harshansenadhir
  1. IMHO its little too much.. 1.6 ~ 1.7 would be reasonable I guess
  2. have you properly grounded the setup.. or earthed in common terms?
  3. I did lot of DIY on this area, and thought to go for a HID kit installation as well and would've fall for cheap blue coated H4 bulbs if not for this site. Check this out, it has lots of good tips and the it has nothing but basics of electricity principles http://www.danielsternlighting.com/
  4. complete engine overhaul as per the definition is quite true but so far i've overhauled not less than 5 engines of the cars I used but never had to replace piston rods. with my experience what I've replaced was mostly in that order Piston Rings, Bearings, Valve guides, Pistons, Piston sleeves, valve sheets.
  5. well i'm not too sure whether i've got it wrong but in my 406 it has a fail safe and it worked few times as well. so after knowing that i use this method to check both radiator fans. the moment i pull out the connection from the sensor both radiator fans engage in full speed (2nd stage).
  6. my advise is to go for the original one although you can improve the breaking power (NM) by installing a bigger one. then you'll probably have to replace it with the brake pump assembly if you fail to find a bigger booster which exactly fits the existing brake pump assembly. and what i'm not too sure is increasing the power of booster will harm the other components of the system such as caliper washers and other brake washers etc.. mithri might be able to shed a light on that
  7. handbrake light comes when you press the paddle 3-4 times means the vacuum pressure has gone down than normal and engine takes a load bit coz in diesels the vacuum is filled by a separate pump unlike from the intake suction on petrols. This pump you'll find most of the times coupled with the alternator. check for pump as well as there's usually an O ring fixed tot he vacuum storage (brake booster) from the brake pedal side. check for that as well. last to check is the diaphragm. if the diaphragm is faulty you better replace the booster (though I once managed to repair it of one of my 504s ).
  8. Some places like M*g*i*y does a funny engine tune up.. I once went with a friend of my who took his Hyundai Accent for a tune up. What they've done was a DYI job and charged a good 1750/- in 2005. All what they've done was removed the throttle body and cleaned it up with W*rt* throttle body and injector cleaner or s'thing and removed the idle up valve together with the motor and cleaned that.. removed the plugs cleaned them and cleaned the plug tops .. that was their engine tune-up.. I was awaiting to see a tune-up carried out with assistance of a ECU scanning tool which they haven't done on that car..
  9. really appreciate that two cents.. true what you're saying is we're dealing with uncertainty .. I wouldn't personally advise anyone to do that.. instead I took a chance and doin it ... most probably I'll go for a full cover by next year ..
  10. well then that must be a problem of having air bubbles in the diesel line.. they might haven't tightened the filter properly.. dont know whether this allowed here therefore drop a quick mail at [email protected]
  11. well bro one thing to clear out, that there's nothing offensive or personal here .. if you go through all my posts in this topic you'll realize it (or am I bad in convincing) anyways back to insurance, my opinion is you'll have to consider it with various measures.. I drove couple of 504s daily( since 2000 upto early this year) with third party insurance which was really fine coz parts were not that expensive and very hardly a bumper or body get a dent.. Hope thats common with this beetle .. and the problems in valuation of old cars.. you may not get a reasonable claim even after a damage. The latest is i'm doin a cost benefit analysis with my 406, in other words the full insurance estimate came around 42k early this year and i'm driving it with a third party to see how much i'll be payin for the damages by the end of year. if thats in excess of 42k i'll go for the insurance from next year . so far 1 trishaw and 2 bikes knocked from behind and was just bruises..
  12. well bro as you've mentioned and experienced, the sensor issue is there with EFI petrol engines.. but AFAIK this carina comes with a 2C Diesel engine which has mechanical diesel pump hence its mechanical fuel injection, unless otherwise it's a common rail injection engine of a new generation which has electronically controlled injectors. Then there's a possibility of a sensor being culprit.
