Amila G
Everything posted by Amila G
  1. Yes it's the kind with the chain, but afaik (told by a good mech I know )you should only use it for removing the filter and not to tighten the new one as the chain could damage the plastic housing and that's why some use t-belts to tighten them. But this instance they did have a proper filter tool, the kind like a cup that fits the top of the filter exactly (the bit that has the polygon kinda shape). But the bugger was too lazy to get reach for it and tried to use the one with the chain
  2. Never ever leave a car alone for anything and they'll f**k up even the simplest of the things. Once I went to laughs to do an oil change I was with the car the entire time and went to pay the bill when the guy is putting the new air filter when I was going back noticed the engine sound is different and later found out that the air intake hose has come off from the filter housing!!! Also they don't have the knowledge to apply a bit of oil to the new filter's rubber seal and once a guy tried to use a metal chain to tighten the new filter(which could damage it). So I stay with the car all the time and watch every step of the service bugger.
  3. May be you've misunderstood the thermostat. It's actually a mechanical valve that cuts off the water supply through the radiator when the engine temp is low.(most valves open around 82 C and closes if the temp is lower to maintain the heat inside the engine). So if the valve is missing the water will always flow through the radiator and the engine will not reach the normal temp if driven constantly at higher speeds.So the fans will not be running regularly. But if your fans work normally and the indicator does not reach 1/2 mark even in traffic, the indicator might be faulty. Get an auto electrician to check the temp sensor and the indicator. Despite a missing thermostat, the engine should reach the optimal temp at least in traffic as there's no wind blowing through the radiator when in traffic.
  4. Just watched this and couldn't resist posting here Clarkson's Car Years Episode 2 - How Japan Took Over the World... And Then Lost It (Part 1)
  5. I think you can't tint the front windows. (driver and passenger). My dad got pulled over (abt 3 months ago) for the tint on the front windows and had to remove it (it was the lightest tint). Better check the police website. According to that cop you can't even put a totally clear polythene sheet on the window !!!
  6. Amila G replied to lasa's topic in The Lounge
    I have turanza ar10 s in my car and they are nice, specially on wet, cut through water puddles really nicely. But I think those are supposed to be car tyres ? Not sure if they can haul the weight of a fully loaded NOAH. Better check the max load of the tyres.
  7. Me too, ac button is my turbo boost button
  8. Thanks for the reply, Why should I avoid panchikawatte ? How about delkanda shops ? Also should I take a mechanic to find a good quality pump or can I check for my self (if so what are the things that I should check for) ?
  9. Thanks, will get it checked, I was told that there's a pin like thing in the vacuum pump that wears out and give a similar sound.
  10. Yes, but I was following if it aint broke don't fix it law anyway I'll get it done. Btw how is toyota lanka for tappet adjusting ? I asked another mech and he said I need to leave the car for overnight for tappet check and I kinda hesitate to leave her on an unfamiliar place . Although my regular mech does tappets I don't if he's got the right tools/values to do it properly.
  11. It started about a week back. There's a little tappet noise but this is way too loud, you can even hear it when the shutters closed. It lasts for a couple minutes, so I;m guessing it s going away when the engine heats up.
  12. Hi, It's a corolla CE110 and about a week ago there was a clattering sound from the engine when it was started in the morning and slowly went away in about 5 mins (or when the engine got hot). After that day the sound comes again in some mornings but not always and it goes away in a few minutes. The sound is exactly like a metal nut hitting the tappet cover but it s not the usual tappet sound. At first I was scared that something has gotten lose inside the engine. The sound is coming from the drivers side of the engine and may be from the diesel pump but cannot locate exactly. I had the injectors checked and all were fine (thinking of a blocked injector as a mech suggested). Another mech said the sound is from either the vacuum pump or the alternator drive belt but the belt looks fine and the tension is also fine. Funny thing is it's really hard to show the symptoms to mechanic as it goes away by the time I take the car to him and it only occurs in the morning. Only option is to leave the car with a mech overnight which I kinda hesitate Apart from that there are no any other issues with it, car pulls great and has good fuel consumption. Valve clearances are not checked for about at least 100k but did not do it cause I had no issues with it. btw engine has clocked 200+ K Any help trouble shooting this is really appriciated.
