harshansenadhir
  1. I believe I can second what MD says by seeing a fine example done by one of those people who do things right.
  2. harshansenadhir replied to dilku's topic in NISSAN
    I thought it'd run at the smell of Petrol vapour without even havin an engine inside..
  3. harshansenadhir replied to dilku's topic in NISSAN
    and then it can be moved to madame tussauds .
  4. found this hilarious statements in a UK based forum where car sales terminology converted to the real meaning .. Still applicable in local context too, at least most of things I would say. MUST SELL...before it blows up. RUNS FINE...I was going to say "runs beautifully" but I had a last minute conscience attack. NEEDS SOME BODY WORK...was blindsided by a Caravan. WELL MAINTAINED...I changed the oil occasionally. LOOKS LIKE NEW...just don't try to drive it anywhere. ALL ORIGINAL...I never had anything fixed, adjusted, or replaced. LOADED WITH OPTIONS...each one more troublesome than the next. NEVER SMOKED IN...unfortunately, that's the best thing I can say about it. PROJECT CAR...doesn't run. LOTS OF POTENTIAL...doesn't run. NEEDS MINOR REPAIR...doesn't run. Needs Nothing - Except a tow truck. Minor Rust - Don't sit down! Minor Rust - Major rust you can’t see. Low Mileage - Only 170,000. Convertible - After driving under truck. Runs Great - Too bad it doesn’t roll. Alarm - Wires are cut to sell stolen. Nice Stereo - To overcome exhaust noise. Needs Paint - To cover rust. New Paint - Beautifully covers rust. Fully Loaded - Seller is too. All Options - 8-track player. Only 59,000 Miles - Well actually 359,000 miles but the clock doesn't show the 300,000. Rare Model - One of 500,000 made. Must Sell - Before the police find the owner. Must Sell - Need bail money. Summer Fun - Roof leaks in winter. Summer Fun - Won't make it to autumn. Reliable - Don't leave the neighbourhood. Daily Driver - 400 miles a day. Only Driven Sundays - Sunday is race day. Engine Rebuilt - Engine degreased and steam cleaned to look it. Doesn’t Smoke - No oil to burn, or 90wt oil. Trans. Rebuilt - Fine sawdust used to make it quiet. 4 Speed Gearbox - 5th gear is dead. Hurry, Won't Last - Neither will car. New Tyres - Retreads years ago. Well Maintained - Oil changed every other leap year. Drives Like a Dream - Nightmare. Car Cover - To help keep out rats. Always Garaged - Embarrassed to leave it outside. Family Owned - Driven by 6 teenagers. Fully Restored - Nothing original. Tax Till Next Year - Stolen tax disc. Moving, Must Sell - Off to jail, need bail money.
  5. you believe the readers would be available? even the previous license had a magnetic strip which was suppose to read and store offences, penalties but the equipment/reader was never given to cops. Same applies to the VIC sticker which suppose to tag on the wind shield of the vehicles with new number plates. A readers suppose to be given to cops to identify basic vehicle information if in case to cross check, never happened. This is the next episode of the same comedy.
  6. why should someone bother? let them realize. I'm not saying Toyota sucks or bad or crap. Prices are too too too exaggerated and buying at that high price is completely insane for me. it's a blessing for us that those idiots(?) don't turn onto euros. Still can enjoy a better ride with a lower investment.
  7. yeah it's THAT thread again..
  8. Perhaps a faster way of doing 1/4 mile than using those carts with tonnes of fibre panels hanging on top of the standard body with fart cannons and still powered by the stock engine.
  9. Big jerk in the sense engine starts shuddering excessively or one time jerk as A/C engages? If engine shudders continuously, then it must be due to a faulty idle-up circuit/valve/system which ideally should speed up the engine (typically a vacuum operated valve triggered by an electric relay for carb systems). It has nothing to do with the fuel consumption assuming it's the idling up issue. If the idle up system works fine, then it can be due to stuck up/partially stuck up A/C compressor. Reason could be a bearing would've given up or excessive refrigerant in the system which makes the compressor stiffer than usual to turn. If you want to make sure the compressor runs freely, ask your A/C technician to remove the belt and turn A/C pulley and see whether it turns freely. For your fuel efficiency issue, check the tail end, spark plugs for carbon build ups. If there's carbon build up in the tail end and on spark plugs then the mixture needs to be re-adjusted. Either it's worn out fuel jet which results in high in flaw of fuel or lack of air. Check the air cleaner element and replace if it's clogged/blocked. If it doesn't help, consult an expert in carburettor tuning.
