Everything posted by HashanJay
Thanks @Davy , I didn't know the behavior of the signal light, gonna give this a try today when I'm heading home.
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
Sorry for late reply and for taking this thread off the focus.. Yes, The even if I pull it all the way up, it doesn't toggle the high/low beam when released instead it acts as the headlight flasher. But once in a while, it works and after some time it stops working. Since I've been using the car for like 3+ years now, I'm pretty confident that I'm pulling the switch in the correct method. I couldn't think of any logic behind this, maybe heat or some other issue. Since this happens from a set of relays I thought it might be some issue there, but still, a not a single electrical mechanic couldn't solve this. They either advice to replace the switch or the set of relays.
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
Yes, in my case, the toggle doesn't happen. Pushing the switch upwards and holding there will light up both high and low beams, and then when releasing it goes back to the low beam (instead of switching to high beam). This isn't a big concern since I don't drive outside Colombo much nowadays. But at higher speeds, it's pretty annoying.
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
My car has a weird issue, I don't know whether this is something to do with Signal/Wiper Stalk Lubrication. When I switch to high beams, they don't get hold in (it acts as the pass-light). But it rarely works normally (holds into the high beam). I think this is a design issue in the Lancer (and many Mitsubishi vehicles). The high beam switch is not a mechanical switch like other cars (where the switch should push downwards to go for the high beam). I don't know whether this is a common issue, but we had the same in our old L300 van Edit: it's a CS3
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
I think they need to replace the airbags unit and other replacements are the motivation factors
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
I guess I need to get it fixed before things go beyond repair. Thanks for the advice @trinity & @Davy You guys have been always helpful !
- 34 replies
- 1
- unit#d mot#rs
- takata
(and 3 more)
Yeah I have tried to plug a HUD device that plugs into the OBD port, but it did not pick anything except getting power from the socket...
Sorry guys, it has been a busy week. Good to hear that some got it fixed... Safety is pretty important @Dushyantha: Yeah, they've replaced the passenger airbag inflator unit (the guy who took over the job told me that). I kept the car there and collected at the end of the day. There was a metallic noise coming from the engine bay when the AC was on, I mentioned that to them in the morning when I hand over the car. They were good enough to check that. According to them, it's a pulley (AC compressor) which is at end of its lifetime. The replacement from agent costs 36000 for pulley itself. He told me that it could be fixed from good AC repair workshop..
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
Hi, It's being a while since my last post. But this isn't about an issue with my car . Two days back, I received a call from Unit#d Mot#rs (Mitsu Agent) on an air bag inflator unit upgrade which is FREE ! I contacted @trinity (the lancer geek) but he was unaware of this. When I Googled it then it was there/ It's a recall as per Mitsu site. http://www.mitsubishicars.com/recall I think the biggest problem agents have is that they don't have a database of Lancer owners. Since a very few take vehicles there for service etc. If someone owns a Lancer 2005 - 2007 better to talk to the agent and get it fixed. I'm going there tomorrow, so I will keep you posted... Cheers,
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
Anyone being contacted by Unit#d Mot#rs on replacing the airbag inflator unit upgrade on Lancer CS series ??Â
Oh Man ! Please accept my belated birthday wishes ! Hope you had a good one !
Hey Try one of these http://www.ebay.com/itm/Turbo-Sound-Fake-BlowOff-Simulator-Universal-Car-Exhaust-Muffler-Pipe-Whistle-/261516195883 http://www.ebay.com/bhp/turbo-whistler These work well if the car has automatic transmission..... Please upload a sound clip when you install these on your car !! Cheers !
In my car (CS3) the default size is 195/60/15... I guess putting 205s might be tricky coz it might touch against the wheel covers on a full turn of wheels. In my case, one wheel cover had few missing clips and on a full turn sometimes the tire touched against the cover with 195 tires. Just check before you pay the price.
hey PreseaLover, No matter how thin the protective film is, still it blocks a certain portion of the light emitting from the bulb. My car had one blackish color headlight protection film (done by the previous owner) on it and it looked really nice, but the visibility at night was not that good when I first took her on a night ride in a non-lighted up area. It went from bad to worse with the time. Then I noticed that the heat produced by the bulbs are making this thin film more and more dense and the amount of light trapped is getting higher. Eventually my headlamps looked darker than before. So finally removed the film and cleaned the glue that it left behind (it took a while to clean it), and the night visibility was enough for my night time journeys. Just wanted to share my experience with headlight tint
DELETED: REPOST !
Woah ! Sexy wheels... Nice machan.. Will look good on your ride.. Post some snaps after installing? By the way are those 15" ?
This video might be useful for car buyers. Explains how to inspect, worth take a look. PS: I don't know whether I have posted on a wrong thread. feel free to move or remove
I bought one from local online store, they said that they got plenty of them returned. The reason is that the hose is leaking, the horse is expandable and the materiel is not that hardy in usage. Luckily mine was not, but if you plan to use on rough surfaces with rocks and all then this might not be the best option. Buy this is just 1 USD, I bought mine for 900+ I think.
I'm Sure Mr. President will ban autolanka if he sees this girls with #bras Seasons Greetings !!!
Hi Praz, Your heavy traffic figures looks fine since my 2008 1.6 CS3 / (manual) does the same or slightly more in heavy traffic (Battharamulla / Rajagiriya), but when it comes to the less / normal traffic conditions mine does around 10 - 12 kmpl and outstation does around 12- 14 kmpl. I remember one time it did 15kmpl+ on highway. If you got an Android phone and would like to keep your fuel records in one place, there's a handy app called 'Fuelio', I use that and during my usage around 20k my CS3 has an average of 11.5 kmpl in mix driving conditions. And as Davy said watch out for the buggers who forcefully pump full tank until fuel spills out form the tank.
4shared links are expired I found the same on Google drive Links 2003 Lancer Factory Service Manual: (6 files) 2003 LANCER OZ FSM Files --------------------------------------------------------------------- 2006 Lancer Factory Service Manual: (10 files) 2006 Lancer FSM Files
Awesome collection, Thanks a lot, Davy! Really appreciate your help from the beginning... I can't access 4Shared from Office I will check when I get home....
Thanks Davy, Any chance of that workshop manual being a PDF? Was it there on Sampath's tread on Manuals / brochures? How many liters will it need to replace the existing oil in the system ?
Thanks, Davy! Same here CS3 (2008), No noises or any known symptoms but I do have a issue with clutch when driving in unmoving traffic, but it rarely happens I thought of getting the oil changed since it's gonna be 100k pretty soon. Thank you for the info! Any place that you would recommend and if you recall the costs just let me know. I have a place nearby and I will check with them as well.
