Toyota Axio - Fuel Consumption - Import Tax - Market Price
yes, it was only wise to afford via a permit scheme before import taxes were lifted. In-fact a relative decided to buy the diesel through permit and again changed his mind due to huge difference in price of the petrol and diesel even with the permit.
Vehicle Insurance
not really, if paying 5k is better than missing the flight you always can proceed.
Actyon 2010 - Need Feedback Asap
it was the last bunch of permits issued. It didn't say micro specifically, it mentions the vehicle should have n percentage of local value addition leaves rest out of the competition.
Proton Or Tata
yes, somewhere around that. Stretching a bit would always save you some money in the future. If you can stretch to 1.3 then fb14 too would be an option.
Proton Or Tata
accent or a soluna would do i guess.
lol not all think the same way.
yes, only a handful available as it was priced at staggering 9.7 mil when introducing by the agents.
i thought it was quite obvious and word of mouth was such that 141 does less fuel that 121. Export model 141 looks bigger and equipped 1.6 engine and both could result in getting less fuel figures. Not sure of axio though.
Car Service
yes, repurcusions of washing engine bay of vehicles equipped with newer electronics were discussed alot and the same has been severely discouraged. Mechanical fuel injected diesels and carb model petrols can be washed with coil, distributor closed properly.
Don't Be Hurry To Buy A Vehicle
logical explanation and general expectation is high import taxes to slap in again.
Proton Or Tata
with both of the options, you have to forget the resale value. However, if you're considering to give it for rent a car purpose, then the tata might do with cheap spares. On the other hand proton might run with mitsu spares but body parts like lights may be difficult to source compared to tata. After about 3 years nothing much would left in tata interior as plastics they used are prone to break very easily and looks horrible after sometime.
Vehicle Insurance
as per the amendment of motor traffic law, now every accident suppose to report to nearest police station. Unless both parties pocket out the repair expenses. When insurance send that claim list police will file charges for not reporting the accident and fine would be 5k or onwards. This is to make accident statistics accurate.
Car Service
usual procedure of servicing the car is wash under carriage, remove engine oil, top up gear box oil/remove and fill gear box oil, remove tires and clean hubs/brake drums(if any), grease pack if any part is suppose to (hub bearings, ball joints, steering rack(non power assisted) newer vehicles are equipped less or non grease nipples ), apply thin coat of a protection oil on under carriage, replace oil filter and then wash engine bay, refill engine oil and wash body, clean interior. This may vary depending on the vehicle, esp washing engine bay, under carriage and applying oil on under carriage may not suitable for a newer vehicle. You suppose to change engine oil, change oil filter, top up or change gear box oil depending on the mileage, clean or change air cleaner depending on the mileage or condition, top up or replace differential oil if it's a rear wheel drive vehicle or 4wd vehicle, top up brake fluid and batterry water. More importantly don't let them to use the atf changer if yours is an auto, coz there were many cases reported of gear box failures due to fricton plates not engaging properly.
2000 Mitsubishi Galant Diesel
Even a thrashed engine would good to go off after 120 seconds of idle run. There are turbo timers automatically adjust shutdown time depending on the length of the run. A simple one where timer is manually set, can be installed between 2~3k. Search the forum for Miniace's contact given at Darley road, Ruwan. Now he has a shop and does all sort of things S*n L*nka did.
Window Tints-what's The Deal???
Take a chill pill man, what xxx and riddle trying to elaborate is the other side of the story which make sense too and I don't think anyone blame you anymore. Even I got shocked to see 'that' post knowing the times I went through with two kids, you know there are some seriously sick people out there Let's call a truce here and keep an eye on what our law makers are up to with this 'situational law'
Fuel Wastage With Beat Barrel ??
, guess you're kidding. There's a difference of the beat comes out of a beat barrel and a punctured tail pipe. Further, punctured tail pipe would affect fuel efficiency more than a beat barrel.
+1
Instead of using a built in turbo timer they advise on user manual to let the engine run for a while before switching it off, at least for diesel turbos which works at higher pressure than petrol. This warning is printed on the dash board itself on some Indian vehicles. Cost effective way When engaged, turbo "fan" revs at extremely high rpms and oil cooler continues to cool the turbo. Imagine you shut down the engine at once in this scenario. Turbo fan would come down from extreme high rpm to 0 at once coz engine won't take any more air into it. This generates excessive load on fins, which doesn't generate while engine at work. Further, at this instance it need to be further cooled down, but when engine stops oil circulation stops, which makes heated oil to remain inside turbo. These two will be harmful for the turbo and might reduce the life of the turbo unit. When engine runs idle for sometime, it'll give room for turbo to either slow down or to come to a complete stop depending on how turbo kick off works. This also gives room to heated up oil to cool down through oil cooler.
Congrats on your new purchase. Do a full service including all oil, filters change. Further, keep in mind that the condition of the air cleaner is critical for this turbo engine and always use the original air cleaner (slightly expensive) Does it has a turbo timer installed? if not recommended to fit a one, no hassle in counting seconds and waiting to switch off the engine when you're in a hurry.
Car Stopped In The Middle Of The Road
sounds a weak fuel pump if thats the case, however what others said on crank sensor can be checked and considered. Why i asked whether is there any resistant to start is to determine its due to excessive heat.
Fixed A Mesh Grill!!!
you're replying to history mate, he's no longer in AL and this reply goes after 3 years, 5 months and 2 days after the post you replied to.
Quick Trivia Part 2
Are you sure this model is available in SL ? MG 1100 or Morris 1100 Perhaps ?
Engine Suddenly Stopped In A Traffic Jam (autogear Car)
1. Was idle RPM 1000 throughout and is it still the same? 2. Does engine revs above 1000 at early morning start and does not goes down as engine heats up ? if your answer is yes for above, there's a high possibility of the idle control valve or TPS playing fool 1. how did engine went off ? was it sudden cut off or slow hesitant run and then stopped? if it was a sudden cut off, something to do with ignition else it can be either a. insufficient fuel feed b. miscalculation of engine management system c. engine heated up excessively either due to lack of coolant or oil 2. how hard/easy to restart it after this sudden engine dead? if it's an easy start, it could be due to some random play of a ignition related electricity but if it was hesitant, yes need a detail checking of the a. fuel feed (fuel pump, lines, filters) failing to diagnose a fault, b. fuel control and ignition control system which means engine management system (preferably a scan)
Import Tax Slashed By 50%
Think logically friends. Although tax reduction is good for the government income in terms of volume based tax income, there are serious adverse impacts of this move by letting huge amount of foreign reserves to flow out of the country. Tax income is again from internal money circulation and therefore net effect will be zero. (no gain of foreign reserves by tax income). Further, the demand for expensive, luxury vehicles were shoot up because of the savings/price drop for said category is higher, say few millions. This makes more foreign reserves to flow out as price tag of luxury vehicles are exorbitantly high. Therefore, there's no room or very very less room for government to further decrease taxes and motivate vehicle imports, instead they might tighten up screws again to stop/control this foreign currency outflow.
Could you please elaborate more on this engine refuse to start. Is it freely cranking and not firing up or it's cranking as if there's excessive load on the starter motor ? Awaiting for the response to further diagnose.
