Everything posted by maheshw
Express-Way Updates
+1 we shouid really apricate our ppl work....if the product is same of atleast 75% similar to the one which are in us or other country we shouild thank these guys as well as appricite this work rather than worring abt capturing for any faulty...
Hmmmm Sound From Razors
with your informations its bit diffuclt any one to comment whats exactly happening? Describe when it happening? as you guess from where it's coming? if it's coming from engine is it while A\C on or off?
Motoring Scams In Sri Lanka
This is not the first thing as well as last thing. same thing happening in some reputed companies as well.it will be bit difficult in our country to expect such things 100%.
N16 Bluebird Sylphy
Wellcome to the forum and congtrz on your buy. N16 Sylphy 1800 is very good reliable car with good interior which i too loved. i have used one for a while few months back and it has enough power to move very quickly.when it comes to fuel it doenst give any high numbers like others in the same range but 10-12 easily can get in long distance. is this have triptronic gears? have you received any repair\service details from previous owner? fully engine tune up will cover injector cleaning as well whcih cost around 15-20k with some parts replacements. EFI tune up only will cost around 5-7K. Also do a search in the forum. you can find lot of informations About this car.
- Best Car For 1.5- 1.8 Lkr
Car Dvd Sets
There are plenty of PLC. Do a search you will find a lot.
Ae100 Idel Problem
+1 to davy a fully engine tune up might solve this problem if you haven't done any recently.also finding a genuine iacv will be bit tough as well as it will cost around 10 to 15k.
Digital Camera Photography
But the man who owned the GTR will think 10-20 times than he deicide to buty the 1st GTR when a requiremnt arice to fill a teeth which cost $ 2500
Autolanka Funniest Moments
Can't watch it ?
- Post Whoring - Part 2
- Car Jerks
Cleaning Silver Coloured Plastic Parts
http://forum.autolanka.com/topic/15468-interior-cleaning-is-good-or-bad/ go thorugh this link....
Engine Oil Smells Petrol
Simply it indicates me a leak in your head gasket. did you noticed any air bubbles when open radiator cap? oil in the radiator white smoke occasionally slight drop in engine oil level slight drop in water level heat comes to 1/2 level when AC Off Heat is below 1/2 always when AC on all of these are the early symptoms of gasket leak. what was the reason for previous radiator replacement? is your fans are kicks on correct time?
Xenon Light Problem In Toyota Vitz 2007
i have experienced the same issue sm time back and finally end up by replacing 1 side ballast.might be the same issue. busually HID ballasts are starting to give troubles after some time back. Better to consult a good electrician.
- Nissan Fb15
Looking For A Reliable Mechanic In Kandy
so i have PM you some details.
Maruti Suzuki Alto 800 - Car Speed Up And Slows When Ac Off And Ac On Respectively
Helllo...Well Come to Forum and Congtratx on your new buy. As i can see if you feel this is happening while ac on\off it might be due to the a\c idle up mechanism. can you feel the same when vehicle is in IDLE status?
Common Issues With Ek3
When was the last Tune. if it's not recently its time for a complete test. also check any malfunctions in petrol pump.did you notice any temp rise? Open the radiator cap & see for any air leak. a tiny leak in gasket too can be once reason from other side.
Temperature Fluctuation
im just telling you. TP11 comes with 1.8cc engine. but the radiator of FB15 is a 1.5cc? was that different can be one reason. even if the fans woring when temp goes high, i feel they are not kicks on correct engine temp. had similar issue on a FB14. issue was a 12V relay which connected to fans.
What Insurance Scheme Is Better V*P Or F****** P**
Totally agree with you.. same experience in Sri...La... Insu.....Fo... P.... what they can do is only cut the claim not the customer satisfied service. how they explain it, SIr,your vehicle is more than 10 yrs old so & so we've to cut 10% from your bill, since your vehicle is a reconditioned one so & so we can pay only 70% for the parts, sorry you have not include this part when taking the insurance, (this will apply for fogs, lip kits, spoilers) even if you write to their CEO nothing will happen....
Loss Of Power In Cefiro A33 2.0G
1000 times....... i have PM you pls check.
He says its an indication of something wrong, but he don't know what it exactly. His advice for me is to sell the car instead of trying to fix this. But I am a person who really don't like to pass this problem on to someone else and make them suffer the same issues I have. I told him about that and then he said for me to find an engine and he will get it installed for me. it's a simple thing that everyone can understand that blinking light indicates a error. if his answer is that he cannot say anything about it, how you gonna belive his engine replacement? Did A*W test drive your car? i have heard that A*W Customer service is very good than others?
- Drove With No Tire Air
Happy Birthday Komisiripala
Ah ok then wear you suits.....have a blast Doct....Many more happy returns of the day.......
Rpm Going Low After Heat The Engine
when was you last EFI tune up? Does RPM goes up when switch on A\C ?