  13. If you suspect a wheel bearing issue, jack up that side and try rotating (the hub) preferably with the wheel removed. Most probably you'll be able to hear the bearing hum. But if it occurs only under load this method won't work I heard replacing front bearings is straight forward. But if you want to do the rears you'll need a hydraulic press to remove the old one and put the new bearing in. (if u go for NSK bearings)
  14. Amila G replied to wjkalana's topic in BMW
    check this out http://xenonsonline.com/shop/bmw-error-canceler.html Local HID conversions may not be a good idea for a new beemer
  15. You are still missing the point. Without the thermostat the engine could take more than a hour to reach the temp. When my thermostat was stuck open, The car reached the normal temp only when I reached colombo traffic in the morning. For the rest of the journey (1+ hrs) it stayed below the 1/4 mark. Reason is constant wind blowing via the radiator cools the engine too much although the fans are not working. Removing the thermostat is the local maka-bass theory. When running too cold the engine is wearing faster and burns too much fuel. See below to understand how the thermostat valve works http://auto.howstuffworks.com/question248.htm If they say so they are idiots.
  16. Amila G replied to nano31's topic in General Automotive
    Get FBL you won't regret. But a bit pricey as made in japan. As per my mech they are as good as the toyota ones. FBK is not made in Japan but JFBK is made in japan according to the box but my mech said they are not up to the genuine toyota standard. FBK is not bad but you'll need to find a pair that is really FBK. I once had a brand called sakura and they are terrible just avoid it
  17. Amila G replied to nano31's topic in General Automotive
    FBL pads are good. (The ones that come in the green box made in japan)
  18. For some agents it makes sense, this happened to my cousin, He went to the mazda agent to get a faulty abs sensor checked on his familia. The mechanic guy told him that the checking the abs sensor cost as much as replacing one so he suggested my cousin to report the problem as "a issue in the brakes" instead of an ABS issue. and then he'll do the abs sensor testing too My cousin did as told and get the faulty sensor replaced and paid the bugger 500 and went home possibly saving a few thousands that they charge for the sensor testing
  19. Sorry sira, but your answer is completely wrong!!! It does not take 20mins for an engine to reach optimal temp, but rather it happens within 5 - 10 mins even in cold mornings if the thermostat works fine. For every time that you run the engine in less than optimal temperature, it increases the engine wear and the fuel consumption. Running without the thermostat IS A BIG ISSUE especially if you do high speed runs in the cold weather. Thermostat cuts off the water supply through the radiator if the engine is cooling and helps to keep the heat within the engine. When you are running without it in cold weather, the water continuously goes through the radiator and gets cooled as the cold wind is blowing through the radiator as the car is travelling. Also running without the thermostat actually increases the fan life as the fan does not have to work often since the engine does not reach the fan working temperature. But it decreases the engine life. So check it and replace with a genuine one if necessary. A thermostat valve should cost around 2000/= and fixing it is a 30min job.
  20. Cooler engine is better is utter BS, it increases engine wear as the engine oil is not heated up properly it does not get thin enough to lubricate properly and increases the fuel consumption too. Me too had a similar issue but on a corolla and it went away when the thermostat is replaced. I noticed a reduction in pulling power when the eng is colder. But does it come to the 1/2 mark when in traffic ? if not the thermostat might not be the issue, and you need to find the if the 1/2 mark is the normal value for vitara, if it doesn't nothing to worry anyway.
  21. whatever the car is, it s not normal for the heat indicator to move significantly from the normal (1/2 on most cars) position uphill or downhill !!!. If the engine is cool then the oil is cool and it s thick, so it does not lubricate well and running like that for a long time causes premature wear. If the engine is running colder it's mostly due to a thermostat issue so try replacing it.
  22. Check if you get too much black smoke. Bad injectors cause loss of power and it s time to check injectors if it hasn't done already. If the engine is badly worn it'll be hard to start in the morning, will burn oil and produce too much black smoke. But frankly 125K is nothing for a well maintained 2C (no offence terrabytetango ), mine has done over 210K and still going strong and I know another CE110 which is closer to 300K. Your issue could most probably be the injector nozzles so get them checked or replaced as necessary. Anyway it's better to check the injectors at least for every 100,000 km and replacing all the 4 with genuine denso ones should cost less than Rs. 10,000
  23. was just wondering who's gonna do the maintenance on these babies........ Think I saw on a fifth gear(most probably) clip that they had to fly-in a mech from Japan to fix a gear box issue...
  24. Kia people suggested him to buy a diesel sorento (saying something like its hard to get a diesel sportage to LK due to high demand in somewhere else), but he insisted and they agreed.
  25. Just to add to the Don's answer... warped discs sometimes create a vibration in the brake paddle at high speeds (when applying brakes of course)...
