Everything posted by Strikeee
Hi guys, I am in the process of buying a SUV to do some off roading. I won't be doing extreme off roading, but to travel in dirt tracks, sandy beaches etc where a typical family sedan can't go. At the moment I am looking at a 2002-2005 Mitsi Montero V6 3.5L. I know petrol engines are not as good as diesel when it comes to off roading, but my budget only cater up to this. So can you share you expert advice regarding this. Is it worth to buy a Montero & is it worth to buy a petrol? Cheer
Hi, Have you check whether the fuse is blown, which powers the dashboard?? If yes, try dismantle your cluster panel and check, you got nothing to lose right? Cheers
If you summarize what chan5 told, increasing the ride height will result in poor handling and ride comfort. Why don't you try to put some tyres with a taller outside diameter. This will allow you to increase ride height (from a half inch to 2 inches in some models)
Go for Falken... or a better tyre brand like bridgestone, michelin or pirelli
How To Reset Limit Switch In Toyota Premio 260
Strikeee replied to Ted's question in Electrical problems
Are you saying that your driver side shutter automatically closed itself after a certain period?? -
Do a google search, you can find some great tips and info regarding how to avoid odometer frauds. This is not only common to Sri Lanka.
Is it what I see it it?? Did they just advertise that, the bag is coming from the boot of a porsche??
Hi guys, I have a 2004 Mitsubishi Magna VRX 5 speed triptroninc front wheel drive, which clocked 120,000kms. The problem I am having with the car is it has a rattling sound in transmission in cold starts. Also it changes gears, 1st - 2nd when rpm hits around 2500, and rest changes around 2000 mark. Can you guys give me your expert advice on this matter? Cheers
This format reminds me of www.carsales.com.au Nice look
I checked your link, but there is no shipping to australia. I check Canon 70D, they priced over $1499 just the camera body here...
I am also struggling to make the decision of what to buy as my 1st DSLR. I got two options which are, Canon EOS 700D Camera + 18-55mm STM, 55-250mm STM and 55mm Lens + Bag + Tripod for $1300 Nikon D5500 Camera + 18-55mm, 55-200mm VRII Lens + Bag + Tripod for $1300 Any expert opinion here....
Just commenting... what about a Fiat 500
ebay is your friend here. You can get decent pair of scope lights, and mesh shell for somewhere around 200-300USD and those are DIY projects. If you are not sure, just search through youtube, you can find loads of videos relavent to ek3 mods.
Hey buddy, your question is too vague... for duty and taxes, vehicle's price is just one factor, YOM, engine CC etc are also taken into account when calculating. Unless you are trying to import a Holden, I think getting a car straight down from Japan is less expensive plus, JDMs are in better built quality plus with more newer features.
It depends upon the road condition you drove..... better to get it checked with a tire place....
As per my knowledge, Premios or Allions don't Triptronic. http://forum.autolanka.com/topic/14923-please-explain-me-toyota-allion-gear-modes/ This will explain...
This is at one of my relations place
Hi guys, I just want your insight about buying a vehicle which clocked over 250,000kms. Lets assume this is a SUV. I don't have a particular brand in my mind, but for the moment lets take the following models, Mitsubishi Montero (2003-2005) Nissan Patrol Y61 ( 2001-2005) Toyota Prado (2003 -2005) if it is a petrol variant what are the pros & cons of buying such & again if its diesel what are the pros & cons.. Also, what areas do I need to look in to before buy Thanks Sorry if repost
why dont you search in EBAY???
Since silicon contains acidic substance isn't applying silicon to the body of car make things worse?? My tinkering guy said, it accelerates rusting, so he said to use no-leak gasket mask(non acidic).
Sold my Xantia to a guy from Kurunagala.....
As I heard... if you do a search in google, you can find loads of links saying that...
Yes, I faced the same issue. As I heard, this is a common issue with EKs. Check on your taillight gaskets & remove the rubber beading of the trunk and see whether there are any holes made due to rust. Also, check the trunk lid's alignment and if you have a power antenna, check it also.
I think you need to get permission....So before buy, check with TRC. You can send them the specs and see what they are saying.... Reason you might not see walkie talkies at toy shops may be because they need licenses.
- 11 replies
- walkie talkie
- kids
(and 5 more)
