harshansenadhir
  1. why we have stand up comedians around? Although their jokes doesn't make sense and are really crap ? Entertainment? Yeah? Same applies here i guess.
  2. amen, in addition they both share a confusing writing pattern.
  3. harshansenadhir replied to D-Devil's topic in OTHERS
    what's the number series? You won't be able to bargain more if this is a well maintained specimen. Check specifically for maintenance records and 80k isn't much for a Peugeot. Try to bargain if the seller is ok with it and you won't loose anything by bargaining. There are few known issues for this model such as ignition coil pack and fuel pump tend to give up for no reason and electronic PAS pump too is bit dodgy. Apart from that it has loads of features for that price. You can either take a trustworthy mechanic who knows european stuff or take it to agents and get a full check up done. I'm not recommending the second option knowing the undercutting deals they do. However that'll add something to your confident factor.
  4. thanks maliths and miniace
  5. true, you can have the desired number within next 30,000 numbers (3 character jumps as you said = 9999 X 3 ) if you pay additional amount. If not, in the normal process, the next number will be randomly generated from next 30,000 and not allocated numbers. I was among the team who did this software and subsequent change requests.
  6. New number generation logic was sequential until early 2003 or so. There was a problem identified by RMV that is people waiting without registering the cars to get a new number and a person can pay additional amount can obtain a number from next 30,000 numbers. Say present series is GA and if you pay more you can get a one from GC lot. This was discriminating and hence people were waiting RMV requested from the software vendor to change the logic as in next number will randomly be generated from next 30,000 numbers. So if the latest number issued was GD-0001 next one could be anything between GD-0002 and GF-0001. Therefore after 2003 you won't be able to relate the number directly to the year and you having newer plate than someone else doesn't mean that your car is registered recently.
  7. Ripper, Sumiya, Charitha, Elvis_pil, S_N and Shai thanks a lot for warm wishes guys.. thanks MasterDon for early wishes and starting the thread
  8. don't know exactly about others but 65 for sure started in 1993-1994 coz i had 65 plater registered in 94.
  9. there are quite a few variations of this model including major 3 versions. Which series this car belongs to? And what's the original engine it came with? Fuel consumption varies from model to model but generally its on the better fuel consumption range. What parts this car needs? For mechanical and some body parts like lights and stuff can be bought from panchikawatta. Subhasinghe motors, ideal automotive, L.N.D de silva motors, euro motors and dharshana motors are some key places you can search for parts. Do a price comparison as some places might quote absurd prices. For some used body parts you can contact this number, 777779677, winro automobile. Had a good collection last time i visited and fair prices. If you need any more help either reply to this post or send me a pm
  10. harshansenadhir replied to tharindu6's topic in SUBARU
    i still feel this is something other than stuck clutch plate. Clutch pedal might return to the original position even if washers of either master or slave clutch cylinders have failed coz it has a loaded spring to return the pedal. Get someone to check whether the clutch fork is moving when you're pressing and releasing the clutch pedal.
  11. I'm not quite sure the rear shocks of your model has any shock mounts, some rubber sort of thing which sits between shock and the body. Please check for worn out or cracked or stiffen shock mounts.
  12. these were taken close to the entry point at Kurundugahahathapma back in 2009 February. Visited about month ago and saw lane marking and light posts too were completed including the entry/exit ways.
  13. great, good observation there. Usually setup is wired using two power sources. One from ignition line (not from key barrel per say but a line powered by the ACC. and ON positions) and another one from direct positive line. Cause for your issue is an loose connection in the first supply I mentioned. If it's occurring else where like entire fuse board or battery terminals then the memory of the setup too should erase. Check the supply lines to setup specifically the one powered by the ignition line.
  14. belated b'day wishes bro.. hope you had a good one..
  15. sounds a loose connection somewhere. What happens to the memory of the setup when this occurs? Does it remains or you have to memorize stations again? Check following thoroughly. Check the fuse for the setup to see its loosen if not move to check Earthing point from the negative battery terminal. Remove if any rust found on the bolt which secures the supply wire to the body. Also make sure its well tighten. Check the wires attached to the battery terminals for loose connections (not the terminal itself but where it connects to the wires). Also check this wires for broken/ weaken places. If all fails give a check to prominent places where positive line gets connected such as fuse box.
  16. when did you do a gear oil change last? Sounds clogs in the torque converter.
  17. yeah, it could be the explanation for brand new vehicles. But i noticed this smell on japanese used and recon vehicles particularly. Heard its a common perfume used in japan, not sure though.
  18. you're missing the point here machang. Brake, charging, oil pressure (and some more indicators depending on options) warning lights on the dash comes at the point of ignition switch on. What is this mode? that's provided to check the bulbs of warning lights. If any of warning lights not lighting up in this mode means something wrong with the warning lamp itself. If these systems are normal then all these indicators suppose to go off after the engine start. But if system "thinks" that engine is not yet started, these lights could remain lit without any issue in these systems, namely, brake, oil. How system "thinks" that engine is running in most systems is through one supply line from alternator. So if this line doesn't feed anything to the system it continues to "think" that the engine is not running. Further, for your information, brake warning light depends on many inputs, hand brake switch, pressure switch inside the servo unit, brake pads, oil level of the brake oil reservoir.
  19. in fact there is a link. That is the console panel gets to know that the engine is running is through the alternator in some systems. If that's the case there's a possibility of some warning lights of the dash board to stay on after engine start.
  20. Does anyone know what's the perfume used in japanese recon vehicles. It's the same smell across most of unreg used cars and its cool.
  21. thanks for the update and yes, as I heard the time lines are now dragged to November if you want to buy a one from A*W. Further, I perfectly understood your reasoning but this pathetic artificially bloated second hand market will resist to this change, and as you pointed out in your previous point, if taxes go up no sooner second hand market will jump up. Also to add further, my neighbour sold his 15 sri KE72 for 525/- on yesterday the very first day it was advertised.
  22. You don't have anything to do. Run it until the shocks seasoned and give it another check. If the ride is so bumpy as in car jerks few times when it hits a pot hole or a bump, then you must check the new shocks you've put in.
  23. why not something like Sanjaya bought and posted pics if you scroll back on this thread instead? There are lots and lots of options what we discussed and with the price reduction some more will fall into this bracket. M800s of that price tag are indeed now accomplished their mission and heading to a slow death I guess.