  10. tried and tested with an annoying dog when I was washing the piston set and other engine components using kerosene and petrol. Bugger would've easily outdone the 100m record of Benn Johnson back then
  11. now only read the edit, the lighting concept will definitely outdo any neon ..we would sooner see terms like "Rhythmic lights" in adverts. Forgot the key component, a fart cannon on the butt of the bull which gives +10 BP and a sound of a Yak fart..
  12. well the bullock-cart is fundamentally AWD, therefore attaching the handle to keep the butt end down wouldn't be of much help.. rather concentrate on enhancing the grip on all four legs (AWD system ) small scale spoilers on all four legs perhaps ? I wonder now ricer boys would copy this and attach spoilers onto wheels to ensure better down-force on all four corners.
  13. FLOL! Vtec Kicked out it should be, the driver should wear a helmet and a visor not to get attacked by those partially digested kos eta ejecting from the jet nozzle at ultra high speed when Vtec start kicking out... and ultra light horseshoes aka "rubber mixed allow horseshoes" or "racing plates" to ensure better grip and handling at high speeds. Further, a phone and a walk-man tied to the reins gives you a "multifunction steering" ...
  14. sent a PM as this should ideally be discussed in Euro car thread.
  15. was this a UK used specimen or a brand new import? You cannot sometimes blame agents and local spare part dealers for not having appropriate part for UK used ones and some rare variants of the same model (and we all know Peugeot agent is a very bad example to generalize). Did I read you right on that 115,000/- or was it 11,500/- ? Same happened on my D8 and I only paid 4,400/- for a brand new OEM water pump.
  16. this is what peugeot gives me when I key in my chassis number in the registered portal. 1. Vehicle characteristics, all information including all serial numbers of components. 2. Applicable/filtered spare part codes for my vehicle which even carries the latest supersede part codes. Never have gone wrong or exchanged a spare part with this. can do wonders even with agents..
  17. seriously speaking, I bet those whom are nostalgic about euro parts haven't ever touched an euro.
  18. My euro is a daily runner of course and it doesn't happen every now and then. It only happens once in a blue moon. Most of the instances, I can buy the spare part, the exact part using the item code within a matter of one day and the replaced part lasts long as oppose to cheap substitutes. It's not getting the wheels back on ground as fast as possible what matters, but to do a reliable, last long repair with solid spares is what matter for me.
  19. I'd prefer that than replacing with used junk found from delkanda or cheap substitute spare parts found in panchikawatta.
  20. LMAO , or may be "which breed got the best demand for meat, if in case I decide to sell it"
  21. the million dollar question would be "which bull is cheap to maintain Indian breed or Western/european breed"
  22. PRESTO!! an ultra economical concept, very creative. We have to consider the cost of grass whether to buy or grow it in-house to determine whether it's really economical to run a bullock cart compared to some 100km/l hybrid econo boxes. Noted quite difference in this new concept that is the forced induction is proposed to stuck up in the exhaust, care to elaborate more on that?
  23. I regret opening this thread and reading your reply amidst conducting a workshop :D I still am laughing whilst trying my level best not to. This is a nice concept than those edible plates, edible vehicles.. lolz
  24. Greed of course but they're backed and supported by penny wise pound foolish km/l fan boys who would die to save couple of liters for every hundred kms they travel by spending additional millions of bucks without considering the cost of funds, IRR, inflation ratios of the country and opportunity cost. If someone do all these calculations how come a well used, 7-8 years old econo box sells above 4 mil mark.
  25. coincident these threads popping up along with some advertisements. I don't understand why these hybrid sellers keep an unnecessary mark up and quote ultra high prices when the taxes are well reduced to encourage hybrid in-flow. Do they think the general public is unaware of the new taxation policies. I've seen them quoting above 4.0 mil for honda civic hybrid when one can bring down for merely 2.6 mil as I heard.
