sathyajithj99
Everything posted by sathyajithj99
  1. Ayyo! That Axela
  2. Allion is a compact sedan. For that budget you can go for a Camry 2007 if don't mind the fuel economy.
  3. Saw this SUBARU Legacy AWD on my way to work today
  4. Well , I've been using an axio 141 x limited 2008 for 5 years. And I've driven a few corolla 141s of my doctor friends and we've exchanged our experience a couple of times. So here's what I've got for you. Hope this helps. Axio 141 some grades like G, X limited have got more bells and whistles than the 141 corolla. But axio X grade doesn't even have a RPM meter. So if you consider such things avoid the X grade. Axio has a better fuel economy than 141. This is totally based on my own calculations and my friend's who have corolla 141s. Very comfortable ride on carpet roads but a bit shaky on bad roads. 141 corolla was handling the badly paved roads very well, but not as comfy as the axio on carpet roads. For me also 141 corolla looks better than the Axio ,it's a few centimetres wider and longer than the Axio. But leg space is the same in both. Most of the 141 corollas were imported brand new for the permits, so they must have been maintained through the agents. So it's a bit reliable with previous service records. 141 corolla is simple with a 4 speed conventional automatic transmission, so less trouble. Axio on the other hand has a CVT which is a bit complicated. So could cause trouble with bad maintenance. But the risk totally worth it because of the smooth gear shifting and comfy ride it provides you. ( this is only my personal opinion ) But when overtaking a long vehicle like a bus, 141 corolla did better with it's 4 speed transmission and 1.6L engine, while the axio screams with high RPM due to the CVT. But if you put "S" gear on the axio, it gives sudden torque and extra engine control which makes you feel confident while overtaking. Corolla handled better at corners than the Axio because of its stiffer suspension. Finally the price tag. You could buy a corolla 141 of the same manufacture year of an axio with less kms on the odo for less price. Maybe 5 lacks or even more. So the decision is yours.
  5. I also bought an Ex#de battery for my car a year ago as Crosswind recommended. It's doing good so far. Comparing with Am#ron, it's cheaper and also got Batt mobile service.
  6. Actually 2.5L are advertised for less prices than 2L. 2L has a better 2nd hand market than 2.5L even it has less options.
  7. This is axela /3. If you wanted those headlights with bi xennon discharge lamps and daytime running lamps, you should have bought the 2.5L version of Mazda 6. You only get halogen projector lamps with no daytime running lamps with 2L one. But still you can fix xennon for your low beam projectors and also LED daytime running lamps around the fog lamp.
  8. Some photos of Mazda Axela / 3 2017 facelift were leaked. Seems like the chrome grill has pierced into the headlight. Love that design.
  9. sathyajithj99 replied to lasa's topic in The Lounge
    Got a pair of Dunlop Indonesian 185/70 14'' tyres for 20,000/= from a tyre shop belongs to a friend of my father. We bought the car 5 years back from his car sale as well
  10. I'm pretty sure Supra was referring to the brand new Mazda 2 he bought.
  11. Yaris is the export model and belta is the JDM. The differences have been discussed before. Do a search.
  12. Well, Wagon R has its ups and downs comparing with 121. It is newer so less maintenance and better on fuel and 121 is spacious better handling comparing with Wagon R and comfortable. If I were you, I'd go for a well maintained 1.5L 121 out of these 2.
  13. Look harder. I'm pretty sure you'll find a K_ no within your budget. Even a well maintained J or H no would be ok. Don't worry about second hand market as long as Sri Lankans' mentality don't change towards Toyotas.
  14. I've driven my axio 141 on that route a couple of times and I was totally disappointed of the way it felt at those bends found somewhere between Kiriella and Ingiriya. There was plenty of body roll while taking corners due to soft suspension. I always had to slow down at the corners. This is a common issue of most of the JDM Toyotas and I am pretty sure this issue is more or less present in 121 as well. So considering your weekly travel on this route I think you'd be better off with a Mazda 3 or Lancer of the same era of 121. If you really want to go with 121, I think 1.5L won't be a problem.
  15. Actually 1.8L one is 122 but people are used to call it 121
  16. Do those chicks charge per hour or on a daily basis?
  17. There are gasoline and diesel 121s. Gasoline 121s come in 3 engine capacities. 1.3L 1.5L 1.8L Out of these three 1.3L is not that good with fuel economy. The other 2 depends on your daily driving conditions. If you drive in city limits mostly with traffic 1.5L would do better on fuel. If it is long journeys including highways, 1.8 L would do better. And of course manual one would do better on fuel than the auto, but sadly most of the manual ones came with 1.3L engine which is underpowered.
