asrock
Everything posted by asrock
  1. asrock replied to Le Sabre's topic in NISSAN
    I recommend you inspect it again, after all its the brakes.
  2. TL prices are little bit high, but they do the repairs according to factory spec. If your insurance company approve the estimate go to TL, but you will probably have to wait in a waiting list, which is usually 1-2 weeks.
  3. I too suggest the Mazda 6, but if fuel and resale value are your primary concerns, consider the 2016 Allion/Premio facelift.
  4. 1998, and only 79K on the clock that's whats wrong with it
  5. If it starts in EV mode yes but usually in the mornings my one sounds like a lawn mower and gradually tones down till EV mode, after that its all history!
  6. My one sounds like a freaking lawn mower at cold starts.
  7. This has been discussed before. Try the usual places like SunLanka, Pet#o etc.
  8. These cars has been extensively discussed please use the search feature. Also there is a dedicated thread for posting fuel figures check that out too. As your first car I recommend the starlet. Old but solid, reliable car. The manual should do good on fuel and is fun to drive. But sedans like FB15, FN16 and 406 should be little more comfier when doing long trips.
  9. This is from a Nissan forum http://www.nisuv.com/nicont-204.html but its worth a read. Probably you are not switching off the engine with the shift lever in P position. Some forums also indicated that SHIFT P error could happen due to a weak 12V battery.
  10. Read the 2nd post of this thread its a different car but same scenario, all points to a bad compressor. Anyway my advice is to go to a good AC mechanic, he would be able to pin point the issue.
  11. Like hrm said check the compressor, it should be a clutch-less variable displacement compressor. Allion/Premio 260 compressors tend to fail rather quickly, when this happens some cheap ass owners gets a clutch driven 121 or 240 compressor, by-pass the electronics, modifies the brackets and fix it in there, these will not run efficiently as the original and will develop these kind of problems.
  12. There should be a idling stop switch check if thats pressed or not Check this post for its location
  13. Just watched deadpool. I really don't understand why this movie has such a good rating on IMDB. Bad story, bad acting, bad humor, bad CGI. One of the worst movies I have ever seen.
  14. I can see only 2 secs of the video?
  15. This was aired on Live@8, half of the country knows about this now.
  16. good idea, I can test it on you
  17. @PreseaLover I think I need a baseball bat too
  18. @The StigFinally got my G90 Dashcam. Its the A7LA30 chipset, upto 1920x1080 resolution is possible. Indoor quality is not that good, yet to fix it on the car and check the quality. MP4 file sizes are pretty huge, 1 minute clip is around 40MB, I only have a 16GB card, don't know how this will record. Will it overwrite old files and continue to record? The user manual is pretty useless, though I saw some where that the unit will not record if there is not enough space on the SD card.
  19. Yup on my allion it was 700 or something when idling with AC on. If there is no considerable amount of vibration you should be ok.
  20. I have experienced this on my Allion 260 and few other cars with CVT, but only on steep inclines. If this is the only issue with the CVT and if gears engage normally I wouldn't worry about this much.
  21. I guess you are referring to the 260 Allion, this has been discussed before search the forum Comfort, Performance and handling Allion would be better but the Prius would have a better acceleration. Obviously the Prius would do better on fuel Breaking I think the Prius would do better Almost all facelift and pre facelift allions I have seen didn't have VSC or TC but the prius has them both. Probably depends on the Grade. Both come with most of the latest features, but being a hybrid the prius may have additional features. Probably depends on the Grade. If you are going for the Allion look for the so called G grade with Illuminated dashboard meter panel etc.
  22. LOL half of that is bullshit like all their other articles.
  23. Another one of those articles, I wonder how many of these are practical? http://turboholics.lk/2016/07/11/windshield-එක-ආරක්ෂා-කරමු/
  24. Nice DIY job machan, and a good write up. Keep it up.
