What's This Engine Bay?
flat 6 yeah, i didn't cover the badges due to the rarity of this particular version of this model. I only need the name of the base model
Starter Motor Runs Continuously
definitely not brushes coz if brushes weak, motor will run slowly or not run at all. However i overhauled the motor with brushes and all bearings using original stuff. This is either solonoid switch or something to with the lever that pulls the starter motor wheel.
Jeep has developed a new issue after getting it on the road after staying few months in the paint shop. Starter motor sometimes runs continuously even after releasing of the ignition key from starting position. Only way to stop it is either disconnect battery cables or tap on the place where solonoid switch fits starter motor. Very hard to find this model of starter motor or solonoid switch as this engine is the first series of 4dr5 engine aka 50A engine, which has a normal motor where new series has gear motor. I took the starter motor to three qualified electricians in jeep community and repaired the solonoid switch twice with replacing contact points and dial plate. Has any of you guys encountered this issue and is there any recommendations? Electricians ?
I Have Been Using The Wrong Alternator Belt
except for the uneven wear out of the grooves used by 4k belt leaving one groove of the pulleys, i don't see a major issue. Also this uneven wear out is negligeable
- What's This Engine Bay?
this engine bay didn't have the brake booster, and mistry solved. this is a left hand version! http://www.cardomain.com/ride/3124796- What's This Engine Bay?
mitsubishi pajero aka inter cooler model in sl with 4m40- Happy Birthday Supra_natural!!!
many happy returns of the day S_N.- 4dr5 Engine Starter Motor
any nut and bolt shop should have it, try nirmala trading at panchikawatte. Failing try some used spare parts joints- Noise When Accelerating With Ac On
general advise is not to wash the engine bay with water and is applicable when it comes to old engines if we think of extremes, simple reason is even the ditributor and coil are prone to unwanted problems when it comes to washing with water. I learnt my lesson hard way after letting the service center (a reputed place) to wash the engine bay of my 406 and i bearly escaped a costly ECU replacement. Simple question, why you risk/compromise the electronics in the engine compartment simply for a nice look inside the engine bay? not worth it, in my experience. Not only electronics but there can be some other rust prone parts where we expedite the process by adding one more component needed in rusting process, h2o vapour. No harm in not washing the engine bay and i haven't done it for more than 2 years, no one complains except myself who puts hand into engine bay every other weekend.- Noise When Accelerating With Ac On
if its not worn out belts i can think of many other, but first to suspect the bearings on A/C pulley. But that cannot be an overnight development esp after a service. Have you washed the engine bay and engine? if so, something to do with the chemicals used and rubber belt.- Noise When Accelerating With Ac On
quite true, even i'm doing this to distinguish belt noises. Was afraid putting it across because newer car engines and water doesn't go together and one should be carefull only to use few droplets directly to the belt.- Volkxwagan
- Volkxwagan
quite true, but they do exist and that's why split glass model should be considered if one opt for classic beetle. I've seen a superb condition split glass black beetle in colombo with white wall tires driven by a fairly young guy and saw an abandoned body of a split glass on matugama - neluwa road about an year ago.- One Word Thread!
noted and removed- One Word Thread!
- Undercoating
now we know who's having an interest on guys legs..- Volkxwagan
dharshana motors imported sometimes back. Not sure whether they're doing it anymore.- Volkxwagan
1303 holds the highest market value in sl. It's more modern and comes with front mcperson struts and a dash board as oppose to other beetles. If you're looking at daily ride with better handling, go for 1303 and if you're looking at a classic, go for early plates split glass 1100, 6v- J55 Turbo Timer
In fact that hurts the alternator as it generates current with no recipient as circuit breaks. Run a vehicle couple of days with battery terminals loose, immediately the alternator will pack up. If turbo timer set to simulate the ignition key off operation, than just cutting off solenoidthen there's no harm.- General Life Span Of A Car (mileage Wise)
something to do with the quality of oils and usage i would say. We tend to use vehicles for short runs mostly. Average trip at one go would be 30-40kms max where wear and tear is high.- General Life Span Of A Car (mileage Wise)
nope, as i told engine runs like new, no oil burns no leaks or whatsoever.- Customized Number Plates
he meant something else by defense & co. A vehicle belongs to one of top brass i guess..- J55 Turbo Timer
if it's only for the fuel cut off solenoid i'm very much in doubt about the impact to the alternator as it stops current flow to the batteries with switching off the ignition.- General Life Span Of A Car (mileage Wise)
it's not just about the figure indicated in the odo meter, as ruslan very correctly said it's all about how you drive and maintain. I know of this japan used hiace brought to sl by it's current owner and used very carefully. Now the odo reads something in excess of 500k and still the originat setup except time belt changes. Not even a slightest oil leak is visible. Secret is he never allow sl grease monkeys to touch the thing, not even service center guys as he changes oil by himself. Even the sump nut is intact like new. Seriously guys, we got to open some knowledge sharing on diy stuff as us as owners tend to be extra carefull in doing stuff on our vehicles. - What's This Engine Bay?
