it be due to some ECU malfunction? If that so shouldn't it be a more regular issue than a one time incident?
  5. Dear Sylvi, Yes, This thread opened for another issue. PO443 i mentioned as other issues currently with the car thinking whether it has something to do with this gear change issue. Also the PO443 code popped up after i repair the alternator. (Changed the coil pack and regulator IC).
  6. JayZ replied to madmax's topic in General Automotive
    That is one wicked ride. But i'd rather bus than getting out of that thing :D
  7. Thanks guys for the inputs. The P0443 issue came after i fixed the alternator. Is there any connection with this error and the alternator fix ? The place i did the scaning didn't had the facilities to check the functionality of the solenoids through their scanner. This needs to be checked soon as well. I will take the car to a good electrical mechanic and should get the system checked. Thanks again.
  8. It should be a Marauder !!!! Hell yaa :D
  9. Thanks MINIACE and Sylvi for the info. Ill contact him and try to get this sorted out soon.
  10. Hmm ... didn't see this thread before. But this mentioned rule has been changed again. I dont have any supporting info on to how much they have reduced it to but when i went to transfer my vehicle they advice me to come during next week since their system is going to change. If you going to do a late transfer during this week (before their system change) you will incur the late payments if theres any payable.
  11. the newly implemented late payment system ( Rs. 100 per day) for vehicle transfer has been altered again. So i guess open paper business will continue as usual
  12. Thanks again, would you be able to tell me a mechanical expert for European vehicles and who does cater for these type of issues around colombo ?
  13. Thanks Miniace, The guy i checked with didnt knew much about activating solenoid with the scanner. Should check again with a good place. Btw what is the impact to the engine due to this issue ? Is it a very bad situation which needs immediate attention? I dont feel any issue with the performance of the vehicle.
  14. Still the DPMC is doing the services.
  15. Has anyone incured this fault code P0443 or similar? P0443 - Evaporative Emission Control System Purge Control Valve Circuit This code comes with the check engine light. I got the code cleared once but still popping up time to time. Any of you had experience with this issue, appreciate your input. Note: i checked online, "http://www.obd-codes.com/p0443" still did not check this with the agents or a mechanic. Vehicle - Ford Mondeo MK3
  16. Hi Sampath, check the link below, <<http://www.ebay.com/itm/PRIUS-2010-2011-LED-gear-shift-knob-chrome-BLUE-light-/110764439582?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item19ca13381e#ht_3304wt_671>>
  17. Am i the only one whose getting this weired feeling that some one is just playing with u guys ?? :D
  18. Thanks fonfe for the valuable info, I got it checked with a scanner and he said its due to the loose connection in the connector. Going to get it checked again from the place where i removed it from.
  19. Dear experts, Recently i had to remove the steering wheel of my car (with the airbag) to service the AC cooler. After the fix airbag indicator is On permanently. Does this happen since the airbag has been removed and re fixed ? Do i have to reset this light ?
  20. Hi Aravinda,Maps are device independent but software dependent. Since this device running Win CE, u can install Garmin or Navitel software later on. I had a Garmin SL map but it lacks details and getting stuck all the time. Sala and Dialog Sat uses a software called Navital and it uses Atlas maps which are highly detailed and does not get stuck. You will be able to install this software from Sala for a fee. Make sure ur device has at least 64 - 128 Mb of RAM.
  21. Saw a prius with a fart can fixed :D Continuous non stop fart in a low tone :sport-smiley-004: LMFAO
  22. Must be a damaged headlight seal due to heat. Better go to a headlight cleaning joint and remove the water inside and get it sealed properly.
  23. Rotating hubcaps means spinners ?? ya i have seen those on Escalades with massive rim sizes. :D I have seen this sorta kit on eBay too. but its fixed to the fender and light is reflected to the rims. wont be this bright. But from the looks of this, i think these are not LED's. it must be a neon tube inside the wheel.
  24. JayZ replied to Nishan.dj's topic in General
    hi Sifaan, From where did u get this pump from ? and how much it costed ?
  25. Well im not sure of any place where u would be able to get this done ... but if u speak to any tint shop in Darly road or Sun Lanka they might consider doi g it for u. And i have seen at Advance audio they are doing vehicle headlight tinting also. vinyl's easiest source would be eBay as u'd be able to get the exact color u want. As u mentioned ur allion has black interior i guess matt black finish or carbon fiber look vinyl would give the best appeal. :D
