kmcsb
Everything posted by kmcsb
  1. kmcsb
    Battery
    i got eg8 single carb.. i ve notice when i start the car and chk its only around 12v and i switched on AC its getting aroud 13v +/- ..
  2. kmcsb
    Battery
    machan where did you find it?? how's its condton..is there any method to get best conditon ones???hw much was it??
  3. kmcsb
    Battery
    i just replzed my battery beacuse its already passed 2 1/2 years..also battery guy told me tht one cell has died...it's not good to my alternator also ter electric devices....is t ok no?? will replzing Alternator IC cost low or high??need any special honda Ic or will it ok with universal ones?? also buying reconditon one is litle bit risky...hw much will be reconditon one??
  4. kmcsb
    Battery
    today morning it was hard to start up my car...after some cracks car starts then i rushy go to battry shop and showed it to them..he told one of my cell has died..so i replazed with exide ultimate battery (maintance free)..then he chk the condition with voltermetr...and told battery only charged when put ac (14.3v +/-) ..he told me tht be a probem in alternator.. is that right..wil it be IC?? wht you thik guys???is honda alternator IC expensive more??? how abut recondition one???
  5. kmcsb
    Tune Ups
    how do i chk my car faults by PGM CARB control unit??? i've just have one..i just turn igingation on and inspect there were no led flashing...is it the right way to chk or any other way???
  6. kmcsb
    Tune Ups
    @2427rpm HC-234 CO-2.72 02-0.94 CO2-13.2
  7. kmcsb
    Tune Ups
    i did eco test and got result...fialyi got passed..but the inspector told me tht my HC AND CO were high...miine d15b jdm single carb...before test i did tunue up by dhammika... i chkd my idle rpm is 825 and hc-393 co-3.066 AND EST wastage 9.78% and rs.14per ltr. @tuneup process dhammika inspectd and told my spark plugs,plug wires,filters,vacums,o2 sensor,carb,rotor,cap is ok...before met him i just replazed thermostat (actually there wont any thermostat installed),ngk sark plugs,oem spark plugs,honda fuel filter,vic airfilters too... plz hep guys....
  8. kmcsb
    Tune Ups
    6 monts ago one of mechanik did a carb clean..and tht's all..FYI when i repaird my A/C i put a large condesor unit also...the problem has appeared after repairing A/C..also @morning car starts and normally doing fast idle (high rpm) and then cmes back to normal....after repair tht is not get normal idle while a press gas padle.. i chkd my accelerator cable is clean and good..
  9. kmcsb
    Tune Ups
    will they able to clean my ac valve alos.or should in need to meet a mechanic first ???
  10. kmcsb
    Tune Ups
    i got eg8 single carb....when i turned on A/C i feels my car rpm getting lower....iwht you think guys....som of my friend told perhaps A/C control valve might be clogged.. also i wish to do eco test and frst i need to do tune up also..can they cleang up those valve or should i need to go mechnik... i lve in pita kote..can anyone know any best plz around my plze.. wht abut dhammika fernando....do you know his charges..... my car runs without ac might 10 .with ac its drop to 6-7kmpl.. thts serve headhe for me...recently i've cangd spark plugs,vic airfilter,new spark plug wires,replzed genue petol filter,replazed thermostat,wheel aligment,no oil leaks..but no improvement..
  11. yes mine auto choke doesntwork after repairing A/C....also when i switched on ac car gets vibrate....will it resolve by doingrepair my car..thts mean do i need carb repair kit????
  12. kmcsb
    Engine Oil
    i found mobil 2000 10w-40 semi synthetic..will it be ok to use an 160k old engine..hw about protection and performance...???
  13. kmcsb
    Idle
    ok thanks machan..that's a realif
  14. kmcsb
    Idle
    machan im not good in mechanical side...will it be easily repair...do i need anything to replze with (repair kits...)??? can it be repair by normal mechanic or should i bring this to honda specilist...
  15. kmcsb
    Idle
    machan i did the cold start u mentioned...but the problem is car doing fast idle but not stop....i waited so long (about 6minuts) but car not falled back normal rpm...so i just press the gas padel once and suddly car came back to normal rpm speed... normaly past days (before repair A/C) first car doing high idle and after 3minuts came back to normal speed...
  16. kmcsb
    Idle
    Recently i put my car for AC service. Since then the engine wont get to idle and stop racing until I press the peddle. If I dont press it it's just keep in high idle. BTW it's a D15B engine.
  17. kmcsb
    Idle
    mine eg8 single carb
  18. kmcsb
    Idle
    machan if i do a tuneup will it resolve my problem...???
  19. kmcsb
    Idle
    mine carb machan
  20. kmcsb
    Idle
    anyone there??
  21. kmcsb
    Idle
    hey friend, When i start my car in ther morning usullay car getting 2-3 miutes to warm up and reduce rpm and gets idle..but since last two days my warm up isnt get idle..its took more time thn i push accerator padle once, finally t got normally fine (got idle)..today i did same metod..normally i keep let it warm and after idle i started to go forward... but this seniro i should paddle my accerlate..why is tht..plz help
  22. tech guys doesnt have..plz tell any others...and hw much willbe 1ltr?? i need 3L
  23. kmcsb
    Gasket
    Anyone knows where to buy this gasket and filter..its from IDLE CONTROL VALVE... i seen those are worm while i was cleaning them... oem part number- 36455 PT3 A01 36454-PS4-003
  24. machan from where do you buy honda transmiision fluid..i called sevral agents but they dont have...wht type of transmission you have ? manual or auto...also how aut prices...
  25. yes machan i understand...an year ago i replzed my distributor....alos i had to renve my license and didi emmison test ..@tht time i saw my idle was 940.tht is preety much highr..isnt it..???last time it was 690...(2 yers ago) also tht report i saw my HC PPm was high tooo... so after replzmy t-stat..i just want to do a tuneup also... machan what are the stranded ignition timing...alos wht is tht degrees??? what parts should i need to watch for get more fuel efficiency to my car back...normally carbs does 10-12kmpl...mine only 6-7...