  13. was it gradually developed or appeared suddenly? and whts on the clock (mileage?) most probably the engine should be 2C(turbo?) .. good engine but vulnerable to quick wear 'n tare. This symptom can be due to few reasons, starting from simplest 1. Air in the diesel line and fuel flows back to tank (but then you'll need to crank more to start ) 2. Faulty one way valve in the hand pump (where the diesel filter fits in) or blocked filter (then this lag of power will remain not only in the morning) 3. Most probable reason could be injectors if this solves when the system heats up 4. Head plate of the diesel pump may need a service 5. lack of compression in cold start. if you need any further assistance call up this number 0773064477 he's the person i'm getting my diesel engines repaired..
  14. well I never done a 3rd party insurance from c*y***co since SL *ns*r**ce were the pioneers doing it. (3rd party i mean) all you need was to fill a form with the particulars you can find in the book (chassis no, engine no, unloaded weight blah blah) and within 15mins you're done.. in late 90's (98 precisely) it took 3 hrs to get the job done when I did it for the first time but now it's just a matter of giving the book to the person who then captures all information, even to open a new policy it took just 15 mins. and yes I noted the full insurance part when you've put it in bold
  15. my gut feeling is someone stole a buck off from you for adjust the idle up claiming that he did an 'engine tune-up'
  16. wrong.. in case of a third party cover up to date revenue license is not required but the CR / or the book .. in contrary you need the third party insurance prior to obtain the up to date revenue license, and for third party they don't give a dime abt the vehicle, you don't need to take it to them except for the book...
  17. in contrary my 406 lost power when I pumped octane 95. had less than 1/4 tank when I refueled with octane 95 and afterwards I felt a loss in pickup.. and sudden jerks when pedal to the metal its D8 with 1.8l engine.. reverted back to octane 90. any 406 owners using octane 95 happily ??
  18. check the brake hose of that side.. coz in my experience with vehicles I never had to replace brake caliper washers.. and to devise such a leak through calipers is nearly impossible. Piece of advise, replace both the hoses if thats the fault.
  19. there are more like these .. most in US .. check this out .. a guy tried to loosen a bolt nut using his shot gun http://news.bbc.co.uk/2/hi/americas/7091904.stm
  20. found this while surfing .... and in case if you didn't have a good laugh try reading this post ..... http://www.audiforums.com/m_693578/..._/tm.htm#693578
  21. harshansenadhir replied to Nisala's topic in TOYOTA
    well its thats 14 sri flat roof the market is below 300k still. Saw a one on yesterday papers asking 275/- if the reg no is 15 above and high roof the market is well above 300k
  22. and talking about the car prices which is the main topic of this thread, it was set a bit lower before the budget due to duty free permits issued. Heard from very trustworthy sources that the number they issued this time cause problems in Japanese assembly lines even. Some manufacturers are unable to cater this sudden huge demand and will take abt a year to make the delivery. Was it 20,000 ? however not all of them applied and obtained the permit. What a smart decision for a country with this economic level, and relying on foreign funds to import 20,000 brand new vehicles at one go duh and since ppl were hurriedly opening LCs the prices went down, the market got a bit fluctuated, but with the budget as I foreseen things will be back to the previous equilibrium where there will be no major price hike but that is subjected to how vehicle importers and dealers interpret, and customers perceive coz there are no maximum prices defined nor rules.
  23. Thought to drop my 2 cents since someone talked abt numbers here, and of course as colombo said these are fictitious figures and does anybody knows the fact they count housewives as employed ppl in Sri Lanka? the more housewives means more employment which is utter bullshit under any economic theory. Also when there's a war situation there's a tend to GDP grow higher coz all the spendings on war also counted as government expenditure and results in puffy GDP figure but the truth is there's nothing productive towards countries economic development. Also they count government expenditure for restoring damaged infrastructure (due to war/tsunami) into GDP calculations. All these equally contributed to have a higher GDP but that's not real GDP. Also note that the private sector alone in this country maintains a 7+ GDP which means literally there's no need to have govt for maintain 7+ GDP in this country. mind you guys don't take a run based on these numbers, talk to ppl and talk to yourself and ask from yourself do you feel like ppl having money or they just roll out on credit cards, loans and ODs.
  24. I sense a problem here.. or is it just me? have u done an ATF change after you took over?
  25. hi CWA pls mail me your contact details to [email protected]
