Everything posted by CJ5
Quick Trivia 3
On the assumption that the floor is now open........ Know what it is????????
- Post Whoring - Part 2
Red Or Green Coolant For Toyota Cars?
Yes. What I did was first let the engine warm up at idling for about 5mnts with the heater on hot to circulate those lines as well. Switched the engine off and then first unscrewed the drain plug on the radiator and then opened the radiator cap.( you have to do it extremely carefully to avoid getting scalded). After all the coolent had drained out I closed the drain plug filled the radiator with water closed the radiator cap and let the engine idle for another two three mnts and then again drained out. Did this twice until the water was clear. Then leaving the drain plug and cap open I fed the radiator with water from the garden-hose and ran the engine for about 5mnts just to wash out anything remaining. Then put the drain plug back in, filled the radiator with the coolent, cleaned the bottle thorughly and filled it upto the mark and then after usual running the next day checked the coolent level in the botttle and topped up. That level remains even now.
Kia Sorento 2.2 Litre Turbo Diesel 2012 Crdi
KIA Killed In an Accident
Difference Between Fb13 & B13
4wd petrol A/T Super Saloon model E-FNB13 4wd diesel MT Super Saloon model X-SNB13 More on that at http://www.cars-directory.net/specs/nissan/sunny/1992_1/ The whole gammut of Datsun/Nissan Sunny models and specs from 1966-2002 can be found at http://www.cars-directory.net/specs/nissan/sunny/
The info at the following link might help http://www.cars-directory.net/specs/nissan/sunny/1990_1/ Going by the info found at the above link, it does not seem so.
Mixing is not advisable unless topping up with the same brand. Still if the coolent in the system is older than two years, total replacement is the way to go IMO. If the coolent type you are about to use (wurth) says it should not be mixed with any other then avoid mixing. I recently faced your situation in a Suzuki which I have and I drained the entire radiator and flushed the system with a hose and water to get all the old coolent out ( it had the red color coolent) and then filled up with the green coolent (wurth) mixed as recommended.
Mazda 323 A/c Problem
Few things to check from my own experience. 1. The filter (the bottle like thingy) 2. Cabin air filter - whether it's clogged 3. Gas pressure. I am no expert but had similar issues from time to time and these were the culprits.
Engine Oil
Gear oil viscosity is usually 90, very thick, and 40 is quite thin compared to the 90. An A/T works on thin oil because the mechanisms are totally different. If thin viscosity oil such as 40 is used in a manual gear box or differential AFIK it will be ruined in a few kms.
Engine Oil
Even U****d M****s recommends 20W-50 (Valvoline Premium Conventional) for new Mitsubishis. I have done 105000kms and use that type of oil with no complaints.
Land Rover Defender Puma Tdci Engine
Daily News?????!!!!....... It's more Daily Noise!!!!
Good Small Car For About 2 Million
If your running is only confined to the city the best, IMO, would be the Jap Alto (660cc) automatic with all options. It does 14kmpl (at least the one my wife uses does that much) is nippy for parking and very low on maintanence with original Jap parts amply available and also swappable with the Indian Alto parts and has a very good re-sale market. Of course if you intend going on long trips out of the city economy would be there (18-20kmpl) but other things such as comfort, luggage space, pulling power could be compromised.
Patch In Shutters And Windscreen -Stain
No I haven't got anything from ebay as still I have the MALCO stuff remaining, but if I had to get some from ebay I would go for the Meguiars Hard Water Spot Remover (US$11.95) which is more or less the same as the MALCO water spot remover going by the description. As for stuff from the local market I guess so far the best would be, as you say, "thinner and brasso" with the 85% local result as well!!!!
Krk Or Macvud?
Why bother with these jap engines?????? U* M****s at Delkanda now have Edelbrock performance engines from the US.
Holden Fb Special Restoration Project
Yep can use a good dose of Succinylcoline which leaves absolutely no traces even in an autopsy and death will be just thought to be natural causes!!!!
Copper Radiator Top Tank..???????
Of course copper is the way to go for the tanks. All old vehicles had copper and lasted the full life of the vehicle. My 54 year old Jeep still has the original upper and lower copper tanks no problems whatsoever.The newbies have plastic this, that, and everything just to reduce production costs and the weight of the vehicle.
Doctors Car Pass
That's the point. Any tom dick or harry who is connected to some one working in the hospital are able to lay their hands on a doctor car pass unlike a lawyers car pass which the cops never challenge and is obtainable by only lawyers!!
Importing Parts For Personal Use
bloody hell!!!!
Toyota Prius
May be the 2nd and 3rd gens too would be that in another 10 years or so!!!!!! As for me the aesthetics never appealed to me in any of the Prius models. They have been downright ugly IMO. Added to that knowing what problems it could develop such as found at http://search.yahoo.com/search?p=toyota+prius+problems&ei=utf-8&fr=b1ie7 Prius is a definite NO for me.
Declare the actual values and when the items arrive speak to the customs people ( preferably the deputy director there) and explain your circumstances and very likely you will just have to pay a nominal amount which you will not grudge. I have done it.
My deepest sympathies. I grieve with you and your cousin
Toyota Prius
Released in 1998 how many even remember this, just 15 years later??????? 1st Gen Prius
Have You Seen A Defender Fool
Yes...that is if anyone considers themselves to be the owner of the country, the road and everything else and considers that all others are subservient including the laws of the land. Unless we assert our rights and stand for our rights there will come a day when these monkeys will even walk into our land and order us out (there are a few such instances even now). Are we to excercise "patience" and let them have their way even then??????? Act now or regret later. I'd rather die fighting rather than bow down to some nincompoop
- Have You Seen A Defender Fool
That's where we go wrong and allowe these monkeys to have their way. Assert your rights and don't subject yourself to be browbeaten by these idiots. What are we becoming????? A nation full of browbeaten pussies claiming to be lions?????? Once at Panadura I too encountered these faggots and kept to my track and halted face to face. Then I pulled along side, rolled down my shutter and gave the faggots the fingure and drove off. Of course my vehicle was a similar SUV and added to that I wear dark aviators and sport a short haircut and was in white shirt and black tie which may have put them on guard too!!!! I have rolled down the shutter and given the figure many times to other convoys of idiots that bulldoze their way through in the opposite direction when they try to shove us into the drains.
