WCW
Everything posted by WCW
  1. Any known local joint to buy other than ebay.....? Some where at Darley Rd or Panchi...? There is no alternator, ....It uses a DC to DC converter to charge the fwd 12V battery.
  2. Bit OT, but from where can I purchase a float charger for a car? Thanks.
  3. Following link might help you; http://www.motortraffic.gov.lk/web/index.php?option=com_content&view=article&id=165&Itemid=165〈=en
  4. Some old classic Japanese brochures found in following Japanese site. May need to use Google translating facility. There are plenty of pages! http://kyuusyamania.blog73.fc2.com/blog-date-200901.html Cheers.
  5. Amigo, Use the search button. I used and found below links might help you, http://forum.autolan...-a-honda-civic/ http://forum.autolan...-civic-es8-es5/ http://forum.autolan...ivices8-or-es5/ Cheers.
  6. Find some of common complete catalogues here http://jccc.web.fc2.com/index-en.html Enjoy!
  7. Yes, but does it make any change ? Only waste of time.
  8. WCW
    Work Place/fields
    May be he is an Ex-pilot now. This is 2012!
  9. Well, I like to see something else happens to him in opposite way (not growing). But definitely not his nose, something well below!
  10. Also check operation of air conditioner, if you are using. Due to lack of gas or malfunction of thermostat, compressor may run continuously. Improve your driving style, as discussed in previous threads. Check the engine running at correct temperature. Check Oxygen sensor too, if available. Check the brake system, binding may cause problem.
  11. Find details about Caldina http://www.cars-dire...caldina/1996_1/ Find details about Corolla vagon CE 108 here; http://www.cars-dire...a_wagon/1996_5/ As per above lists only CE 108 equipped with leaf springs.
  12. http://www.cars-directory.net/specs/toyota/carina/1996_8/
  13. Well assuming your transmission is Automatic, fuel consumption is normal as per my knowledge. Cheers!
  14. Two cents from my side. Select reputed Petrol pumping station such as 'L**gh'. Check Reading before start and at end. Watch sudden trigger squeezing changes when pumping. ,
  15. 1. ONLY FILL YOUR VEHICLE IN THE MORNING WHEN GROUND TEMPERATURE IS LOW. Buy a hybrid, can save more than few milliliters. 2. THEN YOU'RE FILLING UP, DO NOT SQUEEZE THE TRIGGER OF THE NOZZLE TO A FAST MODE Who's operating the trigger? Are you?
  16. Ok, Follow this link; http://forum.autolanka.com/index.php?/topic/13377-how-to-download-toyota-jdm-catalogues-around-1997-up-to-date/ Or even this one; http://translate.google.lk/translate?hl=en&sl=ja&tl=en&u=http%3A%2F%2Fwww.toyota-catalog.jp%2Fcatalog%2F
  17. Try to use search button provided on right top corner. May have a possibility to find Japanese manual.
  18. This is not a new, ! Difference is stealing the money from the pocket by officially in huge amount!.Again,,, Asiyawe ......... ya
  19. Insight Pros; Stylish, fuel efficient, large boot space, silent car comparing to Vitz Cons; expensive and not freely available as Vitz parts, rear leg & head space and middle seat position.
  20. Only to have original engine sound?
  21. + Clean air filter at regular intervals, maintain correct Tyre pressure, improve efficient driving patterns, use reputed petrol station, avoid traffic & unnecessary A/C usage, proper engine tune ups will do. Cheers.
  22. WCW
    Engine Flushing
    Yes, you are correct. My mistake. Even I would like to add Miniace to the expert list.
  23. WCW
    Engine Flushing
    Fellas , You can simply learn how to respect other members by looking at senior members replies such as Master Don, Harshasenadhir, etc . Those are real experts. Also check their vocabulary and compare yours.
  24. WCW
    Engine Flushing
    if i Ooop....s another senior member!!!! sorry, if I made you mad!
