prvnrox
Everything posted by prvnrox
  1. what was the cost??
  2. does the gear indicator bulb in the dash board blink?? also check the oil.once u change the gear oil,you have to keep it in start for some time and then check the oil level again.usually it goes down and again you have to fill it upto the level.was it done properly?
  3. did you get it solved? I did almost all i can do spent more than 100k on the gear box and every thing.only thing which i dint touch is the ECU.fed up now! let me know if any one of you find a solution please.i will post if i happen to do.
  4. machan were u able to fix this issue???
  5. ur talking about a cone filter right?? i dont think u will have a considerable impact on fuel bro.
  6. well i read almost all the threads about gen2 but nothing had a clear cut post.every one says the gear box was sluggish but then says car is good performance wise.so i dunno whether its the pulling power or the response which is meant by the gear box is sluggish
  7. after 3 years! but still if some one is looking for better power,its honda JDM. Gen2 110bhp ek3 exi 105bhp ek3 vi 135 bhp other JDM ek3's such as SiR or Type R's will not fit in to this price range i suppose
  8. okay after two years,it might sound like a stupid thing to post on this threat.but just wanted to know whether ur gen2 is a manual or an auto? I heard the Auto is not so good both fuel and performance.just wanted to clear things out
  9. mine also has a slight buckle which is not visible.i dont feel it when i drive either but the guy at the wheel alignment place told me that it cannot be balance because it is out of shape.so i just run with that wheel in rear.anyways how long do they need to straighten it? I mean macro people
  10. i doubt even ur baby will get this much of care dude! awesome ride!
  11. yes for a Manual car those are the usual figures.An auto will never do more than 9-10 in the city traffic
  12. as per my knowledge throttle position has a particular angle.so u might as well not remove it.try another TB and see
  13. please keep us posted if u happen to go with the tokicos.
  14. No.that's the last thing I gotta try.anyways I took it to another mech.so waiting to see the outcome.will keep the thread updated
  15. I actually took it to mahesh n Ajith both.tried two throttle bodies too (recon ones). But still the problem persists
  16. Yes I actually ran a scan at one of the garages near by and also scanned it at the BOSCH service center.no error codes were found.
  17. I tried it.turned the climate control knob into red and kept the engine in start while having the radiator cap open.kept it until the coolant over flow n then closed the cap.but no luck! ;(
  18. thanx bro.I'll definitely try it tomorrow morning!
  19. depends! mine does 8kmpl and outstations 12.5kmpl
  20. Bro I think you have to either clean or replace ur IAC valve.then you will be good to go!
  21. i tried a new (recon) IACV but dint work.its hell of a headache :S these days um broke so couldnt spend money on the car.will let u know once i fix it.um going to waruna and see.so far i've shown it to Mahesh,Ajith and also the BOSCH service center
  22. exactly don.um also reluctant to buy used shocks simply because we dunno how it has been used
